Description
How to convert weights.h5 model to weights.engine file.
Kindly give the steps for the same.
Environment
TensorRT Version : 7.0
GPU Type : T4
Nvidia Driver Version : 440
CUDA Version : 10.2
CUDNN Version :
Operating System + Version : 18.04
Python Version (if applicable) :
TensorFlow Version (if applicable) :
PyTorch Version (if applicable) :
Baremetal or Container (if container which image + tag) :
Hi @GalibaSashi ,
You can do the conversion with the below mentioned steps
Keras<< ONNX<< TRT
Please check the below link for Keras to Onnx conversion
I tried but can you give additional steps. Because I could not even load the model let alone convert it to onnx.
It is VGG16 model
Hi @GalibaSashi
Please follow the steps in the below link for the conversion.
since keras2onnx is no longer maintained, the option put foward is tf2onnx… this implementation seems to be finicky.
Do you know if there are any plans to have trt support direct load of tf or h5?
NVES
August 21, 2021, 11:45am
6
Please refer to the below link for Sample guide.
This Samples Support Guide provides an overview of all the supported NVIDIA TensorRT 8.4.3 samples included on GitHub and in the product package. The TensorRT samples specifically help in areas such as recommenders, machine comprehension, character...
Refer to the installation steps from the link if in case you are missing on anything
However suggested approach is to use TRT NGC containers to avoid any system dependency related issues.
In order to run python sample, make sure TRT python packages are installed while using NGC container.
/opt/tensorrt/python/python_setup.sh
In case, if you are trying to run custom model, please share your model and script with us, so that we can assist you better.
