For one of my projects I am required to connect using BLE a Jetson Orin AGX to a mobile device. Because the end goal is to establish a connection without having to input any pairing codes, on the Orin AGX a NoInputNoOutput agent was registered. After setting up a generic BLE service and advertising it, I used my mobile device and a BLE Scanner app to connect to the Orin. After hitting the connect button on the phone, a pairing system pop-up appeared.
The moment I hit the Pair button on my phone, the Orin encountered a Kernel Panic.
Tools Prerequisites:
iPhone with iOS 16.3.1
BLE Scanner iOS app
Orin AGX/NX with bluetooth adapter and antenna running Jetpack 5.1.1
How to reproduce
Start Orin and make sure the Bluetooth is ON
Create a new terminal window and type sudo dmesg -w - this is used for logging
Create a new terminal window and type the following:
bluetoothctl
agent off
agent NoInputNoOutput
menu advertise
clear
uuids 0x180D
appearance 833
name heart_test
discoverable on
back
advertise on
After typing these commands, the expected output should be the following
Advertising object registered
UUID: Heart Rate(0x180D)
Tx Power: off
LocalName: heart_test
Appearance: Heart Rate Belt (0x0341)
Discoverable: on
Open the BLE Scanner app on the iPhone
Find the Orin device and tap on the ‘Connect’ button
Wait for the connection to establish
When the pairing pop-up appears, tap on “Pair”
Attached you can find the dmesg and the bluetoothctl logs.
We follow your steps and try on AGX-Orin and iPhone.
Confirmed we can’t reproduce your issue.
We can pairing and connect success without kernel panic.
Please try re-flash your AGX-Orin and try again.
Hello! @carolyuu@kayccc I flashed with JP 5.1.1 following instructions from here, nothing else installed after flash and I got the same result as described above. Also I was able to reproduce it with an iPhone running OS 16.1. Remember I encounter the same issue starting with JP 5.1, and this also reproduces on Orin NX modules.
Sometimes the pairing prompt is not shown on iPhone, however after about 40 seconds the same Kernel Panic occurs. Can you help me further investigate this?
Hope you’re all doing well. Just wanted to check if there’s any news on that issue I’ve been having. It’s kind of holding up the project I’m working on at the moment.
Hey @mr.amikid! I am experiencing similar problems when I am trying to establish the connection between an iPhone and my Orin NX device. Did you solve this already?
I am experiencing similar kernel panic issues when trying to connect to a BLE peripheral. Running NVIDIA Jetpack 5.1.1 on my Orin NX and Orin Nano. This problem doesn’t seem to exist on my Xavier AGX.
