I am attempting to run the minimal example found here example
I compiled with this cmakelist:
cmake_minimum_required(VERSION 3.1)
project(test_inference LANGUAGES CUDA CXX)
find_package(OpenCV 4.4 REQUIRED)
set(CUDADIR /usr/local/cuda-10.2/targets/aarch64-linux/include)
include_directories(${OpenCV_INCLUDE_DIRS} ${CUDADIR})
find_package(CUDA 10.2 REQUIRED)
add_executable(main test-jetson-utils-opencv.cpp)
target_link_libraries(main ${OpenCV_LIBS} ${CUDA_LIBRARIES} jetson-inference jetson-utils nvinfer nvinfer_plugin nvcaffe_parser)
The program compiles and runs. Based on the output the videooutput and videosource open and launch however the video source fails at the first frame test. Any clues on where I should look? Is it a compilation/linking difference between video-viewer and the test example?
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
[gstreamer] gstCamera -- onPreroll
[gstreamer] gstCamera -- map buffer size was less than max size (3110400 vs 3110407)
[gstreamer] gstCamera recieve caps: video/x-raw, width=(int)1920, height=(int)1080, framerate=(fraction)30/1, format=(string)NV12
[gstreamer] gstCamera -- recieved first frame, codec=raw format=nv12 width=1920 height=1080 size=3110407
Error: failed to capture first video frame
[gstreamer] gstCamera -- stopping pipeline, transitioning to GST_STATE_NULL
RingBuffer -- allocated 4 buffers (3110407 bytes each, 12441628 bytes total)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
[gstreamer] gstreamer message async-done ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> mysink
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> pipeline0
GST_ARGUS: Cleaning up
(main:29535): GStreamer-CRITICAL **: 08:49:29.755: gst_mini_object_set_qdata: assertion 'object != NULL' failed
CONSUMER: Done Success
GST_ARGUS: Done Success
[gstreamer] gstCamera -- pipeline stopped
