When i test the demo in /usr/src/tensorrt/samples/python/yolov3_onnx, got errors as follows
Reading engine from file yolov3.trt
and i have set up virtual memory,but it doesn’t work.
Hi niuniu_niu1,
Do you follow the steps shared in our document?
https://docs.nvidia.com/deeplearning/sdk/tensorrt-sample-support-guide/index.html#yolov3_onnx
This is a know issue.
The default workspace size it too big for Jetson platform.
Please decrease the number from 1G into 256Mb with the comment here:
https://devtalk.nvidia.com/default/topic/1052153/jetson-nano/tensorrt-backend-for-onnx-on-jetson-nano/post/5349962/#5349962
it doesn’t work on jetson TX2
Thanks for your feedback.
We will check this and update more information with you asap.
We can run the sample without any issue.
Here is some update for your reference:
1. Make sure your onnx is v1.4.1
$ pip install onnx==1.4.1
2. Update onnx_to_tensorrt.py workspace size into 256Mb
Please try it again and let us know the result.
when i use yolov3-416 i get this error
ValueError: cannot reshape array of size 43095 into shape (1,255,19,19)
also i have modified onnx_to_tensorrt.py as follows
input_resolution_yolov3_HW = (416, 416)
so how to modify output_shapes in onnx_to_tensorrt.py
output_shapes = [(1, 255, 19, 19), (1, 255, 38, 38), (1, 255, 76, 76)]
it works when i modify output_shapes = [(1, 255, 13, 13), (1, 255, 26, 26), (1, 255, 52, 52)]
Thanks a lot!
is there any demo for video?
