Hi, jinshiksung
Is your issue can also be reproduced with the sample shared by terpysk?
Hi, jinshiksung
The onnx version works. Tensorrt version is still not working and is slow
I like to make run it on Tensorrt c++ jetpack to see it run faster as original question
otherwise no point
Please help me to run it on Tensorrt c++ jetpack
Did you get the correct ONNX result in C++ as well?
As shared above, we can get the correct output after applying the post-processing in the YOLOp repository.
To run the model in C++, you will need a C++ post-processing implementation as well.
Do you have the implementation already?
