I train a MobileNetsV1 model with Keras, it generates a .h5 file. And then I put the .h5 model in the Jetson Nano board, and write a predict demo using keras,the predict code runs in the Jetson Nano.When trying to use GPU to speed up the inference, however, it shocks me, it is much slower than CPU only.I can not imagine it! On GPU : 10s , On CPU: 1s.I don’t know why, as we all known, MobileNet is a very very simple and small model.Could someone give me a favor? thanks!
<b><i>MobileNets model summary is as follows:</i></b>
Model: "model_6"
_________________________________________________________________
Layer (type) Output Shape Param #
input_6 (InputLayer) (None, 31, 56, 1) 0
initial_conv (Conv2D) (None, 16, 28, 19) 171
initial_bn (BatchNormalizati (None, 16, 28, 19) 76
initial_act (Activation) (None, 16, 28, 19) 0
block0_dw (DepthwiseConv2D) (None, 16, 28, 19) 171
block0_bn1 (BatchNormalizati (None, 16, 28, 19) 76
block0_act1 (Activation) (None, 16, 28, 19) 0
block0_pw (Conv2D) (None, 16, 28, 38) 722
block0_bn2 (BatchNormalizati (None, 16, 28, 38) 152
block0_act2 (Activation) (None, 16, 28, 38) 0
block1_dw (DepthwiseConv2D) (None, 8, 14, 38) 342
block1_bn1 (BatchNormalizati (None, 8, 14, 38) 152
block1_act1 (Activation) (None, 8, 14, 38) 0
block1_pw (Conv2D) (None, 8, 14, 76) 2888
block1_bn2 (BatchNormalizati (None, 8, 14, 76) 304
block1_act2 (Activation) (None, 8, 14, 76) 0
block2_dw (DepthwiseConv2D) (None, 8, 14, 76) 684
block2_bn1 (BatchNormalizati (None, 8, 14, 76) 304
block2_act1 (Activation) (None, 8, 14, 76) 0
block2_pw (Conv2D) (None, 8, 14, 76) 5776
block2_bn2 (BatchNormalizati (None, 8, 14, 76) 304
block2_act2 (Activation) (None, 8, 14, 76) 0
block3_dw (DepthwiseConv2D) (None, 4, 7, 76) 684
block3_bn1 (BatchNormalizati (None, 4, 7, 76) 304
block3_act1 (Activation) (None, 4, 7, 76) 0
block3_pw (Conv2D) (None, 4, 7, 153) 11628
block3_bn2 (BatchNormalizati (None, 4, 7, 153) 612
block3_act2 (Activation) (None, 4, 7, 153) 0
block4_dw (DepthwiseConv2D) (None, 4, 7, 153) 1377
block4_bn1 (BatchNormalizati (None, 4, 7, 153) 612
block4_act1 (Activation) (None, 4, 7, 153) 0
block4_pw (Conv2D) (None, 4, 7, 153) 23409
block4_bn2 (BatchNormalizati (None, 4, 7, 153) 612
block4_act2 (Activation) (None, 4, 7, 153) 0
block5_dw (DepthwiseConv2D) (None, 2, 4, 153) 1377
block5_bn1 (BatchNormalizati (None, 2, 4, 153) 612
block5_act1 (Activation) (None, 2, 4, 153) 0
block5_pw (Conv2D) (None, 2, 4, 307) 46971
block5_bn2 (BatchNormalizati (None, 2, 4, 307) 1228
block5_act2 (Activation) (None, 2, 4, 307) 0
block6_dw (DepthwiseConv2D) (None, 2, 4, 307) 2763
block6_bn1 (BatchNormalizati (None, 2, 4, 307) 1228
block6_act1 (Activation) (None, 2, 4, 307) 0
block6_pw (Conv2D) (None, 2, 4, 307) 94249
block6_bn2 (BatchNormalizati (None, 2, 4, 307) 1228
block6_act2 (Activation) (None, 2, 4, 307) 0
block7_dw (DepthwiseConv2D) (None, 2, 4, 307) 2763
block7_bn1 (BatchNormalizati (None, 2, 4, 307) 1228
block7_act1 (Activation) (None, 2, 4, 307) 0
block7_pw (Conv2D) (None, 2, 4, 307) 94249
block7_bn2 (BatchNormalizati (None, 2, 4, 307) 1228
block7_act2 (Activation) (None, 2, 4, 307) 0
block8_dw (DepthwiseConv2D) (None, 1, 2, 307) 2763
block8_bn1 (BatchNormalizati (None, 1, 2, 307) 1228
block8_act1 (Activation) (None, 1, 2, 307) 0
block8_pw (Conv2D) (None, 1, 2, 614) 188498
block8_bn2 (BatchNormalizati (None, 1, 2, 614) 2456
block8_act2 (Activation) (None, 1, 2, 614) 0
block9_dw (DepthwiseConv2D) (None, 1, 1, 614) 5526
block9_bn1 (BatchNormalizati (None, 1, 1, 614) 2456
block9_act1 (Activation) (None, 1, 1, 614) 0
block9_pw (Conv2D) (None, 1, 1, 614) 376996
block9_bn2 (BatchNormalizati (None, 1, 1, 614) 2456
block9_act2 (Activation) (None, 1, 1, 614) 0
global_avg (GlobalAveragePoo (None, 614) 0
softmax (Dense) (None, 4) 2460
Total params: 885,323
Trainable params: 875,895
Non-trainable params: 9,428
<b><i>The inference code is below (use CPU).</i></b>
from PIL import Image
import keras
from keras import models
#from keras.utils.generic_utils import CustomObjectScope
import numpy as np
import time
import os
import tensorflow as tf
import keras.backend.tensorflow_backend as KTF
os.environ["CUDA_VISIBLE_DEVICES"] = "1"# use CPU only
config = tf.ConfigProto()
config.gpu_options.allow_growth=True
# config.gpu_options.per_process_gpu_memory_fraction = 0.8
sess = tf.Session(config=config)
KTF.set_session(sess)
width = 56
height = 31
imagesArrayList = []
#with CustomObjectScope({'relu6': keras.applications.mobilenet.relu6,'DepthwiseConv2D': keras.applications.mobilenet.DepthwiseConv2D}):
print('Loading model......')
model = models.load_model('my_model2_0.6_31_56.h5')
model.summary()
print('Load successful!')
#open camera
start = time.time()
image = Image.open('0.jpg')
image = image.resize((width, height))
imageArray = np.array(image)
imageArray = np.reshape(imageArray, (height, width, 1))
imageArray = imageArray.astype('float32')/255
imagesArrayList.append(imageArray)
imageData = np.array(imagesArrayList)
result = model.predict(imageData)
end = time.time()
label = np.argmax(result)
print(str(end-start)+'s')
print('label:', label)
<b><i>the CPU inference spends 1.417342185974121s ,output is below:</i></b>
Load successful!
1.417342185974121s
label: 1
<i><b>In contrast,os.environ["CUDA_VISIBLE_DEVICES"] is changed to be '0' for GPU inference</b></i>
<b>some tensorflow log is as follws:</b>
2019-11-02 22:52:44.860485: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-11-02 22:52:44.863771: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-11-02 22:52:44.866540: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcufft.so.10.0
2019-11-02 22:52:44.867401: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcurand.so.10.0
2019-11-02 22:52:44.871384: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusolver.so.10.0
2019-11-02 22:52:44.878644: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcusparse.so.10.0
2019-11-02 22:52:44.888082: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-11-02 22:52:44.888394: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-11-02 22:52:44.888803: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-11-02 22:52:44.888921: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1763] Adding visible gpu devices: 0
2019-11-02 22:52:44.889047: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudart.so.10.0
2019-11-02 22:52:46.082811: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1181] Device interconnect StreamExecutor with strength 1 edge matrix:
2019-11-02 22:52:46.082895: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1187] 0
2019-11-02 22:52:46.082932: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1200] 0: N
2019-11-02 22:52:46.083331: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-11-02 22:52:46.083645: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:972] ARM64 does not support NUMA - returning NUMA node zero
2019-11-02 22:52:46.083833: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1326] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 1600 MB memory) -> physical GPU (device: 0, name: NVIDIA Tegra X1, pci bus id: 0000:00:00.0, compute capability: 5.3)
Loading model......
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/keras/backend/tensorflow_backend.py:422: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
Load successful!
2019-11-02 22:53:12.755127: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcublas.so.10.0
2019-11-02 22:53:13.395678: I tensorflow/stream_executor/platform/default/dso_loader.cc:42] Successfully opened dynamic library libcudnn.so.7
2019-11-02 22:53:21.320321: W tensorflow/core/common_runtime/bfc_allocator.cc:237] Allocator (GPU_0_bfc) ran out of memory trying to allocate 831.15MiB with freed_by_count=0. The caller indicates that this is not a failure, but may mean that there could be performance gains if more memory were available.
10.121127605438232s
label: 1
<i><b>the GPU inference spends 10.121127605438232s ,output is above.</b></i>
