Jetson Xavier Nx - Cuda toolkit
Hi guys, I have Jetson Xavier Nx. I’m working on a project that using Yolo. My program need Torch & Torchvision . I already installed torch>=1.7.0, torchvision>=0.8.1
but when I run torch.cuda.is_Available() is returning False. Older Cuda versions working fine but I need 1.7.0 or newer versions.
How could you help me?
Hi @hisisman3, if you installed PyTorch/torchvision from pip (or if installing a yolo package from pip pulled those in as dependencies), then the torch wheels from PyPi aren’t built with CUDA enabled. These PyTorch wheels were built with CUDA enabled:
There are also instructions in that post for building torchvision with CUDA. First you should pip3 uninstall torch torchvision to remove the versions that don’t have GPU acceleration.
(moving this post to the Xavier NX forum)
