Jetson Orin spi with only 3 wires
Hi
I would like to use the SPI bus with only 3 wires. SCLK, CS, and SDIO.
How to configure the jetson module ?
David
Hi etasse,
Are you using the devkit or custom board for Orin NX?
Do you mean that you want to use SPI with 3-wires(SCLK, CS, SDIO) instead of 4-wires(SCLK, CS, MISO, MOSI)?
If so, you can just short MISO and MOSI externally w/o any configuration from SW.
