Hello everyone,
I have bumped into some problems regarding USB connection, I’ve tried the following commands but I still can’t get a connection working:
$ lsusb
then I got
Bus 002 Device 003: ID 05e3:0616 Genesys Logic, Inc. hub
Bus 002 Device 002: ID 0955:09ff NVidia Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 028: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 030: ID 1a86:5523 QinHeng Electronics CH341 in serial mode, usb to serial port converter
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I’m sure that the device I’m connecting to is: Bus 001 Device 030: ID 1a86:5523 QinHeng Electronics CH341 in serial mode, usb to serial port converter.
I have also tried the following:
$sudo modprobe usbserial vendor=0x1a86 produbt=0x5523
dmesg
Which apparently should return
usbserial_generic 1-1:1.0: generic converter detected
usb 1-1: generic converter now attached to ttyUSB0
usbcore: registered new interface driver usbserial_generic
based on the examples I’ve seen, showing connection to ttyUSB0, but in my case I got:
[ 4534.021812] usb 1-3.1: new full-speed USB device number 30 using xhci-tegra
[ 4534.047806] usb 1-3.1: New USB device found, idVendor=1a86, idProduct=5523
[ 4534.054825] usb 1-3.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Does this mean that I have made a successful connection?
The hardware I’m using is: nvidia jetson tx1
Ubuntu version 16.04
I am able to connect to ttyUSB0 from my laptop to the device, can some one help me with this issues?
Thank you very much!
