DS 5.0.1 memory leak
Facing memory leak while running the default deepstream-app with the default config given with the deepstream: source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt
Also, facing the same issue with the deepstream-test5-app also - on an average the memory leak per minute is approx. 300KB.
Here is the RSS information of the deepstream-app:
Getting RSS details for process: deepstream-app, pid: 2269
1210780, 01:31
1212452, 02:31
1212864, 03:31
1213364, 04:31
1213364, 05:31
1213768, 06:32
1213904, 07:32
1213904, 08:32
1214168, 09:32
1214168, 10:32
1214412, 11:32
1214676, 12:32
1214676, 13:33
1214676, 14:33
1214676, 15:33
1214676, 16:33
1214676, 17:33
1214676, 18:33
1214676, 19:33
1215232, 20:33
1216144, 21:33
1216572, 22:34
Here is the same output for the deepstream-test5-app:
1005900, 00:10
1008896, 01:11
1009300, 02:11
1009864, 03:11
1010568, 04:11
1011504, 05:11
1011264, 06:11
1011360, 07:11
1012336, 08:11
1012464, 09:11
1012796, 10:11
1013396, 11:11
1013564, 12:11
1013876, 13:11
1014588, 14:12
1014468, 15:12
1014948, 16:12
1015236, 17:12
1015356, 18:12
1015764, 19:12
1016004, 20:12
1017208, 21:12
1017608, 22:12
1017816, 23:12
1018448, 24:12
1018808, 25:12
1019444, 26:13
1019924, 27:13
1020212, 28:13
1020548, 29:13
1020452, 30:13
1020884, 31:13
1021052, 32:13
1021388, 33:13
1022108, 34:13
1022292, 35:13
1022484, 36:13
Here is the complete information as applicable to your setup.
• Hardware Platform (Jetson)
Jetson TX2
• DeepStream Version - 5.0.1
5.0.1
• JetPack Version (valid for Jetson only) - 4.4
4.4
• TensorRT Version
• Issue Type( questions, new requirements, bugs) - bugs
bugs
run the deepstream-app with default tx2 config file, here is the command:
$> /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app$ deepstream-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt
Reproed the issue, have created on internal bug to track.
thanks.
Can we have an ETA on the issue? Or any approx timeframe in which the issue can be fixed?
Dev team are working on it, thanks for your patience.
Forgot to mention, I am using RabbitMQ in nvmsgconv.
have you any update about memory leak on deepstream 5.01
The fix will be in next release.
