Kernel Silent Crash Due to condition
I have a kernel that performs an optimization function. I calculate a vallue F with copy&pasted code from the CUDA Documentation for Parallel Prefix Sums with Bank Offset. This works fine. I applied this all over my work.
My optimization kernel produced no results without throwing an error so I tried to debug as good as it was possible with this attrocious GPU programming…
I forced the output to be black and white stripes rigth after starting the kernel with
out[index] = 65000;
out[index2] = 0.5f;
return;
which also worked fine. Then I moved these instruction further down in my code and found out that some conditions caused the kernel to just stop executing. Some things i was able to fix by transforming conditions in 0’s and 1’s and use them as arithmetic weights.
Here is my problem:
gamma = top / (bottom + 1);
ushort check =  (ushort)(F > epsilon);
out[index] = 65000;
out[index2] = 0.5f;
return;
Produces black and white stripes as output but when I modify it to:
ushort check =  (ushort)(F > epsilon) * (ushort)(gamma != 0);
out[index] = 65000;
out[index2] = 0.5f;
return;
It doesnt do anything. No stripes visible. So my conclusion is that “(ushort)(gamma != 0);” breaks this kernel and I have no idea why. The same kernel was working a week ago perfectly.
And how in the world can a simple condition stops the entire kernel without even throwing an error?
CUDA doesn’t throw errors. kernel execution errors are entirely invisible unless you make them visible.
Are you doing proper CUDA error checking? Have you run your code with cuda-memcheck ?
