We are conducting long-term running tests, and a system restart occurred midway. The serial port output is as follows:
Ubuntu 22.04.5 LTS ubuntu ttyTCU0
ubuntu login:
[239203.910187] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: ivc channel driver missing
[239203.910195] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: ivc channel driver missing
[239203.910200] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: ivc channel driver missing
[239203.910206] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: ivc channel driver missing
[239205.147100] nvgpu: 17000000.gpu pmu_wait_message_cond:664 [ERR] PMU wait timeout expired.
[239205.147108] nvgpu: 17000000.gpu pmu_wait_message_cond:664 [ERR] PMU wait timeout expired.
[239205.147745] nvgpu: 17000000.gpu ga10b_intr_log_pending_intrs:306 [ERR] Pending TOP[0]: 0x00000004, LEAF[4]: 0x11000000
[239205.149087] arm-smmu 12000000.iommu: disabling translation
[239205.149208] arm-smmu 10000000.iommu: disabling translation
[239205.149258] arm-smmu 8000000.iommu: disabling translation
[239205.149473] reboot: Restarting system
?Neodymiumhutdown state requested 1
Rebooting system…
[0000.061] I> MB1 (version: 1.4.0.4-t234-54845784-e89ea9bc)
[0000.066] I>t234-A01-1-Silicon (0x12347) Prod
[0000.070] I>Boot-mode: Coldboot
[0000.073] I> Entry timestamp: 0x00000000
[0000.077] I>last_boot_error: 0x0
[0000.080] I> BR-BCT: preprod_dev_sign: 0
[0000.084] I> rst_source: 0xb, rst_level: 0x1
[0000.088] I> Task: SE error check
[0000.091] I> Task: Bootchain select WAR set
[0000.095] I>Task: Enable SLCG
[0000.098] I>Task: CRC check
Please help analyze the reason for the restart
