I have been looking for samples/examples showing how to transfer data from a Vulkan context to V4L2 (NvBuffer) without passing by the CPU, but couldn’t find anything.
I am trying to encode frames rendered in Vulkan using the V4L2 Video encoder API on the Jetson.
I managed to generate a valid video by copying frame data from the vulkan context to the CPU and then from the CPU to NvBuffers, but for obvious performance reasons I would like to keep data on the GPU and copy it directly from the Vulkan context to NvBuffers.
I tried 2 different ways so far without success:
1# Create a NvBuffer using NvBufferCreateEx and import it in Vulkan as an external memory
int dmabuff_fd;
NvBufferCreateParams cParams;
cParams.width = ctx.width;
cParams.height = ctx.height;
cParams.layout = NvBufferLayout_Pitch;
cParams.colorFormat = NvBufferColorFormat_YUV444;
cParams.nvbuf_tag = NvBufferTag_VIDEO_ENC;
cParams.payloadType = NvBufferPayload_SurfArray;
ret = NvBufferCreateEx(&dmabuff_fd, &cParams);
vk::ImportMemoryFdInfoKHR importMemInfo{};
importMemInfo.handleType = vk::ExternalMemoryHandleTypeFlagBits::eOpaqueFd;
importMemInfo.fd = dmabuff_fd;
vk::MemoryAllocateInfo allocInfo = {};
allocInfo.pNext = &importMemInfo;
allocInfo.allocationSize = memReqs.size;
allocInfo.memoryTypeIndex = Vulkan::findMemoryTypeIndex(memReqs, memProps, vk::MemoryPropertyFlagBits::eDeviceLocal);
auto bufferMemory = device.allocateMemoryUnique(allocInfo);
But this fails with the following error during the call to allocateMemoryUnique:
PosixMemGetSize: lseek failed: Bad file descriptor
NVMAP_IOC_FREE failed: Bad file descriptor
terminate called after throwing an instance of 'vk::OutOfDeviceMemoryError'
what(): vk::Device::allocateMemoryUnique: ErrorOutOfDeviceMemory
I also tried to use vk::ExternalMemoryHandleTypeFlagBits::eDmaBufEXT for the handle type,
but physicalDevice.getExternalBufferProperties indicated that no valid usage was possible.
2# Create an exportable buffer in Vulkan and pass its file descriptor to V4L2
vk::ExportMemoryAllocateInfo exportMemInfo{};
exportMemInfo.handleTypes = vk::ExternalMemoryHandleTypeFlagBits::eOpaqueFd;
allocInfo.pNext = &exportMemInfo;
auto deviceMemory = device.allocateMemoryUnique(allocInfo));
vk::MemoryGetFdInfoKHR fdInfo{};
fdInfo.memory = deviceMemory.get();
fdInfo.handleType = vk::ExternalMemoryHandleTypeFlagBits::eOpaqueFd;
dmabuff_fd = vulkanBackend.device().getMemoryFdKHR(fdInfo);
v4l2_buf.m.planes[j].m.fd = dmabuff_fd;
ret = ctx.enc->output_plane.qBuffer(v4l2_buf, NULL);
This fails with the following error message:
nvbuf_utils: dmabuf_fd 1140 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
Could you give me any hint on how to manage this?
Thank you in advance.
Pierre.
