I am using CP210x USB-UART bridge and something wrong with usb-serial.
I also found similar question in this forum,but it seems not work for me.
https://devtalk.nvidia.com/default/topic/890599/?comment=4786915
as you can see ,cp210x driver is working fine.
ubuntu@tegra-ubuntu:~$ lsusb
Bus 002 Device 003: ID 05e3:0617 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 018: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 014: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 001 Device 013: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
but /dev/ttyUSB* is not showing.
ubuntu@tegra-ubuntu:~$ ls /dev/tty*
/dev/tty /dev/tty15 /dev/tty22 /dev/tty3 /dev/tty37 /dev/tty44 /dev/tty51 /dev/tty59 /dev/tty9
/dev/tty0 /dev/tty16 /dev/tty23 /dev/tty30 /dev/tty38 /dev/tty45 /dev/tty52 /dev/tty6 /dev/ttyS0
/dev/tty1 /dev/tty17 /dev/tty24 /dev/tty31 /dev/tty39 /dev/tty46 /dev/tty53 /dev/tty60 /dev/ttyS1
/dev/tty10 /dev/tty18 /dev/tty25 /dev/tty32 /dev/tty4 /dev/tty47 /dev/tty54 /dev/tty61 /dev/ttyS2
/dev/tty11 /dev/tty19 /dev/tty26 /dev/tty33 /dev/tty40 /dev/tty48 /dev/tty55 /dev/tty62 /dev/ttyS3
/dev/tty12 /dev/tty2 /dev/tty27 /dev/tty34 /dev/tty41 /dev/tty49 /dev/tty56 /dev/tty63 /dev/ttyTHS0
/dev/tty13 /dev/tty20 /dev/tty28 /dev/tty35 /dev/tty42 /dev/tty5 /dev/tty57 /dev/tty7 /dev/ttyTHS1
/dev/tty14 /dev/tty21 /dev/tty29 /dev/tty36 /dev/tty43 /dev/tty50 /dev/tty58 /dev/tty8 /dev/ttyTHS2
here is kernel message
ubuntu@tegra-ubuntu:~$ uname -r
3.10.40-wifiUVC
ubuntu@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 3.10.40-wifiUVC #1 SMP PREEMPT Thu Jan 21 13:43:16 UTC 2016 armv7l armv7l armv7l GNU/Linux
Thanks for someone who responds me :)
