Hi, I want to only update kernel and modules, I use this way:
1. modify /boot/extlinux/extlinux.conf to backup kernel
2. copy new kernel to board
3. strip and tar modules,then copy to board
4. update lib/modules/<version> with step3
then, jetson boot up and everything is ok , except no UI. Are there some error to update kernel and modules?
Note: I know there is a flash.sh script that’s provided by nvidia. But it’s too violent, because I just wanted to update the kernel and modules.
what modification did you make to the kernel image?
I want to disable IOMMU,
Will it work fine if you do a complete re-flash?
No,it’s no work. I test just now. I replace those files followed build kernel, but when device boot up there are too many those messages:
[ 16.885955] pwm_fan: disagrees about version of symbol module_layout
[ 16.899624] ina3221: disagrees about version of symbol module_layout
[ 16.956510] systemd-journald[311]: Received client request to flush runtime journal.
[ 19.343520] ina3221: disagrees about version of symbol module_layout
[ 19.343759] ina3221: disagrees about version of symbol module_layout
[ 19.434682] nvmap: disagrees about version of symbol module_layout
[ 19.448536] userspace_alert: disagrees about version of symbol module_layout
[ 19.448538] userspace_alert: disagrees about version of symbol module_layout
[ 19.448542] userspace_alert: disagrees about version of symbol module_layout
[ 19.448734] userspace_alert: disagrees about version of symbol module_layout
[ 19.448745] userspace_alert: disagrees about version of symbol module_layout
[ 19.449718] pwm_fan: disagrees about version of symbol module_layout
[ 19.449853] userspace_alert: disagrees about version of symbol module_layout
[ 19.452196] spi_tegra114: disagrees about version of symbol module_layout
[ 19.452284] userspace_alert: disagrees about version of symbol module_layout
[ 19.452443] tegra_bpmp_thermal: disagrees about version of symbol module_layout
[ 19.452519] spi_tegra114: disagrees about version of symbol module_layout
[ 19.452818] tegra210_adma: disagrees about version of symbol module_layout
[ 19.453045] tegra210_adma: disagrees about version of symbol module_layout
[ 19.453315] userspace_alert: disagrees about version of symbol module_layout
[ 19.454574] snd_soc_rl6231: disagrees about version of symbol module_layout
[ 19.455926] nvidia: disagrees about version of symbol module_layout
[ 19.456166] userspace_alert: disagrees about version of symbol module_layout
[ 19.456811] typec: disagrees about version of symbol module_layout
[ 19.463503] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.463699] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.464362] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.464365] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.464734] snd_hda_core: disagrees about version of symbol module_layout
[ 19.464803] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.465596] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.465731] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.465759] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.465879] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.466018] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.466020] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.466155] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.467301] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.467910] nct1008: disagrees about version of symbol module_layout
[ 19.468131] snd_soc_spdif_tx: disagrees about version of symbol module_layout
[ 19.469524] snd_soc_simple_card_utils: disagrees about version of symbol module_layout
[ 19.474761] nvadsp: disagrees about version of symbol module_layout
[ 19.479686] using random self ethernet address
[ 19.479689] using random host ethernet address
[ 19.482506] snd_soc_tegra210_ahub: disagrees about version of symbol module_layout
[ 19.485585] cfg80211: disagrees about version of symbol module_layout
[ 19.541811] sha1_ce: disagrees about version of symbol module_layout
[ 19.541827] sha1_ce: disagrees about version of symbol module_layout
[ 19.541842] sha1_ce: disagrees about version of symbol module_layout
[ 19.541849] sha1_ce: disagrees about version of symbol module_layout
[ 19.541881] sha1_ce: disagrees about version of symbol module_layout
[ 19.541895] sha1_ce: disagrees about version of symbol module_layout
[ 19.541970] sha1_ce: disagrees about version of symbol module_layout
[ 19.542006] sha1_ce: disagrees about version of symbol module_layout
[ 19.542047] sha1_ce: disagrees about version of symbol module_layout
[ 19.542209] sha1_ce: disagrees about version of symbol module_layout
[ 19.542211] sha1_ce: disagrees about version of symbol module_layout
[ 19.542320] sha1_ce: disagrees about version of symbol module_layout
[ 19.564922] sha256_arm64: disagrees about version of symbol module_layout
[ 19.564925] sha256_arm64: disagrees about version of symbol module_layout
[ 19.564984] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565019] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565023] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565039] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565217] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565297] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565404] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565519] sha256_arm64: disagrees about version of symbol module_layout
[ 19.565737] sha256_arm64: disagrees about version of symbol module_layout
[ 19.572454] sha256_arm64: disagrees about version of symbol module_layout
[ 19.586609] ghash_ce: disagrees about version of symbol module_layout
[ 19.586612] ghash_ce: disagrees about version of symbol module_layout
[ 19.586651] ghash_ce: disagrees about version of symbol module_layout
[ 19.587098] ghash_ce: disagrees about version of symbol module_layout
[ 19.588785] ghash_ce: disagrees about version of symbol module_layout
[ 19.589044] ghash_ce: disagrees about version of symbol module_layout
[ 19.589230] ghash_ce: disagrees about version of symbol module_layout
[ 19.589720] ghash_ce: disagrees about version of symbol module_layout
[ 19.590550] ghash_ce: disagrees about version of symbol module_layout
[ 19.591959] ghash_ce: disagrees about version of symbol module_layout
[ 19.592119] ghash_ce: disagrees about version of symbol module_layout
[ 19.594973] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.594975] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.594986] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.594988] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.594991] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.595084] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.595239] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.595431] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.599535] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.602709] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.602744] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.602811] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.602955] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.603008] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.603685] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.603936] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.604132] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.609326] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.610580] btintel: disagrees about version of symbol module_layout
[ 19.610625] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.610661] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.610959] btintel: disagrees about version of symbol module_layout
[ 19.610962] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.610991] ghash_ce: disagrees about version of symbol module_layout
[ 19.611225] btintel: disagrees about version of symbol module_layout
[ 19.611406] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.611719] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.611769] aes_ce_cipher: disagrees about version of symbol module_layout
[ 19.613770] loop: disagrees about version of symbol module_layout
[ 19.615402] rtk_btusb: disagrees about version of symbol module_layout
[ 19.663658] input_leds: disagrees about version of symbol module_layout
[ 19.665681] btintel: disagrees about version of symbol module_layout
[ 20.234384] rtk_btusb: disagrees about version of symbol module_layout
[ 20.885437] binfmt_misc: disagrees about version of symbol module_layout
[ 22.940974] binfmt_misc: disagrees about version of symbol module_layout
[ 58.681779] Please complete system configuration setup on the serial port provided by Jetson's USB device mode connection. e.g. /dev/ttyUSBx where x can 0, 1, 2 etc.
