I am currently working on a genetic sequencing program but I lack CUDA experience.
I have a kernel that contains the following loop:
#pragma unroll 1
for (score_type k = lo; k <= hi; ++k)
score_type I1, I2, I, D1, D2, D, H1, H;
I1 = (E_Band_gap_extend1_ptr && k - 1 >= E_lo && k - 1 <= E_hi) ? E_Band_gap_extend1_ptr[k - 1] : WFA_MIN1;
I2 = (H_Band_gap_open1_ptr && k - 1 >= H_lo_o && k - 1 <= H_hi_o) ? H_Band_gap_open1_ptr[k - 1] : WFA_MIN1;
I = nvbio::max(I1, I2) + 1u;
E_Band_ptr[k] = I;
D1 = (F_Band_gap_extend1_ptr && k + 1 >= F_lo && k + 1 <= F_hi) ? F_Band_gap_extend1_ptr[k + 1] : WFA_MIN1;
D2 = (H_Band_gap_open1_ptr && k + 1 >= H_lo_o && k + 1 <= H_hi_o) ? H_Band_gap_open1_ptr[k + 1] : WFA_MIN1;
D = nvbio::max(D1, D2);
F_Band_ptr[k] = D;
H1 = (H_Band_gap_mismatch_ptr && k >= H_lo_m && k <= H_hi_m) ? H_Band_gap_mismatch_ptr[k] : WFA_MIN1;
H = nvbio::max3(H1 + 1, I, D);
if ((uint16)H > M || (uint16)(H - k) > N)
H = WAVEFRONT_OFFSET_NULL;
H_Band_ptr[k] = H;
I’d like to be able to launch a second kernel (from the first) which would execute this loop in parallel for all values of k between lo and hi.
So I defined a second kernel this way
template <typename score_type>
__global__ void compute_band_kernel(score_type M, score_type N, score_type lo, score_type hi, score_type E_lo, score_type E_hi, score_type H_lo_o, score_type H_hi_o, score_type F_lo, score_type F_hi, score_type H_lo_m, score_type H_hi_m,
const int16 *E_Band_gap_extend1_ptr, const int16 *H_Band_gap_open1_ptr, const int16 *F_Band_gap_extend1_ptr, const int16 *H_Band_gap_mismatch_ptr,
int16 *E_Band_ptr, int16 *F_Band_ptr, int16 *H_Band_ptr)
int32 k = lo + blockIdx.x * blockDim.x + threadIdx.x;
if (k >= lo && k <= hi)
I = nvbio::max(I1, I2) + 1;
E_Band_ptr[k] = I;
F_Band_ptr[k] = D;
if ((unsigned short)H > M || (unsigned short)(H - k) > N)
H_Band_ptr[k] = H;
// Fonction pour vérifier les erreurs CUDA
inline void checkCudaErrors(cudaError_t err, const char *msg)
if (err != cudaSuccess)
std::cerr << msg << ": " << cudaGetErrorString(err) << std::endl;
throw std::runtime_error(msg);
void compute_band_host(score_type M, score_type N, score_type lo, score_type hi, score_type E_lo, score_type E_hi, score_type H_lo_o, score_type H_hi_o, score_type F_lo, score_type F_hi, score_type H_lo_m, score_type H_hi_m,
score_type num_threads = hi - lo + 1;
score_type block_size = 256;
score_type num_blocks = (num_threads + block_size - 1) / block_size;
compute_band_kernel<<<num_blocks, block_size>>>(M, N, lo, hi, E_lo, E_hi, H_lo_o, H_hi_o, F_lo, F_hi, H_lo_m, H_hi_m,
E_Band_gap_extend1_ptr, H_Band_gap_open1_ptr, F_Band_gap_extend1_ptr, H_Band_gap_mismatch_ptr,
E_Band_ptr, F_Band_ptr, H_Band_ptr);
checkCudaErrors(cudaDeviceSynchronize(), "Erreur lors de cudaDeviceSynchronize");
NVBIO_FORCEINLINE NVBIO_HOST_DEVICE void compute_band(score_type M, score_type N, score_type lo, score_type hi, score_type E_lo, score_type E_hi, score_type H_lo_o, score_type H_hi_o, score_type F_lo, score_type F_hi, score_type H_lo_m, score_type H_hi_m,
#ifndef __CUDA_ARCH__
// Contexte hôte
compute_band_host(M, N, lo, hi, E_lo, E_hi, H_lo_o, H_hi_o, F_lo, F_hi, H_lo_m, H_hi_m, E_Band_gap_extend1_ptr, H_Band_gap_open1_ptr, F_Band_gap_extend1_ptr, H_Band_gap_mismatch_ptr, E_Band_ptr, F_Band_ptr, H_Band_ptr);
#else
dim3 threadsPerBlock(16, 16);
dim3 numBlocks((1 + threadsPerBlock.x - 1) / threadsPerBlock.x,
(1 + threadsPerBlock.y - 1) / threadsPerBlock.y);
score_type block_size = 5;
// Contexte device : appels de kernel ici
// compute_band_kernel<<<(hi - lo + 256) / 256, 256>>>(M, N, lo, hi, E_lo, E_hi, H_lo_o, H_hi_o, F_lo, F_hi, H_lo_m, H_hi_m, E_Band_gap_extend1_ptr, H_Band_gap_open1_ptr, F_Band_gap_extend1_ptr, H_Band_gap_mismatch_ptr, E_Band_ptr, F_Band_ptr, H_Band_ptr);
// compute_band_kernel<<<numBlocks, threadsPerBlock>>>(M, N, lo, hi, E_lo, E_hi, H_lo_o, H_hi_o, F_lo, F_hi, H_lo_m, H_hi_m, E_Band_gap_extend1_ptr, H_Band_gap_open1_ptr, F_Band_gap_extend1_ptr, H_Band_gap_mismatch_ptr, E_Band_ptr, F_Band_ptr, H_Band_ptr);
compute_band_kernel<<<num_blocks, block_size>>>(M, N, lo, hi, E_lo, E_hi, H_lo_o, H_hi_o, F_lo, F_hi, H_lo_m, H_hi_m, E_Band_gap_extend1_ptr, H_Band_gap_open1_ptr, F_Band_gap_extend1_ptr, H_Band_gap_mismatch_ptr, E_Band_ptr, F_Band_ptr, H_Band_ptr);
#endif
Problem: I have a crash at runtime when modifying variables E_Band_ptr, F_Band_ptr and H_Band_ptr in the second kernel…
Memcheck gives me :
========= Invalid __global__ write of size 2 bytes
========= at void nvbio::aln::compute_band_kernel<int, nvbio::aln::wfa_type<int>>(T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T1, T2)+0x1d80 in /home/karlhal/bioinformatic2/code/RbowtieCuda/src/nvbio/nvbio/alignment/wfa.h:59
========= by thread (0,0,0) in block (0,0,0)
========= Address 0x57f149e65ee2 is out of bounds
========= and is 40.843.114.815.774 bytes before the nearest allocation at 0x7d16d1400000 of size 150 bytes
========= Saved host backtrace up to driver entry point at kernel launch time
========= Host Frame: [0x2c914f]
========= in /lib/x86_64-linux-gnu/libcuda.so.1
========= Host Frame:libcudart_static_4d8b33a106dceb3c07a56e26de61f2d53bb62a68 [0x2696cd]
========= in /home/karlhal/bioinformatic2/code/RbowtieCuda/src/nvbio/build_deb/./nvbio-test/nvbio-test
========= Host Frame:cudaLaunchKernel [0x2cd13d]
========= Host Frame:cudaError cudaLaunchKernel<char>(char const*, dim3, dim3, void**, unsigned long, CUstream_st*) in /usr/local/cuda-12.5/include/cuda_runtime.h:216 [0x494af]
========= Host Frame:__device_stub__ZN5nvbio3aln19compute_band_kernelIiNS0_8wfa_typeIiEEEEvT_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_S4_T0_(int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, nvbio::aln::wfa_type<int>&) in /tmp/tmpxft_0009c696_00000000-6_alignment_test.cudafe1.stub.c:287 [0x4338f]
========= Host Frame:void nvbio::aln::__wrapper__device_stub_compute_band_kernel<int, nvbio::aln::wfa_type<int> >(int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, nvbio::aln::wfa_type<int>&) in /tmp/tmpxft_0009c696_00000000-6_alignment_test.cudafe1.stub.c:290 [0x4346e]
========= Host Frame:void nvbio::aln::compute_band_kernel<int, nvbio::aln::wfa_type<int> >(int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, nvbio::aln::wfa_type<int>) [0x5796b]
========= Host Frame:void nvbio::aln::compute_band_host<int, nvbio::aln::wfa_type<int> >(int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, nvbio::aln::wfa_type<int>&) [0x8eb19]
========= Host Frame:void nvbio::aln::compute_band<int, nvbio::aln::wfa_type<int> >(int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, nvbio::aln::wfa_type<int>&) [0x88d63]
========= Host Frame:int nvbio::aln::priv::wfah_alignment_score_dispatch<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag, unsigned char>::update<true, nvbio::aln::priv::WfahScoringContext<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag>, uchar2*, int, unsigned char*, nvbio::aln::BestSink<int>, nvbio::aln::SimpleWfahScheme, nvbio::aln::wfa_type<int> >(nvbio::aln::priv::WfahScoringContext<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag>&, int, int, int, int, unsigned char*, uchar2*, int&, int*, int*, nvbio::aln::BestSink<int>&, int, int&, int, int, int, int, int, nvbio::aln::SimpleWfahScheme const&, nvbio::aln::wfa_type<int>&) [0x7ed3f]
========= Host Frame:bool nvbio::aln::priv::wfah_alignment_score_dispatch<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag, unsigned char>::run<nvbio::aln::priv::WfahScoringContext<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag>, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::SimpleWfahScheme, nvbio::aln::BestSink<int>, short2*, nvbio::aln::wfa_type<int> >(nvbio::aln::SimpleWfahScheme const&, nvbio::aln::priv::WfahScoringContext<1u, (nvbio::aln::AlignmentType)2, nvbio::aln::PatternBlockingTag>&, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, int, nvbio::aln::BestSink<int>&, int, int, short2*, nvbio::aln::wfa_type<int>&) [0x7711e]
========= Host Frame:bool nvbio::aln::priv::alignment_score_dispatch<nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag>, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, short2*>::dispatch<nvbio::aln::BestSink<int>, nvbio::aln::wfa_type<int> >(nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag>, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, int, nvbio::aln::BestSink<int>&, short2*, nvbio::aln::wfa_type<int>&) [0x71612]
========= Host Frame:bool nvbio::aln::alignment_score<nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag>, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::BestSink<int>, short2*, nvbio::aln::wfa_type<int> >(nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag>, nvbio::vector_view<unsigned char const*, unsigned int>, nvbio::aln::trivial_quality_string, nvbio::vector_view<unsigned char const*, unsigned int>, int, nvbio::aln::BestSink<int>&, short2*, nvbio::aln::wfa_type<int>&) [0x5c73f]
========= Host Frame:void nvbio::aln::SingleTest::full_wfa<128u, 181u, 150u, nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag> >(char const*, nvbio::aln::WfahAligner<(nvbio::aln::AlignmentType)2, nvbio::aln::SimpleWfahScheme, nvbio::aln::PatternBlockingTag>, char const*) [0x4ef60]
========= Host Frame:nvbio::aln::test(int, char**) in /home/karlhal/bioinformatic2/code/RbowtieCuda/src/nvbio/nvbio-test/alignment_test.cu:1827 [0x3e7bc]
========= Host Frame:main in /home/karlhal/bioinformatic2/code/RbowtieCuda/src/nvbio/nvbio-test/nvbio-test.cpp:207 [0x3031d]
========= Host Frame:__libc_start_call_main in ../sysdeps/nptl/libc_start_call_main.h:58 [0x2a1c9]
========= in /lib/x86_64-linux-gnu/libc.so.6
========= Host Frame:__libc_start_main in ../csu/libc-start.c:360 [0x2a28a]
========= Host Frame:_start [0x13a54]
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaLaunchKernel.
========= Saved host backtrace up to driver entry point at error
========= Host Frame: [0x404b45]
========= Host Frame:cudaLaunchKernel [0x2cd177]
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaDeviceSynchronize.
========= Host Frame:cudaDeviceSynchronize [0x2a2f73]
========= Host Frame:void nvbio::aln::compute_band_host<int, nvbio::aln::wfa_type<int> >(int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, int, nvbio::aln::wfa_type<int>&) [0x8eb25]
Erreur lors de cudaDeviceSynchronize: unspecified launch failure
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaFree.
========= Host Frame:cudaFree [0x2af957]
========= Host Frame:thrust::THRUST_200400_860_NS::system::cuda::detail::cuda_memory_resource<&cudaMalloc, &cudaFree, thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default> >::do_deallocate(thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default>, unsigned long, unsigned long) [0x8dd2f]
========= Host Frame:thrust::THRUST_200400_860_NS::device_ptr_memory_resource<thrust::THRUST_200400_860_NS::system::cuda::detail::cuda_memory_resource<&cudaMalloc, &cudaFree, thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default> > >::do_deallocate(thrust::THRUST_200400_860_NS::device_ptr<void>, unsigned long, unsigned long) [0x8795c]
========= Host Frame:thrust::THRUST_200400_860_NS::mr::allocator<unsigned char, thrust::THRUST_200400_860_NS::device_ptr_memory_resource<thrust::THRUST_200400_860_NS::system::cuda::detail::cuda_memory_resource<&cudaMalloc, &cudaFree, thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default> > > >::deallocate(thrust::THRUST_200400_860_NS::device_ptr<unsigned char>, unsigned long) [0x87bbd]
========= Host Frame:thrust::THRUST_200400_860_NS::detail::allocator_traits<thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::deallocate(thrust::THRUST_200400_860_NS::device_allocator<unsigned char>&, thrust::THRUST_200400_860_NS::device_ptr<unsigned char>, unsigned long)::workaround_warnings::deallocate(thrust::THRUST_200400_860_NS::device_allocator<unsigned char>&, thrust::THRUST_200400_860_NS::device_ptr<unsigned char>, unsigned long) [0x7d3ca]
========= Host Frame:thrust::THRUST_200400_860_NS::detail::allocator_traits<thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::deallocate(thrust::THRUST_200400_860_NS::device_allocator<unsigned char>&, thrust::THRUST_200400_860_NS::device_ptr<unsigned char>, unsigned long) [0x7d3fc]
========= Host Frame:thrust::THRUST_200400_860_NS::detail::contiguous_storage<unsigned char, thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::deallocate() [0x760a0]
========= Host Frame:thrust::THRUST_200400_860_NS::detail::contiguous_storage<unsigned char, thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::~contiguous_storage() [0x702ad]
========= Host Frame:thrust::THRUST_200400_860_NS::detail::vector_base<unsigned char, thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::~vector_base() [0x58b7c]
========= Host Frame:thrust::THRUST_200400_860_NS::device_vector<unsigned char, thrust::THRUST_200400_860_NS::device_allocator<unsigned char> >::~device_vector() [0x4d7e7]
========= Host Frame:nvbio::aln::SingleTest::~SingleTest() [0x4cc05]
========= Host Frame:nvbio::aln::test(int, char**) in /home/karlhal/bioinformatic2/code/RbowtieCuda/src/nvbio/nvbio-test/alignment_test.cu:1834 [0x408a8]
========= Program hit cudaErrorLaunchFailure (error 719) due to "unspecified launch failure" on CUDA API call to cudaGetLastError.
========= Host Frame:cudaGetLastError [0x2a5cd0]
========= Host Frame:thrust::THRUST_200400_860_NS::cuda_cub::throw_on_error(cudaError, char const*) [0x4c35f]
========= Host Frame:thrust::THRUST_200400_860_NS::system::cuda::detail::cuda_memory_resource<&cudaMalloc, &cudaFree, thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default> >::do_deallocate(thrust::THRUST_200400_860_NS::pointer<void, thrust::THRUST_200400_860_NS::cuda_cub::tag, thrust::THRUST_200400_860_NS::tagged_reference<void, thrust::THRUST_200400_860_NS::cuda_cub::tag>, thrust::THRUST_200400_860_NS::use_default>, unsigned long, unsigned long) [0x8dd4c]
terminate called after throwing an instance of 'thrust::THRUST_200400_860_NS::system::system_error'
what(): CUDA free failed: cudaErrorLaunchFailure: unspecified launch failure
========= Error: process didn't terminate successfully
========= Target application returned an error
========= ERROR SUMMARY: 5 errors
Why is there such a difference in the addresses (out of bounds) defining the three variables mentioned above?
With my thanks,
Franck
