I am hoping you could advise why I am unable to to get record working on I2S1 via an AK4642 codec module. Playback is working fine on I2S1 to the same AK4642 slave codec, but when recording, I see that the master audio clock is enabled, but no bit clock / sample clock is generated by the I2S1 interface. Since the codec is configured as a slave, I need those clocks for the record.
I attach my record script, and the output from that script when I run it.
The error I am seeing, is as I have seen on other forum posts:
arecord: pcm_read:2103: read error: Input/output error
using dmesg, I can also see the error:
[ 200.446385] ================ak4642_set_mcko===============
[ 200.446397] ak4642: frequency = 12288000
[ 200.548885] tegra210-i2s tegra210-i2s.0: Failed at I2S0_RX sw reset
[ 200.555161] tegra210-i2s tegra210-i2s.0: ASoC: PRE_PMU: I2S1 DAP RX event failed: -22
The debug trace I think shows that the routing looks OK.
I also attach my edited device tree files.
When I run the record script, I can see that master audio clock is enabled, but I do not see the bit and sample clocks active on the I2S1 bus.
Please could you give me some hints of what to check to get the record process working?
many thanks
Dom
rec_i2s1.sh (513 Bytes) rec_i2s1_output.txt (27.3 KB)
tegra186-quill-common.dtsi (32.5 KB) tegra186-quill-p3310-1000-a00-00-base.dts (8.2 KB) tegra186-quill-p3310-1000-c03-00-base.dts (10.0 KB)
