Kernel level memory leak LT 36.3 / Deepstream 7
Jetson Orin Nano
• DeepStream Version
Deepstream 7
Jetpack 6
• TensorRT Version
libnvinfer-dev 8.6.2.3-1+cuda12.2
nvidia-smi: NVIDIA-SMI 540.3.0 Driver Version: N/A CUDA Version: 12.2
Bug
Our device does inference on roadways, and with the new jetpack and L4T versions, we have noticed that long running processes will continue to grow the kmalloc-128 in the slab memory until failure.
The easiest way to test and reproduce this is to use the deepstream-app config_infer_primary.txt file that is installed with deepstream:
/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_infer_primary.txt
Using a simple mp4 recording of the roadway roughly 1.5 minutes long and looping it through a pretty simple pipeline with the inference configured in the sample file provided above gives roughly 50mb/hour leak on the slab kmalloc-128 as shown by running slabtop.
gst-launch-1.0 multifilesrc location=/home/omnisight/timeless_file.mp4 loop=true ! decodebin ! nvvideoconvert ! mux.sink_0 nvstreammux name=“mux” width=640 height=480 batch-size=1 gpu-id=0 live-source=true ! nvinfer gpu-id=0 unique-id=1 config-file-path=“config_infer_primary.txt” ! progressreport update-freq=1 ! fakesink
We ran this for various hours and the result is always the same… the slab will continue to grow until the system crashes from OOM.
Restarting nvargus-daemon or the gst pipeline does NOT free the memory.
If we take out the nvinfer, the leak does not appear to be there.
Following is the leak progress:
Timestamp,OBJS,ACTIVE,USE,OBJ_SIZE,SLABS,OBJSLAB,CACHE_SIZE,NAME
2024-09-17 22:22:55,83328,82960,99%,0.12K,2604,32,10416K,kmalloc-128
2024-09-17 22:43:37,90816,90595,99%,0.12K,2838,32,11352K,kmalloc-128
2024-09-18 01:44:49,2670272,2670272,100%,0.12K,83446,32,333784K,kmalloc-128
2024-09-18 07:36:32,7803392,7803391,99%,0.12K,243856,32,975424K,kmalloc-128
2024-09-18 15:05:43,14345024,14344804,99%,0.12K,448282,32,1793128K,kmalloc-128
2024-09-18 16:19:38,15423008,15422670,99%,0.12K,481969,32,1927876K,kmalloc-128
Not sure if this is related to:
Is there any support that Nvidia can provide?
Yes. We’ll fix that issue on our next JetPack version. Please stay tuned for the next release.
0001-host1x-fence-Free-the-kzalloc-mem.zip (1018 Bytes)
That definitely fixes the memory leak, slabs haven’t changed in over an hour. Thank you so much!
