Hi Matt,
I did research on the subject and I discovered that I need to put all kernels in a module. that solved the issue for this previous example. The real code I have, it is still giving me the same error even when I already have all kernels in the module. here is a portion of the code (original one is too long) I am providing here:
main program:
program test3
use kernels
use reyneq_Dev
use Q4_globals_Dev
use flows_Dev
use average_Dev
use filmtk_Dev
use sl_fthk_Dev
use bearing_Dev
nxmax = 402
nymax = 402
nx = nxmax
ny = nymax
allocate(hxlnewDev(nxmax,nymax),hxlDev(nxmax,nymax),hxrnewDev(nxmax,nymax),hxrDev(nxmax,nymax), &
hydnewDev(nxmax,nymax),hyunewDev(nxmax,nymax),hydDev(nxmax,nymax),hyuDev(nxmax,nymax))
allocate(xrefDev(nxmax),yrefDev(nxmax),hDev(nxmax,nymax),hnewDev(nxmax,nymax),hxyDev(nxmax,nymax))
allocate(ztaDev(nxmax,nymax),etaDev(nxmax,nymax),bearxDev(nxmax,nymax), &
bearyDev(nxmax,nymax),pDev(nxmax,nymax),poldDev(nxmax,nymax))
allocate(awDev(nxmax,nymax),apDev(nxmax,nymax),aeDev(nxmax,nymax), &
arDev(nxmax,nymax),asDev(nxmax,nymax),anDev(nxmax,nymax))
allocate(ajDev(nxmax),bjDev(nxmax),cjDev(nxmax),djDev(nxmax))
grid = dim3(ceiling(real(nx-1)/threads%x), &
ceiling(real(ny-1)/threads%y),1) !ny-1
call reyneq_p1_kernel<<<grid,threads>>>(nx,ny,nxmax,nymax,qnDev,pnDev,nter,iqpo,icoe,idisc, &
pitDev,pirDev,gamaDev,d0Dev,siDev,dtDev,omega0Dev,t1Dev,t2Dev,t3Dev,t4Dev,&
zdatDev,qndatDev,xrefDev,yrefDev,pDev,poldDev,hDev,hnewDev,awDev,aeDev,asDev,&
anDev,arDev,apDev,bearxDev,bearyDev,hydnewDev,hyunewDev,hxlnewDev,hxrnewDev,ztaDev,etaDev)
istat = cudaThreadSynchronize()
if (istat .ne. 0) write(*,*) ' reyneq_p1 kernel error ',cudaGetErrorString(istat),istat
call reyneq_p2_kernel<<<grid,threads>>>(nx,ny,nxmax,nymax,pDev,ajDev,bjDev,cjDev,djDev, &
awDev,aeDev,asDev,anDev,apDev,arDev,akdDev,aknDev)
if (istat .ne. 0) write(*,*) ' reyneq_p2 kernel error ',cudaGetErrorString(istat)
call reyneq_p3_kernel<<<grid,threads>>>(nx,ny,nxmax,nymax,pDev,xrefDev,yrefDev, &
awDev,apDev,aeDev,arDev,asDev,anDev,ajDev,bjDev,cjDev,djDev)
if (istat .ne. 0) write(*,*) ' reyneq_p3 kernel error ',cudaGetErrorString(istat)
end program test3
memory modules:
!module Q4_globals_Dev
use cudafor
!use Q4_sizes
!use Q4_globals
implicit none
!cuda device variables
integer :: istat
type(dim3) :: grid, threads
type(cudaDeviceProp) :: prop
!slider info
!xl = x length, yl = y length, zl=**, xg = **, xt=taper Length, ht = taper angle, rebase = base recess
real(8), device :: xlDev, ylDev, zlDev, xgDev, xtDev, htDev, rebaseDev, crownDev, camberDev, twistDev
!Grid
!integer, device :: nxDev,nx1Dev,nx2Dev,nx3Dev,nx4Dev
real(8), device, allocatable, dimension(:) :: xrefDev,xref1Dev,xref2Dev,xref3Dev,xref4Dev, &
yrefDev,yref1Dev,yref2Dev,yref3Dev,yref4Dev
!real(8), device, allocatable, dimension(:,:) :: bearxDev, bearx1Dev, bearx2Dev,bearx3Dev,&
! bearx4Dev, bearyDev, beary1Dev, beary2Dev, beary3Dev, beary4Dev
!Run Setup and Initial attitude
real(8), device :: skeDev, raDev, rpmDev, u0Dev, hmDev, hx0Dev, h0Dev, hsDev, hyDev, p0xlDev
!height data (say what hnew and h are)
real(8), device, allocatable, dimension(:,:) :: hDev, h1Dev, h2Dev, h3Dev, h4Dev, hnewDev, hnew1Dev,&
hnew2Dev, hnew3Dev, hnew4Dev
!pressure
real(8), device, allocatable :: pDev(:,:), p1Dev(:,:), p2Dev(:,:), p3Dev(:,:), p4Dev(:,:)
!constants
real(8), device :: corCoefDev !d0, gama, pir, pit, t1, t2, t3, t4, slip_beta, slip_gamma, accom,
!reynolds equation
real(8), device :: akmaxDev, akDev, ak0Dev, ak1Dev, ak2Dev, ak3Dev, ak4Dev
!reynolds eqn residuals
real(8), device, allocatable, dimension(:,:) :: resDev, res1Dev, res2Dev, res3Dev, res4Dev !, &
! su01Dev, su02Dev, su03Dev, su04Dev
!various parameters needed by the reynolds equation
!many of these are set in ave_height()
real(8), device, allocatable, dimension(:,:) :: cohimxDev,cohimx1Dev,cohimx2Dev, &
cohimx3Dev,cohimx4Dev,cohjmxDev,cohjmx1Dev,cohjmx2Dev,cohjmx3Dev,cohjmx4Dev, &
himaxDev,himax1Dev,himax2Dev,himax3Dev,himax4Dev, &
himinDev,himin1Dev,himin2Dev,himin3Dev,himin4Dev, &
hjmaxDev,hjmax1Dev,hjmax2Dev,hjmax3Dev,hjmax4Dev, &
hjminDev,hjmin1Dev,hjmin2Dev,hjmin3Dev,hjmin4Dev, &
recssiDev,recssi1Dev,recssi2Dev,recssi3Dev,recssi4Dev, &
recssjDev,recssj1Dev,recssj2Dev,recssj3Dev,recssj4Dev
!FORCES
real(8), device :: emaxDev, errDev, fDev, fnegDev, fposDev, fspDev, fsrDev, xfDev, yfDev, &
!xint(4), yint(4), hint(4), &
hminDev, MinFHDev, MinFHLocXDev, MinFHLocYDev, &
jacDev(3,3), rintDev(4), hintgeDev(4),hgapDev(4), &
XmomDev, YmomDev, xPosLocDev, yPosLocDev, xNegLocDev, yNegLocDev, &
fvdw_outputDev !,ZmomDev
real(8), device, allocatable, dimension (:,:) :: vdwMolecularForceMapDev
real(8), device, allocatable, dimension (:) :: xintNewDev, yintNewDev, hintNewDev
!contact and surface roughness
real(8), device :: cpDev !(nxx,nyx)
real(8), device :: rsikDev,ctaDev,raspDev,fcrDev,txrDev,tyrDev, &
aratioDev,eyoungDev,ydstDev,ydcoeDev,pratioDev,frcoeDev,ahcDev,bhcDev,elecpotDev
!forces on the slider
real(8), device :: f0Dev, xf0Dev, yf0Dev, xfsDev, yfsDev, Pitch_StiffnessDev, Roll_StiffnessDev,&
PSADev, RSADev
logical, device :: crashDev
end module Q4_globals_Dev
module filmtk_Dev
!use Dyn_sizes_module
implicit none
real(8), device, allocatable :: hxlnewDev(:,:), hxrnewDev(:,:), hydnewDev(:,:), hyunewDev(:,:)
real(8), device :: zx1Dev,zx2Dev,zy1Dev,zy2Dev,zxDev
end module filmtk_Dev
module sl_fthk_Dev
implicit none
real(8), device, allocatable :: hxlDev(:,:), hxrDev(:,:), hydDev(:,:), hyuDev(:,:), hxyDev(:,:), &
hsadDev(:,:)
end module sl_fthk_Dev
module flows_Dev
implicit none
real(8), device :: t1Dev, t2Dev, t3Dev, t4Dev, gamaDev, pirDev, pitDev, d0Dev, zdatDev(1001), qndatDev(1001)
!integer, device :: nterDev, icoeDev, iqpoDev
end module flows_Dev
module average_Dev
implicit none
real(8), device, allocatable :: ztaDev(:,:), etaDev(:,:)
end module average_Dev
module bearing_Dev
implicit none
real(8), device, allocatable :: bearxDev(:,:), bearyDev(:, :)
end module bearing_Dev
! added by Dolf 06/04/15
module reyneq_Dev
implicit none
real(8), device, allocatable :: awDev(:,:),apDev(:,:),aeDev(:,:),arDev(:,:),asDev(:,:),anDev(:,:),&
aw1Dev(:,:),ap1Dev(:,:),ae1Dev(:,:),as1Dev(:,:),an1Dev(:,:),ar1Dev(:,:),dp1Dev(:,:), &
aw2Dev(:,:),ap2Dev(:,:),ae2Dev(:,:),as2Dev(:,:),an2Dev(:,:),ar2Dev(:,:),dp2Dev(:,:), &
aw3Dev(:,:),ap3Dev(:,:),ae3Dev(:,:),as3Dev(:,:),an3Dev(:,:),ar3Dev(:,:),dp3Dev(:,:), &
aw4Dev(:,:),ap4Dev(:,:),ae4Dev(:,:),as4Dev(:,:),an4Dev(:,:),ar4Dev(:,:),dp4Dev(:,:), &
poldDev(:,:),ajDev(:),bjDev(:),cjDev(:),djDev(:)
real(8), device :: qnDev(1001),pnDev(1001)
real(8), device :: siDev,dtDev,omega0Dev,akdDev,aknDev
end module reyneq_Dev
GPU kernels:
module kernels
contains
attributes (global) subroutine reyneq_p1_kernel(nx,ny,nxmax,nymax,qn,pn,nter,iqpo,icoe,idisc, &
pit,pir,gama,d0,si,dt,omega0,t1,t2,t3,t4,zdat,qndat,xref,yref,p,pold,h,hnew,aw,ae,as,an,ar,ap, &
bearx,beary,hydnew,hyunew,hxlnew,hxrnew,zta,eta)
implicit none
integer, value :: nter,iqpo,icoe,idisc,nx,ny,nxmax,nymax
integer :: i,j,nxm1,nym1
integer :: NY1M1, IP1, NY4, JP1, NX5, NX4, NX1, NX3, NX2, I1, I2, IM1, KINT, JM1, K, L, &
IDIRECT, NX1M1, NY2, NY3, NY1, J1, J2, NY5, LOC
real(8) :: H2IP_B, AP2, AP3, AP1, AP4, APJ_B, RATIO, DEXP, AMI_B, RAK, H2JP, AW4, AW3, AW2, AW1, &
BJ, QNJP_B, PEMI_B, PEPJ, H2IM, APJ, H2IP, API, H2JP_B, DABS, PEPJ_B, H2JM, PEMJ_B, DMI, DMJ, &
AN4, AN1, AN2, AN3, PEPI_B, DPI_B, AMI, AMJ, PN_B, API_B, AMJ_B,H2JM_B, AJ, RAKPRE, &
FPJ, AE1, AE3, AE2, AE4, QNIM_B, P2JM, FMI_B, QNJP, DELYJM2, DELYJM1, QNH2JM, AMULT, DPJ_B, &
FMJ_B, AKN, DJ, AKD, P2IM, DELXIM2, DELXIM1, FPJ_B, P2IP, QNH2IM_B, AS3, CJ, AS1, DMI_B, AS4, &
QNH2JP, FMJ, FMI, ZTAM, QNH2JP_B, ETAP, FPI_B, DELYJP1, DELYJP2, ETAM, AR1, AR2, AR3, AR4, &
AS2, QNJM_B, XMXP, DPJ, DPI, P2JP, QNH2IM, DELXIP1, DELXIP2, QNIP, QNH2JM_B, H2IM_B, QNIM, QNH2IP, &
PEPI, QNH2IP_B, DMJ_B, FPI,DP4, DP3, DP2, DP1, QNIP_B, YMYP, PEMJ,ZTAP, PEMI, QNJM
real(8) :: t1,t2,t3,t4,pit,pir,gama,d0,si,dt,omega0,zdat(1001),qndat(1001),xref(nxmax),yref(nxmax),p(nxmax,nymax), &
pold(nxmax,nymax),bearx(nxmax,nymax),beary(nxmax,nymax),zta(nxmax,nymax),eta(nxmax,nymax), &
hydnew(nxmax,nymax),hyunew(nxmax,nymax),hxlnew(nxmax,nymax),hxrnew(nxmax,nymax),h(nxmax,nymax),&
hnew(nxmax,nymax),aw(nxmax,nymax),ap(nxmax,nymax),ae(nxmax,nymax),ar(nxmax,nymax),as(nxmax,nymax),&
an(nxmax,nymax),qn(1001),pn(1001)
real(8) :: C22, Q2, QN1, QN2, S1, U1, FF0, XI, DEL, AIJ, C12, C11, DLOG10, DFLOAT,&
V1, V2, V3, V4, V5, Z1, Z2, A, B, R1, R2, V, EV, F1, F2, Z0, Z, DLOG, ALZ
dimension a(20),b(20)
i = (blockidx%x - 1) * blockDim%x + threadidx%x
j = (blockidx%y - 1) * blockDim%y + threadidx%y
nxm1 = nx-1
nym1 = ny-1
if(j >= 2 .and. j <= nym1) then
!do 300 j=2,nym1
jm1=j-1
jp1=j+1
delyjp1=yref(jp1)-yref(j )
delyjm1=yref(j )-yref(jm1)
if(j.ne.nym1) delyjp2=yref(j+2)-yref(jp1)
if(j.ne.2) delyjm2=yref(jm1)-yref(j-2)
ymyp =(yref(jp1)-yref(jm1))/2.d0
if(i >= 2 .and. i >= nxm1) then
! do 250 i=2,nxm1
im1=i-1
ip1=i+1
delxip1=xref(ip1)-xref(i )
delxim1=xref(i )-xref(im1)
if(i.ne.nxm1) delxip2=xref(i+2)-xref(ip1)
if(i.ne.2) delxim2=xref(im1)-xref(i-2)
xmxp =(xref(ip1)-xref(im1))/2.d0
h2im = hydnew(i ,j )
h2ip = hydnew(i+1,j )
h2jm = hxlnew(i ,j )
h2jp = hxlnew(i ,j+1)
h2im_b = hyunew(i ,j )
h2ip_b = hyunew(i+1,j )
h2jm_b = hxrnew(i ,j )
h2jp_b = hxrnew(i ,j+1)
ztam=zta(i ,j )
ztap=zta(i ,j+1)
etam=eta(i ,j )
etap=eta(i+1,j )
p2im = (p(im1,j)+p(i,j))/2.d0
p2ip = (p(ip1,j)+p(i,j))/2.d0
p2jm = (p(i,jm1)+p(i,j))/2.d0
p2jp = (p(i,jp1)+p(i,j))/2.d0
pn(i)=p2im*h2im
! pn = input, qn = output
! call flow(1) here!!!
! call flow(pn,qnim)
!ha use the continuum model…
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 100
!ha use the first order slip model…
else if (iqpo.eq.1) then
qn(i) = pn(i) + t1
!return
goto 100
!ha use the second order slip model…
else if (iqpo.eq.2) then
r1 = t2/pn(i)
r2 = r1/pn(i)
qn(i) = pn(i) + t1 + r1
!return
goto 100
!ha use the asymtotic fk model…
else if (iqpo.eq.3) then
r1 = t2/pn(i)
s1 = t3/(pn(i)pn(i))
u1 = t4/(pn(i)pn(i)pn(i))
qn(i) = pn(i) + t1 + r1 - s1 - u1
!return
goto 100
!ha use the full fk model…
else if (iqpo.eq.4) then
z = d0pn(i)
if (icoe.eq.1) go to 30
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
b(2) = 1.5d0(1.d0-gama)
do 25 i = 3,nter
xi = dfloat(i)
aij = xi(xi-1.d0)(xi-2.d0)
a(i) = (-2.d0a(i-2))/aij
b(i) = (-2.d0b(i-2)-(3.d0xixi-6.d0xi+2.d0)*a(i))/aij
25 continue
icoe = 1
30 if (z.ge.1.1d0) then
v = 1.889881575d0z**0.66666666666666666d0
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
ff0 = ev(1.d0-1.d0/v1+25.d0/v2-1225.d0/v3 + 89425.d0/v4-7263025.d0/v5)
f1 = evdsqrt(v/3.d0)(1.d0+5.d0/v1-35.d0/v2 + 665.d0/v3+9625.d0/v4-9284275.d0/v5)
f2 = ev*(v/3.d0)*(1.d0+17.d0/v1-35.d0/v2 + 1925.d0/v3-175175.d0/v4+22247225.d0/v5)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 35 i = nter,1,-1
xi = dfloat(i)
aij = 1.d0/(1.d0+xi)
if (i.eq.1) then
ff0 = ((alz*xi+1.d0)*a(i) + b(i)*xi + ff0)
go to 27
end if
ff0 = ((alz*xi+1.d0)*a(i) + b(i)*xi + ff0)*z
27 f1 = (a(i)*alz + b(i) + f1)z
f2 = (aij((alz-aij)*a(i)+b(i)) + f2)*z
35 continue
ff0 = -0.5d0ff0
f1 = 0.5d0(f1 + 1.d0)
f2 = pir/4.d0 - 0.5d0*(f2 + 1.d0)z
end if
c11 = 8.d0-zzz(pir/12.d0-z/16.d0)-2.d0z(4.d0+zz)ff0 - (16.d0+zz(8.d0+zz/8.d0))f1-z(16.d0+zz)f2
c22 = 1.d0- 2.d0f1
c12 = 2.d0 - (pir/2.d0)z + zz/4.d0-2.d0zff0 - (4.d0 +zz/2.d0)f1 - 2.d0zf2
del = c11c22 - c12c12
q2 = (pir/del)(c11 - zz*(c12/6.d0-zzc22/144.d0))
qn(i) = (-1.d0/z+q2)*(6.d0/z)*pn(i)
!return
goto 100
! use the data base of precalculated qp based on fk model…
else if (iqpo.eq.5) then
z0=d0pn(i)
loc=dint(200.d0dlog10(z0)+401)
if (loc.ge.801) goto 55
if(loc.lt.1)goto 56
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
qn(i)=(qn2-qn1)*(z0-z1)/(z2-z1)+qn1
!return
goto 100
! if inverse knudsen no. is out of range of database
! use first order slip
55 continue
r1 = t2/pn(i)
s1 = t3/(pn(i)*pn(i))
u1 = t4/(pn(i)*pn(i)*pn(i))
!return
goto 100
56 continue
qn(i)=-pn(i)6.d0/pirdlog(z0)/z0
!return
goto 100
end if
! end flow(1) sub here!!!
100 continue
qnim = qn(i)
qnh2im = qnimh2imh2im
fmi = h2im*(bearx(im1,j)+bearx(i,j))/2.d0
dmi=qnh2im/delxim1
pemi=fmi/dmi
if(etam.eq.1.d0) then
ami_b=0.d0
fmi_b=0.d0
else
pn_b=p2im*h2im_b
! call flow(2) here!!!
! call flow(pn_b,qnim_b)
pn(i) = pn_b
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 200
qn(i) = pn(i) + t1
!return
goto 200
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 200
r1 = t2/pn(i)
!return
goto 200
z = d0pn(i)
if (icoe.eq.1) go to 45
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 40 i = 3,nter
xi = dfloat(i)
40 continue
icoe = 1
45 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 50 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 42
end if
42 f1 = (a(i)*alz + b(i) + f1)z
50 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 200
z0=d0pn(i)
if (loc.ge.801) goto 65
if(loc.lt.1)goto 66
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 200
65 continue
r1 = t2/pn(i)
!return
goto 200
66 continue
!return
goto 200
end if
! end flow(2) sub here!!!
200 continue
! end flow sub
! setting up the output
qnim_b = qn(i)
qnh2im_b = qnim_bh2im_bh2im_b
fmi_b = h2im_b*(bearx(im1,j)+bearx(i,j))/2.d0
dmi_b=qnh2im_b/delxim1
pemi_b=fmi_b/dmi_b
endif
pn(i)=p2ip*h2ip
! call flow(3) here!!!
! call flow(pn,qnip)
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 300
qn(i) = pn(i) + t1
!return
goto 300
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 300
r1 = t2/pn(i)
!return
goto 300
z = d0pn(i)
if (icoe.eq.1) go to 60
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 54 i = 3,nter
xi = dfloat(i)
54 continue
icoe = 1
60 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 64 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 47
end if
47 f1 = (a(i)*alz + b(i) + f1)z
64 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 300
z0=d0pn(i)
if (loc.ge.801) goto 75
if(loc.lt.1)goto 76
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 300
75 continue
r1 = t2/pn(i)
!return
goto 300
76 continue
!return
goto 300
end if
! end flow(3) sub here!!!
300 continue
! end flow sub
qnip = qn(i)
qnh2ip = qniph2iph2ip
fpi = h2ip*(bearx(ip1,j)+bearx(i,j))/2.d0
dpi=qnh2ip/delxip1
pepi=fpi/dpi
if(etap.eq.1.d0) then
api_b=0.d0
fpi_b=0.d0
else
pn_b=p2ip*h2ip_b
! call flow(4) sub here!!!
!call flow(pn_b,qnip_b)
pn(i) = pn_b
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 400
qn(i) = pn(i) + t1
!return
goto 400
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 400
r1 = t2/pn(i)
!return
goto 400
z = d0pn(i)
if (icoe.eq.1) go to 74
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 69 i = 3,nter
xi = dfloat(i)
69 continue
icoe = 1
74 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 79 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 62
end if
62 f1 = (a(i)*alz + b(i) + f1)z
79 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 400
z0=d0pn(i)
if (loc.ge.801) goto 85
if(loc.lt.1)goto 86
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 400
85 continue
r1 = t2/pn(i)
!return
goto 400
86 continue
!return
goto 400
end if
! end flow(4) sub here!!!
400 continue
! end flow sub
! added by Dolf 7/8/15
qnip_b = qn(i)
qnh2ip_b = qnip_bh2ip_bh2ip_b
fpi_b = h2ip_b*(bearx(ip1,j)+bearx(i,j))/2.d0
dpi_b=qnh2ip_b/delxip1
pepi_b=fpi_b/dpi_b
endif
pn(i)=p2jm*h2jm
! call flow(5) here!!!
!call flow(pn,qnjm)
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 500
qn(i) = pn(i) + t1
!return
goto 500
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 500
r1 = t2/pn(i)
!return
goto 500
z = d0pn(i)
if (icoe.eq.1) go to 89
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 84 i = 3,nter
xi = dfloat(i)
84 continue
icoe = 1
89 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 94 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 67
end if
67 f1 = (a(i)*alz + b(i) + f1)z
94 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 500
z0=d0pn(i)
if (loc.ge.801) goto 95
if(loc.lt.1)goto 96
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 500
95 continue
r1 = t2/pn(i)
!return
goto 500
96 continue
!return
goto 500
end if
! end flow(5) sub here!!!
500 continue
! end flow sub
qnjm = qn(i)
qnh2jm = qnjmh2jmh2jm
fmj = h2jm*(beary(i,jm1)+beary(i,j))/2.d0
dmj=qnh2jm/delyjm1
pemj=fmj/dmj
if(ztam.eq.1.d0) then
amj_b=0.d0
fmj_b=0.d0
else
pn_b=p2jm*h2jm_b
! call flow(6) here!!!
!call flow(pn_b,qnjm_b)
pn(i) = pn_b
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 600
qn(i) = pn(i) + t1
!return
goto 600
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 600
r1 = t2/pn(i)
!return
goto 600
z = d0pn(i)
if (icoe.eq.1) go to 104
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 99 i = 3,nter
xi = dfloat(i)
aij = xi*(xi-1.d0)(xi-2.d0)
99 continue
icoe = 1
104 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 109 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 72
end if
72 f1 = (a(i)*alz + b(i) + f1)z
109 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 600
z0=d0pn(i)
if (loc.ge.801) goto 105
if(loc.lt.1)goto 106
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 600
105 continue
r1 = t2/pn(i)
!return
goto 600
106 continue
!return
goto 600
end if
! end flow(6) sub here!!!
600 continue
qnjm_b = qn(i)
qnh2jm_b = qnjm_bh2jm_bh2jm_b
fmj_b = h2jm_b*(beary(i,jm1)+beary(i,j))/2.d0
dmj_b=qnh2jm_b/delyjm1
pemj_b=fmj_b/dmj_b
endif
pn(i)=p2jp*h2jp
! call flow(7) here!!!
!call flow(pn,qnjp)
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 700
qn(i) = pn(i) + t1
!return
goto 700
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 700
r1 = t2/pn(i)
!return
goto 700
z = d0pn(i)
if (icoe.eq.1) go to 119
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 114 i = 3,nter
xi = dfloat(i)
114 continue
icoe = 1
119 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 124 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 77
end if
77 f1 = (a(i)*alz + b(i) + f1)z
124 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 700
z0=d0pn(i)
if (loc.ge.801) goto 115
if(loc.lt.1)goto 116
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 700
115 continue
r1 = t2/pn(i)
!return
goto 700
116 continue
!return
goto 700
end if
! end flow(7) sub here!!!
700 continue
qnjp = qn(i)
qnh2jp = qnjph2jph2jp
fpj = h2jp*(beary(i,jp1)+beary(i,j))/2.d0
dpj=qnh2jp/delyjp1
pepj=fpj/dpj
if(ztap.eq.1.d0) then
apj_b=0.d0
fpj_b=0.d0
else
pn_b=p2jp*h2jp_b
! call flow(8) here!!!
!call flow(pn_b,qnjp_b)
if (iqpo.eq.0) then
qn(i) = pn(i)
!return
goto 800
qn(i) = pn(i) + t1
!return
goto 800
r1 = t2/pn(i)
r2 = r1/pn(i)
!return
goto 800
r1 = t2/pn(i)
!return
goto 800
z = d0pn(i)
if (icoe.eq.1) go to 134
a(1) = 0.d0
a(2) = -1.d0
b(1) = -pir
do 129 i = 3,nter
xi = dfloat(i)
129 continue
icoe = 1
134 if (z.ge.1.1d0) then
v1 = 12.d0v
v2 = 24.d0vv1
v3 = 36.d0vv2
v4 = 48.d0vv3
v5 = 60.d0vv4
ev = pitdexp(-v)
else
ff0 = 0.d0
f1 = 0.d0
f2 = 0.d0
alz = dlog(z)
do 139 i = nter,1,-1
xi = dfloat(i)
if (i.eq.1) then
go to 82
end if
82 f1 = (a(i)*alz + b(i) + f1)z
139 continue
ff0 = -0.5d0ff0
end if
c22 = 1.d0- 2.d0f1
!return
goto 800
z0=d0pn(i)
if (loc.ge.801) goto 125
if(loc.lt.1)goto 126
z1=zdat(loc)
qn1=qndat(loc)
z2=zdat(loc+1)
qn2=qndat(loc+1)
! interpolate…
!return
goto 800
125 continue
r1 = t2/pn(i)
!return
goto 800
126 continue
!return
goto 800
end if
! end flow(8) sub here!!!
800 continue
qnjp_b = qn(i)
qnh2jp_b = qnjp_bh2jp_bh2jp_b
fpj_b = h2jp_b*(beary(i,jp1)+beary(i,j))/2.d0
dpj_b=qnh2jp_b/delyjp1
pepj_b=fpj_b/dpj_b
endif
go to (11,12,13,14,15),idisc
! power law
11 ami=dmax1(0.d0,dmi*(1.d0-0.1d0dabs(pemi))*5)
api=dmax1(0.d0,dpi(1.d0-0.1d0dabs(pepi))*5)
amj=dmax1(0.d0,dmj(1.d0-0.1d0dabs(pemj))*5)
apj=dmax1(0.d0,dpj(1.d0-0.1d0dabs(pepj))*5)
if(etam.ne.1.d0) then
ami_b=dmax1(0.d0,dmi_b(1.d0-0.1d0dabs(pemi_b))*5)
endif
if(etap.ne.1.d0) then
api_b=dmax1(0.d0,dpi_b(1.d0-0.1d0dabs(pepi_b))*5)
endif
if(ztam.ne.1.d0) then
amj_b=dmax1(0.d0,dmj_b(1.d0-0.1d0dabs(pemj_b))*5)
endif
if(ztap.ne.1.d0) then
apj_b=dmax1(0.d0,dpj_b(1.d0-0.1d0dabs(pepj_b))*5)
endif
goto 20
! central difference
12 ami=dmi(1.d0-0.5d0dabs(pemi))
api=dpi(1.d0-0.5d0dabs(pepi))
amj=dmj(1.d0-0.5d0dabs(pemj))
apj=dpj(1.d0-0.5d0dabs(pepj))
ami_b=dmi_b(1.d0-0.5d0dabs(pemi_b))
endif
api_b=dpi_b(1.d0-0.5d0dabs(pepi_b))
endif
amj_b=dmj_b(1.d0-0.5d0dabs(pemj_b))
endif
apj_b=dpj_b(1.d0-0.5d0*dabs(pepj_b))
endif
goto 20
! 1st-order upwind: idisc = 2
13 ami=dmi
api=dpi
amj=dmj
apj=dpj
ami_b=dmi_b
endif
api_b=dpi_b
endif
amj_b=dmj_b
endif
apj_b=dpj_b
endif
goto 20
! hybrid
14 ami=dmax1(0.d0,dmi*(1.0d0-0.5d0dabs(pemi)))
api=dmax1(0.d0,dpi(1.0d0-0.5d0dabs(pepi)))
amj=dmax1(0.d0,dmj(1.0d0-0.5d0dabs(pemj)))
apj=dmax1(0.d0,dpj(1.0d0-0.5d0dabs(pepj)))
ami_b=dmax1(0.d0,dmi_b(1.0d0-0.5d0dabs(pemi_b)))
endif
api_b=dmax1(0.d0,dpi_b(1.0d0-0.5d0dabs(pepi_b)))
endif
amj_b=dmax1(0.d0,dmj_b(1.0d0-0.5d0dabs(pemj_b)))
endif
apj_b=dmax1(0.d0,dpj_b(1.0d0-0.5d0dabs(pepj_b)))
endif
goto 20
! exponential
15 ami=dmidabs(pemi)/(dexp(dabs(pemi))-1.d0)
api=dpidabs(pepi)/(dexp(dabs(pepi))-1.d0)
amj=dmjdabs(pemj)/(dexp(dabs(pemj))-1.d0)
apj=dpjdabs(pepj)/(dexp(dabs(pepj))-1.d0)
ami_b=dmi_bdabs(pemi_b)/(dexp(dabs(pemi_b))-1.d0)
endif
api_b=dpi_bdabs(pepi_b)/(dexp(dabs(pepi_b))-1.d0)
endif
amj_b=dmj_bdabs(pemj_b)/(dexp(dabs(pemj_b))-1.d0)
endif
apj_b=dpj_bdabs(pepj_b)/(dexp(dabs(pepj_b))-1.d0)
endif
20 continue
aw(im1,jm1)=-ymyp(etam*(ami+dmax1( fmi,0.d0)) + (1.d0-etam)(ami_b+dmax1( fmi_b,0.d0)))
ae(im1,jm1)=-ymyp(etap*(api+dmax1(-fpi,0.d0)) + (1.d0-etap)(api_b+dmax1(-fpi_b,0.d0)))
as(im1,jm1)=-xmxp(ztam*(amj+dmax1( fmj,0.d0)) + (1.d0-ztam)(amj_b+dmax1( fmj_b,0.d0)))
an(im1,jm1)=-xmxp(ztap*(apj+dmax1(-fpj,0.d0)) + (1.d0-ztap)(apj_b+dmax1(-fpj_b,0.d0)))
ap(im1,jm1)=-aw(im1,jm1)-ae(im1,jm1) &
-as(im1,jm1)-an(im1,jm1) &
-ymyp(etamfmi+(1.d0-etam)fmi_b) &
+ymyp(etapfpi+(1.d0-etap)fpi_b) &
-xmxp(ztamfmj+(1.d0-ztam)fmj_b) &
+xmxp(ztapfpj+(1.d0-ztap)fpj_b)
if(idirect.ne.1) then
amult = xmxp * ymyp * si / dt / omega0
ar(im1,jm1)=amulth(i,j)pold(i,j)
ap(im1,jm1)=ap(im1,jm1)+amulthnew(i,j)
else
ar(im1,jm1)=0.d0
endif ! idirect
endif ! i
endif ! j
!250 continue
!300 continue
end subroutine reyneq_p1_kernel
attributes (global) subroutine reyneq_p2_kernel(nx,ny,nxmax,nymax,p, &
aj,bj,cj,dj,aw,ae,as,an,ap,ar,akd,akn)
implicit none
integer, value :: nx,ny,nxmax,nymax
integer :: i,j,im1,ip1,jp1,jm1,nxm1,nym1
real(8) :: aj(nxmax),bj(nxmax),cj(nxmax),dj(nxmax),p(nxmax,nymax), &
aw(nxmax,nymax),ae(nxmax,nymax),an(nxmax,nymax),as(nxmax,nymax), &
ar(nxmax,nymax),ap(nxmax,nymax)
real(8) :: akd,akn
nym1 = ny-1
nxm1 = nx-1
!do j=2,nym1
if (j >=2 .and. j <= nym1) then
jm1=j-1
jp1=j+1
!do i=2,nxm1
if (i >=2 .and. i <= nxm1) then
im1=i-1
ip1=i+1
aj(im1)=aw(im1,jm1)
bj(im1)=ap(im1,jm1)
cj(im1)=ae(im1,jm1)
dj(im1)=ar(im1,jm1)-as(im1,jm1)*p(i,jm1) - an(im1,jm1)*p(i,jp1)
if(i.eq.2) then
dj(im1)=dj(im1)-aw(im1,jm1)*p(im1,j)
aj(im1)=0.d0
else if (i.eq.nxm1) then
dj(im1)=dj(im1)-ae(im1,jm1)*p(ip1,j)
cj(im1)=0.d0
endif
akd=akd+dabs(aj(im1)*p(im1,j)+bj(im1)*p(i,j) + cj(im1)*p(ip1,j)-dj(im1))
akn=akn+dabs(bj(im1)*p(i,j))
!enddo
!enddo
endif
endif
end subroutine reyneq_p2_kernel
attributes (global) subroutine reyneq_p3_kernel(nx,ny,nxmax,nymax,p,xref,yref, &
aw,ap,ae,ar,as,an,aj,bj,cj,dj)
use cudafor
implicit none
integer :: i,j,k,km1,nxm1,nym1,jm1,jp1,im1,ip1,nxm2,nym2,n
real(8) :: p(nxmax,nymax),xref(nxmax),yref(nxmax),aw(nxmax,nymax),ap(nxmax,nymax), &
ae(nxmax,nymax),ar(nxmax,nymax),as(nxmax,nymax),an(nxmax,nymax),aj(nxmax),bj(nxmax), &
cj(nxmax),dj(nxmax),beta(nxmax),gamma(nxmax)
real(8) :: ymyp,xmxp
nxm1 = nx-1
nym1 = ny-1
nxm2 = nx-2
nym2 = ny-2
!do 500 j=2,nym1
if ( j >= 2 .and. j <= nym1) then
jm1=j-1
jp1=j+1
ymyp=(yref(jp1)-yref(jm1))/2.d0
!do 450 i=2,nxm1
if(i >= 2 .and. i <= nxm1) then
im1=i-1
ip1=i+1
xmxp=(xref(ip1)-xref(im1))/2.d0
aj(im1)=aw(im1,jm1)
bj(im1)=ap(im1,jm1)
cj(im1)=ae(im1,jm1)
if(i.eq.2) then
aj(im1)=0.d0
cj(im1)=0.d0
endif
!450 continue
endif ! i
!call tridag(nxm2,aj,bj,cj,dj)
! tridag starts
n = nxm2
beta(1)=bj(1)
gamma(1)=dj(1)/beta(1)
do 10 k=2,n
km1=k-1
beta(k)=bj(k)-aj(k)*cj(km1)/beta(km1)
gamma(k)=(dj(k)-aj(k)*gamma(km1))/beta(k)
10 continue
dj(n)=gamma(n)
do 20 k=n-1,1,-1
dj(k)=gamma(k)-cj(k)*dj(k+1)/beta(k)
20 continue
! tridag ends
do 475 k=1,n !nxm2
p(k+1,j)=dj(k)
475 continue
!500 continue
endif ! j
end subroutine reyneq_p3_kernel
end module
end of code:
it is very strange case to me to encounter such error.
please advice what might be the potential cause for this.
Dolf
