I develop custom camera porting in Jetson Tx2 board.
custom sensor slave address : 0x20
I am testing by modifying the ov5693 device driver.
I2C communication is not working.
i2cdetect It looks like you read some data like the message below.
jpchae@jpchae-desktop:~/Downloads$ sudo i2cdetect -y -r 2
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: 10 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
dmesg message is shown below.
[ 840.443150] tegra-i2c 3180000.i2c: no acknowledge from address 0x3
I checked for a hardware connection problem.
pwdn-gpio, reset-gpio high / low operation check is okay
scl-gpio Oscilloscope to check 8-bit clock generating is okay
sda-gpio Oscilloscope to check 8-bit data signal is okay
I have also lowered the speed of the i2c clock.
i2cset and i2cget commands give an error. (The symptoms are the same for the ov5693 camera.)
jpchae@jpchae-desktop:~/Downloads$ sudo i2cset -f -y 2 0x20 0x01 0x00
Error: Write failed
jpchae@jpchae-desktop:~/Downloads$ sudo i2cget -f -y 2 0x20
Error: Read failed
This test hardware confirms that it works on the evm board for camera testing, and attempts to connect to jetson tx2.
Where should I check?
Please let me know if there is a way to test the operation of i2C in device driver separately.
