I am trying to use the L2 cache residency control CUDA API to accelerate my kernel program.
size_t num_megabytes_persistent_data{3};
cudaDeviceProp device_prop{};
int current_device{0};
CHECK_ERROR(cudaGetDevice(¤t_device));
CHECK_ERROR(cudaGetDeviceProperties(&device_prop, current_device));
std::cout << "GPU: " << device_prop.name << std::endl;
std::cout << "L2 Cache Size: " << device_prop.l2CacheSize / 1024 / 1024
<< " MB" << std::endl;
std::cout << "Max Persistent L2 Cache Size: "
<< device_prop.persistingL2CacheMaxSize / 1024 / 1024 << " MB"
<< std::endl;
size_t size = min(int(device_prop.l2CacheSize * 0.75), device_prop.persistingL2CacheMaxSize);
size_t const num_megabytes_persistent_cache{3};
/* Set aside max possible size of L2 cache for persisting accesses */
CHECK_ERROR(
cudaDeviceSetLimit(cudaLimitPersistingL2CacheSize,
num_megabytes_persistent_cache * 1024 * 1024));
std::cout << "Set persistent L2 cache size to "
<< num_megabytes_persistent_cache << " MB" << std::endl;
std::cout << "cudaLimitPersistingL2CacheSize: " << cudaLimitPersistingL2CacheSize << " MB"
<< std::endl;
// potentially thrashing stream
cudaStream_t stream_persistent_cache;
cudaStreamAttrValue stream_attribute_thrashing;
// stream_attribute_thrashing.accessPolicyWindow.base_ptr =
// reinterpret_cast<void*>(d_input_symbols);
// reinterpret_cast<void*>(d_active_state_list);
reinterpret_cast<void*>(d_reordered_csr_row_ptrs);
stream_attribute_thrashing.accessPolicyWindow.num_bytes =
num_megabytes_persistent_data * 1024 * 1024;
stream_attribute_thrashing.accessPolicyWindow.hitRatio = 1.0;
stream_attribute_thrashing.accessPolicyWindow.hitProp =
cudaAccessPropertyPersisting;
stream_attribute_thrashing.accessPolicyWindow.missProp =
cudaAccessPropertyNormal;
CHECK_ERROR(cudaStreamSetAttribute(
stream_persistent_cache, cudaStreamAttributeAccessPolicyWindow,
&stream_attribute_thrashing));
// no thrashing
cudaStreamAttrValue stream_attribute_non_thrashing{
stream_attribute_thrashing};
stream_attribute_non_thrashing.accessPolicyWindow.hitRatio =
std::min(static_cast<double>(num_megabytes_persistent_cache) /
num_megabytes_persistent_data,
1.0);
&stream_attribute_non_thrashing));
kernel <<<>>>(d_input_symbols, d_active_state_list, d_reordered_csr_row_ptrs);
However, I do not see any improvement when I change this binded data ptr to different input parameter buffers (d_input_symbols, d_active_state_list, d_reordered_csr_row_ptrs);
Basically, I am doing a SpMSpV-type computation.
I am wondering if I am using the L2 resicency technique correctly and how can I confirm if I am correct.
Is there any related PTX instruction that I can check in my compiled PTX program?
