Keras vgg16 model to try/engine
his @Morganh
I am having a trained Classification model VGG16 … which I have trained in keras. its extension is .h5.
How can I convert it into .trt or .engine file so that I can use it on Jetson Nano for running predictions.
Any help will be appreciable?
thanks
Please run TLT classification network. Set it as the pretrained model.
Then get tlt model and etlt model, and use tlt-converter to generate trt engine.
ok thanks I can try this .
@Morganh
it throws error
NotImplementedError: Invalid model file extension. /workspace/tlt-experiments/classification/pretrained_resnet18/tlt_pretrained_classification_vvgg16/vgg_16.h5
do I need to rename the extension as .hdf5 from vgg_16.h5.
is it the right way ?
thanks
Officially TLT provides the pretrained model in Transfer Learning Toolkit — Transfer Learning Toolkit 3.0 documentation
For your case, you can can rename it to .hdf5 and retry.
@Morganh
Any clue about this .
at the time of training in keras
keras version is 2.4.3
and tensorflow version is 2.4.1
tried but did not get any solution for this .
thanks
So, your pretrained model is not compatible with TLT.
Please use the pretrained models in ngc.
got it thanks .
