I have read all the examples in the Tegra_multimedia_api.
I have a question ,How get the dma(YUV420DATA) data .
the sample 12:
STEP1: I got preprebuffer about dmabuffer in function “prepare_buffers”
STEP2: use the “start_capture” we can get YUV422 file.
STEP3:
NvBufferMemSyncForDevice(ctx->g_buff[v4l2_buf.index].dmabuff_fd, 0,
(void **) &ctx->g_buff[v4l2_buf.index].start);
// Convert the camera buffer from YUV422 to YUV420P
if (-1 == NvBufferTransform(ctx->g_buff[v4l2_buf.index].dmabuff_fd, ctx->render_dmabuf_fd,
&transParams))
ERROR_RETURN("Failed to convert the buffer");
cuda_postprocess(ctx, ctx->render_dmabuf_fd);
ctx->renderer->render(ctx->render_dmabuf_fd);
How can I get data in render_dmabuf_fd,ths video format is YUV420 and how can i translate
to NvBuffer struct ;
I want use the “NvVideoEncoder” to encode video that come form V4L2_DMA.
can you help me ?
// TODO add multi-planar support
// Currently it supports only YUV422 interlaced single-planar
if (-1 == NvBufferMemMap(ctx->g_buff[index].dmabuff_fd, 0, NvBufferMem_Read_Write,
(void **) &ctx->g_buff[index].start))
ERROR_RETURN("Failed to map buffer");
I tried this method, and by virtual mapping, I can get YUV422 data.But it really can’t get YUV420M data.
ctx->render_dmabuf_fd is YUV420M converted from ctx->g_buff[index].dmabuff_fd, so you should map/unmap render_dmabuf_fd.
Thank you ,dear DaneLL,I found a similar method in the sample, referring to sample_00;
NvBufferParams params;
NvBufferGetParams(ctx->render_dmabuf_fd, ¶ms);
// create new ifstream
ofstream *streamOutput = new ofstream("appYuv420p.yuv");
if(!streamOutput->is_open())
// streamOutput->good();
printf("Error opeing input file\n");
void *psrc_data;
// unsigned int plane;
for(int j=0;jrender_dmabuf_fd,j,NvBufferMem_Read_Write,&psrc_data);
if(ret == 0)
// unsigned int i = 0;
NvBufferMemSyncForCpu(ctx->render_dmabuf_fd,j,&psrc_data);
for(int pos=0;poswrite((char*)psrc_data+pos*params.pitch[j],params.width[j]);
if(!streamOutput->good())
// streamOutput->
printf("stream write failed plane:%d\n",j);
NvBufferMemUnMap(ctx->render_dmabuf_fd, j, &psrc_data);
