@JerryChang , my issue seems different, as it is in program stage. Here is the log:
ROOTFS_ENC=1 EXT_NUM_SECTORS=976773168 ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --no-flash --external-device nvme0n1p1 -S 160GiB -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml --external-only --network usb0 jetson-xavier-nx-devkit-tx2-nx external
./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
last lines of logs says
Active index file is /mnt/external/flash.idx
Number of lines is 16
max_index=15
writing item=1, 9:0:primary_gpt, 512, 19968, gpt_primary_9_0.bin, 16896, fixed-<reserved>-0, 9308a9d059290c808a4a696eb0e746a33637817d
Writing primary_gpt partition with gpt_primary_9_0.bin
Offset is not aligned to K Bytes, no optimization is applied
dd if=/mnt/external/gpt_primary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=512 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.329022 s, 51.4 kB/s
Writing primary_gpt partition done
Error: The backup GPT table is corrupt, but the primary appears OK, so that will be used.
Warning: Not all of the space available to /dev/nvme0n1 appears to be used, you can fix the GPT to use all of the space (an extra 976751999 blocks) or continue with the current setting?
Writing secondary_gpt partition with gpt_secondary_9_0.bin
dd if=/mnt/external/gpt_secondary_9_0.bin of=/dev/nvme0n1 bs=1 skip=0 seek=500107845120 count=16896
16896+0 records in
16896+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.281062 s, 60.1 kB/s
Writing secondary_gpt partition done
Error: The backup GPT table is not at the end of the disk, as it should be. Fix, by moving the backup to the end (and removing the old backup)?
Fix/Ignore? Fix
Fix/Ignore? Fix
Model: WD_BLACK SN770 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 20.5kB 419MB 419MB ext4 APP msftdata
2 419MB 42.9GB 42.5GB APP_ENC msftdata
3 42.9GB 85.5GB 42.5GB APP_ENC_b msftdata
4 85.5GB 85.5GB 66.1MB recovery msftdata
5 85.5GB 85.5GB 524kB recovery-dtb msftdata
6 85.5GB 85.5GB 65.5kB kernel-bootctrl msftdata
7 85.5GB 85.5GB 65.5kB kernel-bootctrl_b msftdata
8 85.5GB 85.6GB 83.9MB kernel msftdata
9 85.6GB 85.7GB 83.9MB kernel_b msftdata
10 85.7GB 85.7GB 524kB kernel-dtb msftdata
11 85.7GB 85.7GB 524kB kernel-dtb_b msftdata
12 85.7GB 85.8GB 105MB RECROOTFS msftdata
13 85.8GB 500GB 414GB UDA msftdata
[ 3]: l4t_flash_from_kernel: Expanding last partition to fill the storage device
[ 3]: l4t_flash_from_kernel: Successfully create gpt for external device
[ 3]: l4t_flash_from_kernel: Starting to flash to external device
max_index=15
writing item=0, 9:0:master_boot_record, 0, 512, mbr_9_0.bin, 512, fixed-<reserved>-0, 694898d1c345bdb31b377790ed7fc0b0db184bf7
writing item=2, 9:0:APP, 20480, 419430400, , , fixed-<reserved>-1,
Formatting APP partition /dev/nvme0n1p1 ...
mke2fs 1.44.1 (24-Mar-2018)
Discarding device blocks: done
Creating filesystem with 409600 1k blocks and 102400 inodes
Filesystem UUID: 8e8307af-d973-48f8-a207-9b67e4de65e2
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
Formatting APP parition done
tar --xattrs -xpf /mnt/external/system_boot.img --checkpoint=10000 --warning=no-timestamp --numeric-owner -C /tmp/ci-gZWGfNQNnL
writing item=3, 9:0:APP_ENC, 419450880, 42530242560, system_root_encrypted.img_ext, 13919892112, fixed-<reserved>-2,
Writing APP_ENC partition with system_root_encrypted.img_ext
Get size of partition through connection.
blkdiscard /dev/nvme0n1p2
[ 8]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
[ 8]: l4t_flash_from_kernel: Error: /mnt/internal/flash.idx is not found
[ 8]: l4t_flash_from_kernel: ERROR simg2img not found! To install - please run: "sudo apt-get install simg2img" or "sudo apt-get install android-tools-fsutils"
[ 8]: l4t_flash_from_kernel: Error flashing qspi
[ 8]: l4t_flash_from_kernel: Error flashing external device
Cleaning up...
It looks to program the NVME device, but show this error, may I know what could be wrong? I tried without APP_ENC_b, that is same thing.
