JetPack 5.1.2 , the latest production release for Jetson is now live! JetPack 5.1.2 adds support for Jetson AGX Orin Industrial module and brings new features in bootloader, camera, security and OTA. JetPack 5.1.2 includes the same version of compute stack as JetPack 5.1.1 but upgrades VPI to VPI 2.3. JetPack 5.1.2 supports all Jetson Xavier and Orin modules and developer kits.
Support for Jetson Orin NX and Jetson Orin Nano in Image based OTA tools
Please note that, we had deprecated Nvbuf_utils in JetPack 5 last year and with this release, we are removing Nvbuf_utils. Refer to migration guide to migrate from Nvbuf_utils to NvUtils.
Installing JetPack 5.1.2
You can install JetPack 5.1.2 using multiple ways:
Using SDK Manager: Install JetPack 5.1.2 using SDK Manager on any Jetson Orin and Xavier modules.
SDCard Image: If you are using Jetson Orin Nano Developer Kit or Jetson Xavier NX Developer kit, then you can use the SDCard image from JetPack 5.1.2 page.
Flashing Scripts: Download the Jetson Linux tar balls from Jetson Linux 35.4.1 page and use flashing scripts to flash. Refer to QuickStart section in Jetson Linux Developer Guide.
Debian Packages: After flashing Jetson Linux, you can install the rest of the JetPack using apt commands. Please refer JetPack documentation
To upgrade from a previous version of JetPack 5 using debian packages, refer to JetPack documentation.
Hi.
I just have installed jetpack 5.12 and for beginning tried to recompile and flash kernel to my Jetson AGX Orin 64GB-DRAM develop kit.
After flashing board never come up.
Can I get help?
Run the following commands to export the environment variables:
export KERNEL_DIR=kernel-5.10
export CROSS_COMPILE=$HOME/l4t-gcc/bin/aarch64-buildroot-linux-gnu-
export JETPACK=$HOME/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
export KERNEL_OUT=$JETPACK/images
export KERNEL_MODULES_OUT=$JETPACK/images/modules
Download BSP sources from the Jetson Download Center for NVIDIA Jetson Linux 35.4.1 and extract the sources into Jetpack directory:
mkdir -p sources && cd sources
tar -xvf public_sources.tbz2 Linux_for_Tegra/source/public/kernel_src.tbz2 --strip-components=3
tar -xvf kernel_src.tbz2
steps of building the BSP sources to generate the kernel Image, the external modules, and the device tree blob.
4.1 Create the directories for the build outputs:
mkdir -p $KERNEL_MODULES_OUT
4.2 Clean the environment: ( install before: sudo apt-get install python3-sphinx )
cd $JETPACK/sources/kernel/$KERNEL_DIR
make mrproper
4.3 Setup the default configuration:
make ARCH=arm64 O=$KERNEL_OUT tegra_defconfig
4.4 Build the BSP: ( install before: sudo apt-get install libssl-dev )
make ARCH=arm64 O=$KERNEL_OUT CROSS_COMPILE=$CROSS_COMPILE -j4
4.5. Install the modules to the output directory created in step 1:
make modules_install ARCH=arm64 O=$KERNEL_OUT CROSS_COMPILE=$CROSS_COMPILE INSTALL_MOD_PATH=$KERNEL_MODULES_OUT
4.6. Backup the binaries that come installed by default in Jetpack:
BKUP_DATE=date "+%Y_%m_%d_%H_%M_%S"
mv $JETPACK/kernel/Image{,.$BKUP_DATE}
mv $JETPACK/kernel/kernel_supplements.tbz2{,.$BKUP_DATE}
mv $JETPACK/kernel/dtb{,.$BKUP_DATE}
4.7. Copy the binaries built to the default locations expected by the flashing tool:
cd $KERNEL_OUT
cp ./arch/arm64/boot/Image $JETPACK/kernel/
cp -r ./arch/arm64/boot/dts/nvidia $JETPACK/kernel/dtb
4.8. Update the kernel modules in the kernel supplements tarball:
cd $KERNEL_MODULES_OUT
tar --owner root --group root -cjf $JETPACK/kernel/kernel_supplements.tbz2 lib/modules
4.9. Install tegra binaries:
cd $JETPACK
sudo ./apply_binaries.sh
Set target to recovery mode and Execute the flash script:
./flash.sh jetson-agx-orin-devkit mmcblk0p1
After success in all steps, after reset I tried to run
sudo screen /dev/ttyACM0 115200
failed - /dev/ttyACM0 not found
Target is not running with display, keyboard and mouse connected.
I have been using Nvidia AGX Orin 64gb Developer kit, from past 1 week I am facing difficulties with DP port.
I mean I am not able to get the display, while troubleshooting I have tried to re-flash the image thinking if there was probably any OS issue but my host system properly detects the Developer kit but while flashing the OS image I would require the display in working condition for successful installation.
Could anyone please help me conforming that it’s a display issue or if there is anything I am missing.
