My problem is simple to explain. I have a structure with some members of different types.
Kernel function receive array of struct as parameter. When launching kernel function I try to change some member(for example cellid) of the struct.
But after I copy that array to host I realize that nothing has been changed.
What the problem may be there?
Kernel:
__global__ void mainCalcCuda(struct Particle* particles, int framenum) {
int idx = blockIdx.x;
particles[idx].cellid = 12; // there is checking correct behaviour of a kernel: Diman
Structure:
extern "C"
struct Particle {
Vector defposition;
inline Particle() { neighbours = new Neighbour[128]; }
Material* material;
int localId;
int globalId;
int objId;
bool isNull;
bool received;
int cellx,celly,cellz;
int cellid; // this parameter I attempt to change in vain
int num_of_neighbours;
Neighbour* neighbours;
Vector position;
Vector velocity;
Vector acceleration;
double mass;
double energy;
double pressure;
double density;
Tensor2Gen tDeformation;
Tensor2Gen tStressDev;
Tensor2Gen tStress;
double deformWork;
double crack;
double state;
double wn;
double c;
double rc;
double h;
double maxMu;
double ro0;
double prevEnergy;
double prevCrack;
double prevPressure;
double prevDeformWork;
double prevDensity;
double prevState;
Vector prevVelocity;
Vector prevPosition;
Tensor2Gen prevTStressDev;
void init(int gId, int lid, int oId, Vector pos, Vector vel, double ah, bool mnull);
void resetNeighbours();
void resetStatus();
void resetPosition();
void newNeighbour(Particle* p);
void setMaterial(Material* mat);
host main:
Particle *device, *host;
int N = ps->getPartNum();
size_t size = N * sizeof(Particle);
cudaMalloc((void **) &device, size);
host = (Particle*) malloc(size);
cudaMemcpy(device, ps->particles, size, cudaMemcpyHostToDevice);
mainCalcCuda <<< N, 1 >>> (device, framenum);
cudaMemcpy(host, device, size, cudaMemcpyDeviceToHost);
for (int i=0; i<N; i++)
cout << host->cellid;
cout << "\n";
host++;
