Is there any meothd to show the flash detailed info of Jetson Orin NX 16GB-DRAM (P3767-0000)
Hi Experts,
base on dts file, I found out that there are 4 spi devices on the Jetson Orin NX 16GB-DRAM (P3767-0000)
spi@3210000{
status = “okay”;
spi@0 {
compatible = “tegra-spidev”;
reg = <0x0>;
spi-max-frequency = <50000000>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,rx-clk-tap-delay = <0x10>;
nvidia,tx-clk-tap-delay = <0x0>;
spi@1 {
reg = <0x1>;
controller-data {
/* SPI3, 40pin header, Pin 37(MOSI), Pin 22(MISO), Pin 13(CLK), Pin 18(CS) */
spi@3230000{
status = “okay”;
spi@0 {
reg = <0x0>;
controller-data {
spi@1 {
reg = <0x1>;
controller-data {
Could you please tell me where I can check the the spi devices detailed info.
thanks,
LImeng
Hi meng.li,
Are you using the devkit or custom board for Orin NX?
There’re 2 SPI interfaces available for Orin NX, and 2 CS for each SPI interface.
What do you mean about “the spi devices detailed info”?
The pin mapping? SPI frequency? SPI mode?
May I know what’s your use case for SPI interface?
Hi KevinFFF,
I don’t use customer board.
I use the NVIDIA Orin NX module and the NVIDIA Orin Nano carrier board.
About the “the spi devices detailed info”
I mean that I don’t know what spi slave chip is connected, because I don’t have the schematics of the Orin NX module. It is not showed to users like the schematic of carrier board.
thanks,
LImeng
Hi meng.li,
SPI interface is from the SoM, you can find more details in Jetson Orin NX Series and Orin Nano Series Design Guide and Jetson Orin Series SoC Technical Reference Manual
