Loading TensorRT Engine from File Failed
I have a neural network that originally wrote in Keras
I converted it to Onnx, and then to TensorRT
FIRST - Keras to Onnx conversion with → GitHub - onnx/keras-onnx: Convert tf.keras/Keras models to ONNX
Installed with pip, the conversion succeeded.
SECOND - Onnx to trt conversion with → GitHub - onnx/onnx-tensorrt: ONNX-TensorRT: TensorRT backend for ONNX
Cloned the repo
To create the engine:
onnx2trt my_model.onnx -o my_engine.trt
To create the txt file: (link to it attached at the end)
onnx2trt my_model.onnx -t my_engine.trt
When trying to load the trt engine I get:
[E] [TRT] (31) - Serialization Error in verifyHeader: 0 (Magic tag does not match)
[E] [TRT] INVALID_STATE: std::exception[E] [TRT] INVALID_CONFIG: Deserialize the cuda engine failed.
The code to load the trt engine is attached below (link to drive)
I updated the keras to onnx converter - installed it from source
pip install -U git+https://github.com/microsoft/onnxconverter-common
pip install -U git+https://github.com/onnx/keras-onnx
FIRST: Convert the Keras model to onnx successfully.
SECOND: Convert Onnx to TRT (engine txt file attached in the link below)
The conversion failed with output:
Input filename: /home/shira/Documents/Projects/EmotionsTrtInfer/models/emotion_model_new.onnx
ONNX IR version: 0.0.6
Opset version: 11
Producer name: keras2onnx
Producer version: 1.7.0
Domain: onnxmltools
Model version: 0
Doc string:
WARNING: ONNX model has a newer ir_version (0.0.6) than this parser was built against (0.0.3).
Writing ONNX model (without weights) as text to /home/shira/Documents/Projects/EmotionsTrtInfer/models/emotion_model_new.txt
Parsing model
While parsing node number 1 [Conv → “convolution_output22”]:
ERROR: /home/shira/Documents/Git/onnx-tensorrt/ModelImporter.cpp:537 In function importModel:
[5] Assertion failed: tensors.count(input_name)
Environment
TensorRT Version 7.0.0:
GPU Type GeForce RTX 2080 Ti:
Nvidia Driver Version 440.33.01:
CUDA Version 10.2:
CUDNN Version 7:
Linux 18.04:
Link contain:
- Load_trt_engine.txt → C++ code to load the engine
- emotion_model_old.txt → engine from first onnx to trt conversion
- emotion_model_new.txt → engine from second onnx to trt conversion
https://drive.google.com/drive/folders/1mLFmsjTXq2fblImAAPty4eggbumrw7zl?usp=sharing
