Jetson nanoでNiceHash Minerを試すHPをみてJetson Xavier NXでも動かせないか試そうとしていますが
$ sudo apt install git
$ cd
$ git clone -b linux GitHub - tpruvot/ccminer: CUDA Open Source miner project, for most nvidia cards
$ cd ccminer
$ ./build.sh
ここまで入力後に
In file included from ./crt/host_config.h:60:0,
from ./crt/host_config.h:60,
from ./cuda_runtime.h:100,
from ccminer.cpp:49:
./crt/host_defines.h:60:30: error: #include nested too deeply
#include “crt/host_defines.h”
util.cpp: In function ‘bool stratum_benchdata(json_t*, json_t*, int)’:
util.cpp:1697:21: error: ‘gpu_power’ was not declared in this scope
cgpu->gpu_power = gpu_power(cgpu); // mWatts
util.cpp:1700:2: error: ‘gpu_info’ was not declared in this scope
gpu_info(cgpu); // vid/pid
util.cpp:1700:2: note: suggested alternative: ‘cgpu_info’
cgpu_info
Makefile:1894: recipe for target ‘ccminer-util.o’ failed
make[2]: *** [ccminer-util.o] Error 1
make[2]: *** 未完了のジョブを待っています…
In file included from ./builtin_types.h:56:0,
from ./cuda_runtime.h:91,
./device_types.h:66:6: error: use of enum ‘device_builtin’ without previous declaration
enum device_builtin cudaRoundMode
./device_types.h:68:5: error: ‘cudaRoundNearest’ was not declared in this scope
cudaRoundNearest,
./device_types.h:68:5: note: suggested alternative: ‘cudaRoundMode’
cudaRoundNearest,
cudaRoundMode
./device_types.h:69:5: error: ‘cudaRoundZero’ was not declared in this scope
cudaRoundZero,
./device_types.h:69:5: note: suggested alternative: ‘cudaRoundMode’
cudaRoundZero,
cudaRoundMode
./device_types.h:70:5: error: ‘cudaRoundPosInf’ was not declared in this scope
cudaRoundPosInf,
./device_types.h:70:5: note: suggested alternative: ‘cudaRoundMode’
cudaRoundPosInf,
cudaRoundMode
./device_types.h:71:5: error: ‘cudaRoundMinInf’ was not declared in this scope
cudaRoundMinInf
./device_types.h:71:5: note: suggested alternative: ‘cudaRoundMode’
cudaRoundMinInf
cudaRoundMode
./device_types.h:66:25: error: scalar object ‘cudaRoundMode’ requires one element in initializer
In file included from ./driver_types.h:59:0,
from ./builtin_types.h:59,
./vector_types.h:98:27: error: variable ‘device_builtin char1’ has initializer but incomplete type
struct device_builtin char1
./vector_types.h:100:5: error: expected primary-expression before ‘signed’
signed char x;
./vector_types.h:100:5: error: expected ‘}’ before ‘signed’
./vector_types.h:100:5: error: expected ‘,’ or ‘;’ before ‘signed’
./vector_types.h:101:1: error: expected declaration before ‘}’ token
Makefile:1866: recipe for target ‘ccminer-ccminer.o’ failed
make[2]: *** [ccminer-ccminer.o] Error 1
mv -f .deps/ccminer-hefty1.Tpo .deps/ccminer-hefty1.Po
mv -f .deps/ccminer-pools.Tpo .deps/ccminer-pools.Po
make[2]: ディレクトリ ‘/home/yukio/ccminer’ から出ます
Makefile:2292: recipe for target ‘all-recursive’ failed
make[1]: *** [all-recursive] Error 1
make[1]: ディレクトリ ‘/home/yukio/ccminer’ から出ます
Makefile:693: recipe for target ‘all’ failed
make: *** [all] Error 2
となってしまいます。…同じエラーが続くので同じものは省かせてもらいました。
個別にファイルの配置が関係するのかと思いますが解決策などありますでしょうか?
