I just received my Nvidia jetson TX2 and have been trying to use it. When I connect to the internet over wifi, the internet works as expected. However when I connect to it over an ethernet connection, only non-HTTPS sites seem to work. In addition, I can reliably ssh into my jetson via its Wifi address, but not over its ethernet address. However ifconfig reports that both interfaces are up and running correctly with zero dropped packets and they are in the correct subnet range for my router.
Here is a video:
Here is the output of ifconfig, with the wifi off:
docker0 Link encap:Ethernet HWaddr 02:42:e0:da:a8:63
inet addr:172.17.0.1 Bcast:0.0.0.0 Mask:255.255.0.0
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
eth0 Link encap:Ethernet HWaddr 00:04:4b:c5:80:2a
inet addr:192.168.0.28 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::1c62:58a6:e75:ae82/64 Scope:Link
inet6 addr: 2607:fea8:1cdf:f227:f67:1b16:4846:445e/64 Scope:Global
inet6 addr: 2607:fea8:1cdf:f227:fd5f:7152:52e4:d0e1/64 Scope:Global
inet6 addr: fd00:f81d:fa2:b142:64d2:f544:3a04:f563/64 Scope:Global
inet6 addr: 2607:fea8:1cdf:f227::6/128 Scope:Global
inet6 addr: fd00:f81d:fa2:b142:fd5f:7152:52e4:d0e1/64 Scope:Global
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:35995 errors:0 dropped:0 overruns:0 frame:0
TX packets:15383 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:46448825 (46.4 MB) TX bytes:1577389 (1.5 MB)
Interrupt:42
l4tbr0 Link encap:Ethernet HWaddr ca:a1:b8:24:0a:66
inet addr:192.168.55.1 Bcast:192.168.55.255 Mask:255.255.255.0
inet6 addr: fe80::a84b:cff:fe53:afeb/64 Scope:Link
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1003 (1.0 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:2016 errors:0 dropped:0 overruns:0 frame:0
TX packets:2016 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:181128 (181.1 KB) TX bytes:181128 (181.1 KB)
usb0 Link encap:Ethernet HWaddr ca:a1:b8:24:0a:66
usb1 Link encap:Ethernet HWaddr fa:58:21:87:7e:4e
wlan0 Link encap:Ethernet HWaddr 00:04:4b:c5:80:28
RX packets:7542 errors:0 dropped:0 overruns:0 frame:0
TX packets:6723 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4039199 (4.0 MB) TX bytes:1269025 (1.2 MB)
Here is the output of ethtool eth0:
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Link detected: yes
