SOLVED!
that’s indeed the direction in which I was trying to investigate…
but, parse-edid was not able to correctly parse what was coming from (one of) the monitor which was not working with my board (an ASUS VS238), here is its output:
This is read-edid version 3.0.1. Prepare for some fun.
Attempting to use i2c interface
No EDID on bus 0
No EDID on bus 1
No EDID on bus 2
No EDID on bus 4
No EDID on bus 5
1 potential busses found: 3
256-byte EDID successfully retrieved from i2c bus 3
Looks like i2c was successful. Have a good day.
Checksum Correct
Section "Monitor"
Identifier "ASUS VS238"
ModelName "ASUS VS238"
VendorName "ACI"
# Monitor Manufactured week 51 of 2012
# EDID version 1.3
# Digital Display
DisplaySize 510 290
Gamma 2.20
Option "DPMS" "true"
Horizsync 24-83
VertRefresh 50-75
# Maximum pixel clock is 170MHz
#Not giving standard mode: 1152x864, 75Hz
#Not giving standard mode: 1280x960, 60Hz
#Not giving standard mode: 1280x1024, 60Hz
#Not giving standard mode: 1440x900, 60Hz
#Not giving standard mode: 1680x1050, 60Hz
#Not giving standard mode: 1920x1080, 60Hz
#Not giving standard mode: 1280x720, 60Hz
#Not giving standard mode: 1280x800, 60Hz
#Extension block found. Parsing...
Hmm, you have data blocks, but not video ones... weird
Something strange happened. Please contact the author,
Matthew Kern at <pyrophobicman@gmail.com>
Thus, I e-mailed the author, as suggested by the command output ;) sending also the binary EDID provided by get-edid.
He quickly answered that he will fix this problem in the next release and moreover he provided to me the correctly parsed EDID (I have to thank him again for his help!)
Here is the correctly parsed EDID:
Section "Monitor"
VendorName "ACI"
# EDID version 1.3
# Digital Display
DisplaySize 510 290
Gamma 2.20
Horizsync 24-83
VertRefresh 50-75
Modeline "Mode 16" 27.00 720 736 798 858 480 489 495
525 -hsync -vsync
Modeline "Mode 0" 148.50 1920 2008 2052 2200 1080 1084
1089 1125 +hsync +vsync
Modeline "Mode 1" 25.200 640 656 752 800 480 490 492
525 -hsync -vsync
Modeline "Mode 2" 27.027 720 736 798 858 480 489 495
525 -hsync -vsync
Modeline "Mode 3" 27.027 720 736 798 858 480 489 495
525 -hsync -vsync
Modeline "Mode 4" 27.000 720 732 796 864 576 581 586
625 -hsync -vsync
Modeline "Mode 5" 27.000 720 732 796 864 576 581 586
625 -hsync -vsync
Modeline "Mode 6" 74.250 1280 1720 1760 1980 720 725
730 750 +hsync +vsync
Modeline "Mode 7" 74.250 1280 1390 1420 1650 720 725
Modeline "Mode 8" 74.250 1920 2448 2492 2640 1080 1082
1089 1125 +hsync +vsync interlace
Modeline "Mode 9" 74.250 1920 2008 2052 2200 1080 1082
1087 1125 +hsync +vsync interlace
Modeline "Mode 10" 54.054 1440 1472 1596 1716 480 489
495 525 -hsync -vsync
Modeline "Mode 11" 54.054 1440 1472 1596 1716 480 489
Modeline "Mode 12" 54.000 1440 1464 1592 1728 576 581
586 625 -hsync -vsync
Modeline "Mode 13" 54.000 1440 1464 1592 1728 576 581
Modeline "Mode 14" 148.500 1920 2448 2492 2640 1080
1084 1089 1125 +hsync +vsync
Modeline "Mode 15" 148.500 1920 2008 2052 2200 1080
Modeline "Mode 17" 74.25 1280 1390 1430 1650 720 725
Modeline "Mode 18" 74.25 1280 1720 1760 1980 720 725
Modeline "Mode 19" 27.00 720 732 796 864 576 581 586
625 -hsync -vsync
Option "PreferredMode" "Mode 16"
EndSection
I just copied and pasted all of this in the /etc/X11/xorg.conf (in the place of the already present “Monitor” section).
After a reboot the monitor is correctly displaying the board boot and after some seconds the ubuntu desktop.
