We are currently facing an issue with our Kubernetes cluster following a recent power outage and would appreciate your assistance in restoring it.
Cluster Configuration :
- 1 x BCM Head Node
- 1 x K8s/Slurm Master Node (separate from head node)
- 3 x DGX H100 Worker Nodes
Issue Overview:
After the power outage, the entire cluster went down. We followed a sequential restart process—first powering on the master nodes, then the worker nodes.
However, we encountered the following issues:
Kubernetes Command Failure:
Running kubectl get nodes returned an error: “Could not get server API group list.”
Service Status Check:
Upon checking systemctl status for both kubelet and containerd, we found both services were inactive.
Kubelet was inactive because of missing config file /var/libkubelet -
Service Restart Attempt:
We attempted to bring the services up using the following commands:-
systemctl enable containerd
systemctl start containerd
kubeadm init phase kubelet-start
systemctl daemon-reexec
systemctl restart kubelet
containerd successfully started.
kubelet started initially but exited shortly afterward.
Kubelet Configuration Error:
We discovered that /var/lib/kubelet/config.yaml was missing.
After regenerating the configuration, kubelet failed again—this time due to inability to load the CA certificate from the expected location
After copying the required certificate to the location specified in the error, the service then threw a bootstrapping error, and we appear to be stuck in a loop. Can you please let me know if i am missing any steps to fix these .
