Hello!
I need a bit of help on a problem that I’ve been stuck with for a few days.
I’m trying to parallelize a k-means clustering algorithm and the CUDA kernel I wrote gives different results on every run. I’ve tried running it on a smaller dataset and the problem persists.
I’ve looked over this topic, but there isn’t any conclusion on what was the actual problem: https://forums.developer.nvidia.com/t/inconsistent-results-on-every-run/
I ran the code with cuda-memcheck and cuda-gdb and I didn’t see any errors. I’ve also tested the sqDistance function in a separate program to check it’s not the one causing problems, but the results are okay.
I’m new to CUDA so I don’t really have much experience with problems like this.
Do you have any idea on what should I do next to debug this?
Thank you!
Code:
image.txt (2.3 MB)
kmeansclustering.cu (6.2 KB)
#include "stdio.h"
#include <fstream>
#include <iostream>
using namespace std;
#define kmean 10
#define H 300
#define W 300
#define iterations 200
__device__ float sqDistance(float *p1, float *p2) {
return (powf(p1[0] - p2[0], 2) + powf(p1[1] - p2[1], 2) +
powf(p1[2] - p2[2], 2));
__global__ void kmeanKernel(float *pixels, float *cluster_pos,
float *sorteddata_pixels, int *sorteddata_cluster,
float *cluster_meanpoint, int *cluster_hitcount,
int repetition) {
int i = threadIdx.x + blockDim.x * blockIdx.x;
if (i < H * W * 3) {
if (i % 3 == 0) {
float distance;
float bestdistance;
int bestcluster = 0;
distance = INFINITY;
bestdistance = distance;
for (int m = 0; m < 3 * kmean; m = m + 3) {
distance = sqDistance(cluster_pos + m, pixels + i);
if (distance < bestdistance) {
bestcluster = m / 3;
if (repetition == (iterations - 1)) {
sorteddata_pixels[i] = cluster_pos[bestcluster * 3];
sorteddata_pixels[i + 1] = cluster_pos[bestcluster * 3 + 1];
sorteddata_pixels[i + 2] = cluster_pos[bestcluster * 3 + 2];
sorteddata_cluster[i / 3] = bestcluster;
__syncthreads();
cluster_meanpoint[bestcluster * 3] += pixels[i];
cluster_meanpoint[bestcluster * 3 + 1] += pixels[i + 1];
cluster_meanpoint[bestcluster * 3 + 2] += pixels[i + 2];
cluster_hitcount[bestcluster]++;
int main() {
ifstream inputValues("image.txt");
float *host_pixels = 0;
float *host_cluster_pos = 0;
float *host_sorteddata_pixels = 0;
int *host_sorteddata_cluster = 0;
float *host_meanpoint = 0;
int *host_cluster_hitcount = 0;
float *device_pixels = 0;
float *device_cluster_pos = 0;
float *device_sorteddata_pixels = 0;
int *device_sorteddata_cluster = 0;
float *device_meanpoint = 0;
int *device_cluster_hitcount = 0;
host_pixels = (float *)malloc(3 * H * W * sizeof(float));
host_cluster_pos = (float *)malloc(3 * kmean * sizeof(float));
host_sorteddata_pixels = (float *)malloc(3 * H * W * sizeof(float));
host_sorteddata_cluster = (int *)malloc(H * W * sizeof(int));
host_meanpoint = (float *)malloc(3 * kmean * sizeof(float));
host_cluster_hitcount = (int *)malloc(kmean * sizeof(int));
cudaMalloc((void **)&device_pixels, 3 * H * W * sizeof(float));
cudaMalloc((void **)&device_cluster_pos, 3 * kmean * sizeof(float));
cudaMalloc((void **)&device_sorteddata_pixels, 3 * H * W * sizeof(float));
cudaMalloc((void **)&device_sorteddata_cluster, H * W * sizeof(int));
cudaMalloc((void **)&device_meanpoint, 3 * kmean * sizeof(float));
cudaMalloc((void **)&device_cluster_hitcount, kmean * sizeof(int));
for (int i = 0; i < 3 * H * W; ++i) {
inputValues >> host_pixels[i];
inputValues.close();
// Asign random values to start the iteration
for (int i = 0; i < 3 * kmean; i = i + 3) {
host_cluster_pos[i] = host_pixels[i];
host_cluster_pos[i + 1] = host_pixels[i + 1];
host_cluster_pos[i + 2] = host_pixels[i + 2];
int block_size = 1024;
int blocks_no = 3 * H * W / block_size;
if (3 * H * W % block_size)
++blocks_no;
int repetition = 0;
printf("Blocks no, Blocks size: %d, %d\n", blocks_no, block_size);
cudaMemcpy(device_pixels, host_pixels, 3 * H * W * sizeof(float),
cudaMemcpyHostToDevice);
while (repetition < iterations) {
repetition++;
cudaMemcpy(device_cluster_pos, host_cluster_pos, 3 * kmean * sizeof(float),
cudaMemcpy(device_meanpoint, host_meanpoint, 3 * kmean * sizeof(float),
cudaMemcpy(device_cluster_hitcount, host_cluster_hitcount,
kmean * sizeof(int), cudaMemcpyHostToDevice);
kmeanKernel<<<blocks_no, block_size>>>(
device_pixels, device_cluster_pos, device_sorteddata_pixels,
device_sorteddata_cluster, device_meanpoint, device_cluster_hitcount,
repetition);
cudaDeviceSynchronize();
// printf("\n Error msg: %s \n", cudaGetErrorString(cudaGetLastError()));
cudaMemcpy(host_cluster_pos, device_cluster_pos, 3 * kmean * sizeof(float),
cudaMemcpyDeviceToHost);
cudaMemcpy(host_meanpoint, device_meanpoint, 3 * kmean * sizeof(float),
cudaMemcpy(host_cluster_hitcount, device_cluster_hitcount,
kmean * sizeof(int), cudaMemcpyDeviceToHost);
// The position is now the mean and the other parameters are restored
if (host_cluster_hitcount[m / 3] == 0) {
// If no hit, then assign random value again
host_cluster_pos[m] = host_pixels[m];
host_cluster_pos[m + 1] = host_pixels[m + 1];
host_cluster_pos[m + 2] = host_pixels[m + 2];
// Doing the mean of the meanpoint which contains the sum of all the hit
// coordinates
host_cluster_pos[m] = host_meanpoint[m] / (host_cluster_hitcount[m / 3]);
host_meanpoint[m + 1] / (host_cluster_hitcount[m / 3]);
host_meanpoint[m + 2] / (host_cluster_hitcount[m / 3]);
printf("%d | %1.6f %1.6f %1.6f | %d\n", m / 3, host_meanpoint[m],
host_meanpoint[m + 1], host_meanpoint[m + 2],
// Restoring hit and meanpoint
host_meanpoint[m] = 0;
host_meanpoint[m + 1] = 0;
host_meanpoint[m + 2] = 0;
host_cluster_hitcount[m / 3] = 0;
cudaMemcpy(host_sorteddata_pixels, device_sorteddata_pixels,
3 * H * W * sizeof(float), cudaMemcpyDeviceToHost);
cudaMemcpy(host_sorteddata_cluster, device_sorteddata_cluster,
H * W * sizeof(int), cudaMemcpyDeviceToHost);
free(host_pixels);
free(host_cluster_pos);
free(host_sorteddata_pixels);
free(host_sorteddata_cluster);
free(host_meanpoint);
free(host_cluster_hitcount);
cudaFree(device_pixels);
cudaFree(device_cluster_pos);
cudaFree(device_sorteddata_pixels);
cudaFree(device_sorteddata_cluster);
cudaFree(device_meanpoint);
cudaFree(device_cluster_hitcount);
