We are trying to port some Python code from a Raspberry Pi to Jetson TX1 (24.1 64bit). We have the devkit camera and a USB camera working from command line using gstreamer.
gst-launch-1.0 v4l2src device="/dev/video1" ! ‘video/x-raw, width=640, height=480, format=(string)I420’ ! videoconvert ! ximagesink
gst-launch -v nvcamerasrc fpsRange=“30.0 30.0” ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1’ ! nvvidconv flip-method=2 tnr=6 ! ‘video/x-raw, width=(int)1920, height=(int)1080, format=(string)BGRx’ ! tee name=tp tp. ! queue max-size-buffers=2 ! ximagesink name=highres tp. ! queue max-size-buffers=2 ! videocrop left=240 right=240 ! videoscale ! ‘video/x-raw, width=(int)640, height=(int)480, format=(string)BGRx, pixel-aspect-ratio=(fraction)1/1’ ! ximagesink name=lowres
Frame rates are marginal and would like to use the opencv4tegra acceleration (not to excited about moving to OpenCV3.1). Seems acc not realistic for USB and we could not get nvtee to split the stream correctly. Ideas on nvtee would be welcome but not the main issue.
The old code used a USB camera, so we would like to get that working first. The following seems to connect to the camera, but we dont know how to link the gst-pipe into openCV.
# copied from https://gist.github.com/jampekka/ec4a3f3a3748fd2a281d/
import numpy as np
import cv2
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst
# This doesn't seem to make any difference
#GObject.threads_init()
Gst.init(None)
# This works
pipe = Gst.parse_launch("""v4l2src device=/dev/video1 !
appsink sync=false max-buffers=2 drop=true name=sink emit-signals=true""")
sink = pipe.get_by_name('sink')
pipe.set_state(Gst.State.PLAYING)
while True:
print "Getting a sample"
sample = sink.emit('pull-sample')
print sample.get_buffer().get_size()
The following fails to open the camera:
** (cam.py:8145): WARNING **: Couldn’t connect to accessibility bus: Failed to connect to socket /tmp/dbus-HmKP8cTCj6: Connection refused
2016-08-02 13:41:31,340 - ERROR - Camera Open Failed
import numpy as np
import cv2
import sys
import gi
from gi.repository import GObject, Gtk
from gi.repository import Gst as gst
#from gi.repository import GdkX11, GstVideo
gst.init(None)
#mygstpipe = gst.Pipeline()
import logging
logging.basicConfig(level=logging.DEBUG, format='%(asctime)s - %(levelname)s - %(message)s')
mycam = cv2.VideoCapture("v4l2src device='/dev/video1' ! 'video/x-raw, width=1280, height=720, format=I420' ! videoconvert ! appsink sync=false max-buffers=2 drop=true name=sink emit-signals=true")
#mycam = cv2.VideoCapture("nvcamerasrc ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)I420, framerate=(fraction)30/1' ! nvvidconv flip-method=2 ! 'video/x-raw, format=(string)BGRx' ! videoconvert ! appsink")
if mycam.isOpened():
rval, frame = mycam.read()
logging.info('Hit ESC to close')
else:
rval = False
logging.error('Camera Open Failed')
while rval:
cv2.imshow("feed", frame)
key = cv2.waitKey(20)
if key == 27: # exit on ESC
break
cv2.destroyWindow("feed")
Thoughts on where to go next?
