I am working with jetpack-6.1(rev1) on Orin NX.
After running twice a simple image capture test program (and waiting ten minutes for kmemleak to make its job), kmemleak has detected a memory leak originating from
capture->unpins_list =
vzalloc(setup->queue_depth * sizeof(*capture->unpins_list));
in vi_capture_setup() in drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c
I tracked it down to this line
kfree(capture);
in vi_capture_shutdown() in the same file, where ‘capture’ is freed without first freeing ‘unpins_list’.
I have added a trivial fix
@@ -551,6 +552,13 @@ void vi_capture_shutdown(
vfree(capture->unpins_list);
capture->unpins_list = NULL;
+ if (capture->unpins_list) {
+ printk("kfree(capture = %p) with non-NULL (%p) unpins_list\n",
+ capture, capture->unpins_list);
+ printk("force freeing unpins_list\n");
+ vfree(capture->unpins_list);
+ capture->unpins_list = NULL;
kfree(capture);
chan->capture_data = NULL;
which suppresses the memory leak on ‘unpins_list’, but thereafter kmemleaks reports many more memory leaks, which reveals that ‘unpins_list’ itself contains pointers to many other allocated memory zones.
Here is my test program. Adjust it based on your sensor characteristics. Memory leak happens if run twice or more.
v4l2-ctl -d /dev/video0 -p 67.200
v4l2-ctl -d /dev/video0 --stream-mmap=3 --stream-count=256 --set-fmt-video=width=2472,height=2064,pixelformat=GREY
Nvidia experts, can you provide a clean fix ?
Have a nice day
