Hi all,
i’m getting messages about i2c devices not responding:
[ 1699.161350] tegra-i2c c240000.i2c: no acknowledge from address 0x1c
[ 1699.167927] tegra-i2c c240000.i2c: no acknowledge from address 0x1d
I have i2c access from user space , using imu with rtimulib with no issues.
running sudo i2cdetect -y -r 0 shows ‘UU’ on address 40h,41h,42h,42h,75h,77h
same command on i2c bus 1 shows proper IMU address
I assume the 2 devices are related to the dev board?
hello moshe.eliyahu,
in general, you may not provide correct power regulator of your customize device.
may I know what’s these two devices, please review the specification and given correct settings.
thanks
the real question should of been on r32.3.1 TX2 how do I turn off the i2c debugging messages.
kayccc
March 3, 2020, 3:21am
4
Hi terrysu50z,
Thanks for the comments, please continue following up those topics you opened, don’t spend time on those old topics and none related.
