L2 Hit Rate(Texture Reads) becomes 100% when modifying memory never used
I’m working on a microbenchmark to test if the L2 cache is inclusive or not. My GPU is GTX 960m(compute 5.0).
The program randomly accessed a pointer on device which was allocated with a block of memory(fit L2 2048KB), and modified the accessed value. The memory allocation is done by malloc() on the device so I think the memory is not cached but at the heap in device memory. All global functions are executed by a single thread in a single block(<<<1,1>>>).
However, when I profile the program by
nvprof -m l2_tex_read_hit_rate,l2_read_transactions,l2_write_transactions,tex_cache_transactions,global_hit_rate ./cache
, I get 100% L2 Hit Rate.
I tried to do following things:
  1. Increase the memory block size to make it larger than L2. However the L2 Hit Rate is still 100%
  2. Add “-O0 -g” when compiling. Still 100%
  3. Increase the number of threads. This makes L1 cache hit rate to increase. Before that the L1 cache hit rate was always 0% and I don’t know why, either…
  4. Input the size of memory block by scanf() to disable the potential constant folding. Still 100%
  5. Decrease the iteration time from 2048*1024/sizeof(int) to much smaller numbers… The L2 hit rate became lower(e.g. when iteration time is 8, the L2 hit rate became 75%…)
I suspect there is an unrevealed prefetching policy on L2, or malloc() on device triggers the cache which is different with CPUs. Does anyone ever encounter this? Many thanks!
The source code is https://github.com/SebastianElvis/gpu-benchmark/blob/master/src/cache.cu.
of the top of my head CC 5.0 doesn’t cache in L1 global data, but it cache local (stack) vars. This may the reason why L1 get hits only when you have more threads - there is not enough space in registers and local data are spilled into L1 cache
GPU caches never use hardware (automatic) prefetching, although GeForces support software prefetching via PTX command
you should look into PTX/SASS code. my understanding is that getVals is optimized out but setVals with large SIZE should have L2 cache misses
If you want to look at generated code, always look at SASS. Since PTX is compiled to SASS by an optimizing compiler (PTXAS), observations at the PTX level are largely meaningless, unless you are chasing a code generation issue in the NVVM portion of the compiler.
BTW, I wouldn’t be very surprised if prefetching instructions at PTX level turn into effective no-ops on some architectures (but I don’t have evidence one way or the other).
How do we know for certain that “GPU caches never use hardware (automatic) prefetching”? Did NVIDIA state this somewhere in official documentation?
why you think so? prefetching can substantially improves performance, given that memory latencies are hundreds cycles
just common sense - with thousands threads and small caches, there is only 1-10 KB of L2 cache per warp, which will be quickly filled by any prefetching, in many cases losing really useful data. There is a huge difference to CPUs that have ~ 1 MB cache/thread. The same applies to memory throughput - useless prefetching will take too much resources. Finally, it will require extra hardware - thousands prefetchers for thousands threads. GPUs don’t speculate, it’s their bonna motto.
Finally, NVidia and other GPU vendors never said about hardware prefetching, and I consider that as evidence that they don’t have one. Implementing prefetching and not talking about that is inefficient - it’s a part of microarchitecture that programmers should take into account when optimizing their programs. F.e. Intel discloses abilities of its hw prefetchers.
Just common sense. My recollection from being involved with building x86 processors is that prefetch instructions are fairly useless compared to hardware-based prefetching mechanisms (one issue: determining the “optimal” prefetching distance at compile time), and since memory bandwidth is often limited the load requests emanating from prefetch instructions may be treated as hints only, i.e. they result in actual memory reads only if there is still surplus bandwidth available.
My experience from experimenting with prefetch instructions when they first appeared in GPUs was that they were almost always unable to boost performance. I recall only one (maybe two) cases where there was an improvement outside measurement noise level (2%). Your mileage may vary, and I would certainly be interested in seeing real-life CUDA kernels where the use of prefetch instructions results in a reproducable performance enhancement on one of the modern architectures (that is, Maxwell or newer).
Since PTX is a portable code representation, one cannot remove instructions added to that virtual ISA, but it is possible to eliminate them during translation to SASS if they serve no useful purpose on a particular architecture.
Regarding OP’s posting, it is as BulatZiganshin said.
The getVals kernel is entirely optimized out (I am assuming we are building without debug switches)
For me, the getVals kernel profiles with a 0% hitrate, not 100%. The setVals kernel profiles with 57% read hit rate.
$ cat t59.cu
#include <stdio.h>
#include <stdlib.h>
#include <curand.h>
#include <curand_kernel.h>
#define SIZE (2048*1024/sizeof(int))
__device__ int *nonce;
// called by host, executed by GPU
__global__ void init() {
        nonce = (int *)malloc(SIZE*sizeof(int));
__global__ void setVals() {
        curandState_t state;
        /* we have to initialize the state */
        curand_init(0, /* the seed controls the sequence of random values that are produced */
                          0, /* the sequence number is only important with multiple cores */
                          0, /* the offset is how much extra we advance in the sequence for each call, can be 0 */
                          &state);
        for(int i=0;i<SIZE;i++){
                int r = curand(&state) % SIZE;
                //printf("%d ", r);
                *(nonce+r) = i;
__global__ void getVals() {
        int j;
                j = *(nonce+i);
                //printf("%d ", j);
int main(void) {
        //printf("%d\n", sizeof(int));
        init<<<1, 1>>>();
        getVals<<<1, 1>>>();
        setVals<<<1, 1>>>();
        return 0;
$ nvcc -arch=sm_60 -o t59 t59.cu -lcurand
t59.cu(41): warning: variable "j" was set but never used
$ cuobjdump -sass ./t59
Fatbin elf code:
arch = sm_60
code version = [1,7]
producer = <unknown>
host = linux
compile_size = 64bit
        code for sm_60
Fatbin elf code:
arch = sm_60
producer = cuda
host = linux
        code for sm_60
                Function : _Z7getValsv
        .headerflags    @"EF_CUDA_SM60 EF_CUDA_PTX_SM(EF_CUDA_SM60)"
                                                          /* 0x001fbc00fde007f6 */
        /*0008*/                   MOV R1, c[0x0][0x20];  /* 0x4c98078000870001 */
        /*0010*/                   NOP;                   /* 0x50b0000000070f00 */
        /*0018*/                   NOP;                   /* 0x50b0000000070f00 */
                                                          /* 0x001ffc00ffe007ed */
        /*0028*/                   NOP;                   /* 0x50b0000000070f00 */
        /*0030*/                   EXIT;                  /* 0xe30000000007000f */
        /*0038*/                   BRA 0x38;              /* 0xe2400fffff87000f */
                Function : _Z7setValsv
        /* 0x001fc400fe2007f6 */
        /*0010*/                   MOV R4, RZ;                                 /* 0x5c9807800ff70004 */
        /*0018*/                   MOV32I R12, 0x58213ed2;                     /* 0x01058213ed27f00c */
        /* 0x001fc400fe2007f1 */
        /*0028*/                   MOV32I R11, 0x455f2458;                     /* 0x010455f24587f00b */
        /*0030*/                   MOV32I R10, 0xf8a42704;                     /* 0x010f8a427047f00a */
        /*0038*/                   MOV32I R9, 0xdcd8f87c;                      /* 0x010dcd8f87c7f009 */
        /* 0x001f8400fec007e1 */
        /*0048*/                   MOV32I R8, 0x511db0d6;                      /* 0x010511db0d67f008 */
        /*0050*/                   MOV R0, RZ;                                 /* 0x5c9807800ff70000 */
        /*0058*/                   MOV32I R2, 0x0;                             /* 0x010000000007f002 */
        /* 0x001f98000e2007e2 */
        /*0068*/                   MOV32I R3, 0x0;                             /* 0x010000000007f003 */
        /*0070*/                   LDG.E.64 R6, [R2];                          /* 0xeed5200000070206 */
        /*0078*/                   SHR.U32 R5, R12, 0x2;                       /* 0x3828000000270c05 */
        /* 0x001f9400fe2007f6 */
        /*0088*/                   LOP.XOR R5, R5, R12;                        /* 0x5c47040000c70505 */
        /*0090*/                   SHL R14, R5, 0x1;                           /* 0x384800000017050e */
        /*0098*/                   SHL R12, R8, 0x4;                           /* 0x384800000047080c */
        /* 0x001f9800fec007e6 */
        /*00a8*/                   LOP3.LUT R5, R8, R14, R5, 0x96;             /* 0x5be7028960e70805 */
        /*00b0*/                   LOP.XOR R5, R5, R12;                        /* 0x5c47040000c70505 */
        /*00b8*/                   IADD3 R12, R4, c[0x2][0x0], R5;             /* 0x4cc002880007040c */
        /* 0x011f9840fe2007f6 */
        /*00c8*/                   LOP32I.AND R12, R12, 0x7ffff;               /* 0x0400007ffff70c0c */
        /*00d0*/                   SHR.U32 R15, R12.reuse, 0x1e;               /* 0x3828000001e70c0f */
        /*00d8*/                   ISCADD R14.CC, R12, R6, 0x2;                /* 0x5c18810000670c0e */
        /* 0x0005c4001e2007e2 */
        /*00e8*/                   IADD.X R15, R7, R15;                        /* 0x5c10080000f7070f */
        /*00f0*/                   STG.E [R14], R0;                            /* 0xeedc200000070e00 */
        /*00f8*/                   LDG.E.64 R12, [R2];                         /* 0xeed520000007020c */
        /*0108*/                   SHR.U32 R6, R11, 0x2;                       /* 0x3828000000270b06 */
        /*0110*/                   LOP.XOR R6, R6, R11;                        /* 0x5c47040000b70606 */
        /*0118*/                   SHL R7, R6, 0x1;                            /* 0x3848000000170607 */
        /* 0x001fd800fcc207f1 */
        /*0128*/                   LOP3.LUT R7, R5.reuse, R7, R6, 0x96;        /* 0x5be7030960770507 */
        /*0130*/                   SHL R6, R5, 0x4;                            /* 0x3848000000470506 */
        /*0138*/                   LOP.XOR R6, R7, R6;                         /* 0x5c47040000670706 */
        /* 0x001f8400ffa007f6 */
        /*0148*/                   IADD3 R7, R4, c[0x2][0x4], R6;              /* 0x4cc0030800170407 */
        /*0150*/                   SHL R7, R7, 0x2;                            /* 0x3848000000270707 */
        /*0158*/                   LOP32I.AND R7, R7, 0x1ffffc;                /* 0x040001ffffc70707 */
        /* 0x001f8809fcc007e5 */
        /*0168*/                   IADD32I R11, R0, 0x1;                       /* 0x1c0000000017000b */
        /*0170*/                   IADD R14.CC, R12, R7;                       /* 0x5c10800000770c0e */
        /*0178*/                   IADD.X R15, RZ, R13;                        /* 0x5c10080000d7ff0f */
        /* 0x001f98002e2000f1 */
        /*0188*/                   STG.E [R14], R11;                           /* 0xeedc200000070e0b */
        /*0190*/                   LDG.E.64 R12, [R2];                         /* 0xeed520000007020c */
        /*0198*/                   SHR.U32 R7, R10, 0x2;                       /* 0x3828000000270a07 */
        /* 0x081fc400fcc007f6 */
        /*01a8*/                   LOP.XOR R7, R7, R10;                        /* 0x5c47040000a70707 */
        /*01b0*/                   SHL R16, R7, 0x1;                           /* 0x3848000000170710 */
        /*01b8*/                   LOP3.LUT R16, R6.reuse, R16, R7, 0x96;      /* 0x5be7038961070610 */
        /* 0x001fd800fec007e6 */
        /*01c8*/                   SHL R7, R6, 0x4;                            /* 0x3848000000470607 */
        /*01d0*/                   LOP.XOR R7, R16, R7;                        /* 0x5c47040000771007 */
        /*01d8*/                   IADD3 R10, R4, c[0x2][0x8], R7;             /* 0x4cc003880027040a */
        /* 0x003f9400fc2007fd */
        /*01e8*/                   SHL R10, R10, 0x2;                          /* 0x3848000000270a0a */
        /*01f0*/                   LOP32I.AND R10, R10, 0x1ffffc;              /* 0x040001ffffc70a0a */
        /*01f8*/                   IADD32I R14, R0, 0x2;                       /* 0x1c0000000027000e */
        /* 0x0003c400fc4047e6 */
        /*0208*/                   IADD R12.CC, R12, R10;                      /* 0x5c10800000a70c0c */
        /*0210*/                   IADD.X R13, RZ, R13;                        /* 0x5c10080000d7ff0d */
        /*0218*/                   STG.E [R12], R14;                           /* 0xeedc200000070c0e */
        /* 0x001fd800fcc00171 */
        /*0228*/                   LDG.E.64 R10, [R2];                         /* 0xeed520000007020a */
        /*0230*/                   SHR.U32 R15, R9, 0x2;                       /* 0x382800000027090f */
        /*0238*/                   LOP.XOR R9, R15, R9;                        /* 0x5c47040000970f09 */
        /* 0x001f9840fe2007e6 */
        /*0248*/                   SHL R16, R9, 0x1;                           /* 0x3848000000170910 */
        /*0250*/                   LOP3.LUT R16, R7.reuse, R16, R9, 0x96;      /* 0x5be7048961070710 */
        /*0258*/                   SHL R9, R7, 0x4;                            /* 0x3848000000470709 */
        /* 0x001ff400fec007f6 */
        /*0268*/                   LOP.XOR R9, R16, R9;                        /* 0x5c47040000971009 */
        /*0270*/                   IADD3 R15, R4, c[0x2][0xc], R9;             /* 0x4cc004880037040f */
        /*0278*/                   SHL R15, R15, 0x2;                          /* 0x3848000000270f0f */
        /* 0x011f9801fca007e1 */
        /*0288*/                   LOP32I.AND R15, R15, 0x1ffffc;              /* 0x040001ffffc70f0f */
        /*0290*/                   IADD32I R12, R0, 0x3;                       /* 0x1c0000000037000c */
        /*0298*/                   IADD R14.CC, R10, R15;                      /* 0x5c10800000f70a0e */
        /*02a8*/                   IADD.X R15, RZ, R11;                        /* 0x5c10080000b7ff0f */
        /*02b0*/                   STG.E [R14], R12;                           /* 0xeedc200000070e0c */
        /*02b8*/                   LDG.E.64 R10, [R2];                         /* 0xeed520000007020a */
        /* 0x001fc400fec007e6 */
        /*02c8*/                   SHR.U32 R13, R8, 0x2;                       /* 0x382800000027080d */
        /*02d0*/                   LOP.XOR R8, R13, R8;                        /* 0x5c47040000870d08 */
        /*02d8*/                   SHL R18, R8, 0x1;                           /* 0x3848000000170812 */
        /* 0x001fd800fcc007e5 */
        /*02e8*/                   SHL R13, R9, 0x4;                           /* 0x384800000047090d */
        /*02f0*/                   LOP3.LUT R8, R9, R18, R8, 0x96;             /* 0x5be7040961270908 */
        /*02f8*/                   LOP.XOR R13, R8, R13;                       /* 0x5c47040000d7080d */
        /* 0x001f9800ffa007f6 */
        /*0308*/                   IADD3 R8, R4, c[0x2][0x10], R13;            /* 0x4cc0068800470408 */
        /*0310*/                   SHL R8, R8, 0x2;                            /* 0x3848000000270808 */
        /*0318*/                   LOP32I.AND R8, R8, 0x1ffffc;                /* 0x040001ffffc70808 */
        /* 0x001f8800fca04fe1 */
        /*0328*/                   IADD R14.CC, R10, R8;                       /* 0x5c10800000870a0e */
        /*0330*/                   IADD32I R8, R0, 0x4;                        /* 0x1c00000000470008 */
        /*0338*/                   IADD.X R15, RZ, R11;                        /* 0x5c10080000b7ff0f */
        /*0348*/                   STG.E [R14], R8;                            /* 0xeedc200000070e08 */
        /*0350*/                   LDG.E.64 R10, [R2];                         /* 0xeed520000007020a */
        /*0358*/                   SHR.U32 R12, R5, 0x2;                       /* 0x382800000027050c */
        /*0368*/                   LOP.XOR R12, R12, R5;                       /* 0x5c47040000570c0c */
        /*0370*/                   SHL R18, R12, 0x1;                          /* 0x3848000000170c12 */
        /*0378*/                   SHL R5, R13, 0x4;                           /* 0x3848000000470d05 */
        /* 0x001ff400fec007e6 */
        /*0388*/                   LOP3.LUT R12, R13, R18, R12, 0x96;          /* 0x5be7060961270d0c */
        /*0390*/                   LOP.XOR R5, R12, R5;                        /* 0x5c47040000570c05 */
        /*0398*/                   IADD3 R12, R4, c[0x2][0x14], R5;            /* 0x4cc002880057040c */
        /* 0x003f9400fc2007e6 */
        /*03a8*/                   SHL R12, R12, 0x2;                          /* 0x3848000000270c0c */
        /*03b0*/                   LOP32I.AND R12, R12, 0x1ffffc;              /* 0x040001ffffc70c0c */
        /*03b8*/                   IADD32I R8, R0, 0x5;                        /* 0x1c00000000570008 */
        /*03c8*/                   IADD R14.CC, R10, R12;                      /* 0x5c10800000c70a0e */
        /*03d0*/                   IADD.X R15, RZ, R11;                        /* 0x5c10080000b7ff0f */
        /*03d8*/                   STG.E [R14], R8;                            /* 0xeedc200000070e08 */
        /*03e8*/                   LDG.E.64 R10, [R2];                         /* 0xeed520000007020a */
        /*03f0*/                   SHR.U32 R12, R6, 0x2;                       /* 0x382800000027060c */
        /*03f8*/                   LOP.XOR R6, R12, R6;                        /* 0x5c47040000670c06 */
        /*0408*/                   SHL R12, R6, 0x1;                           /* 0x384800000017060c */
        /*0410*/                   LOP3.LUT R12, R5.reuse, R12, R6, 0x96;      /* 0x5be7030960c7050c */
        /*0418*/                   SHL R6, R5, 0x4;                            /* 0x3848000000470506 */
        /*0428*/                   LOP.XOR R6, R12, R6;                        /* 0x5c47040000670c06 */
        /*0430*/                   IADD3 R12, R4, c[0x2][0x18], R6;            /* 0x4cc003080067040c */
        /*0438*/                   SHL R12, R12, 0x2;                          /* 0x3848000000270c0c */
        /*0448*/                   LOP32I.AND R12, R12, 0x1ffffc;              /* 0x040001ffffc70c0c */
        /*0450*/                   IADD32I R8, R0, 0x6;                        /* 0x1c00000000670008 */
        /*0458*/                   IADD R10.CC, R10, R12;                      /* 0x5c10800000c70a0a */
        /* 0x001dc4001e2007e2 */
        /*0468*/                   IADD.X R11, RZ, R11;                        /* 0x5c10080000b7ff0b */
        /*0470*/                   STG.E [R10], R8;                            /* 0xeedc200000070a08 */
        /*0478*/                   LDG.E.64 R2, [R2];                          /* 0xeed5200000070202 */
        /*0488*/                   SHR.U32 R12, R7, 0x2;                       /* 0x382800000027070c */
        /*0490*/                   LOP.XOR R7, R12, R7;                        /* 0x5c47040000770c07 */
        /*0498*/                   SHL R12, R7, 0x1;                           /* 0x384800000017070c */
        /*04a8*/                   LOP3.LUT R12, R6.reuse, R12, R7, 0x96;      /* 0x5be7038960c7060c */
        /*04b0*/                   SHL R7, R6, 0x4;                            /* 0x3848000000470607 */
        /*04b8*/                   LOP.XOR R7, R12, R7;                        /* 0x5c47040000770c07 */
        /* 0x001fc401fea007e1 */
        /*04c8*/                   IADD3 R12, R4, c[0x2][0x1c], R7;            /* 0x4cc003880077040c */
        /*04d0*/                   IADD32I R8, R0, 0x8;                        /* 0x1c00000000870008 */
        /*04d8*/                   SHL R12, R12, 0x2;                          /* 0x3848000000270c0c */
        /* 0x001f8400fc2007e5 */
        /*04e8*/                   ISETP.NE.AND P0, PT, R8, c[0x2][0x20], PT;  /* 0x4b6b038800870807 */
        /*04f0*/                   LOP32I.AND R12, R12, 0x1ffffc;              /* 0x040001ffffc70c0c */
        /*04f8*/                   IADD32I R15, R0, 0x7;                       /* 0x1c0000000077000f */
        /* 0x001f8400fc2007e1 */
        /*0508*/                   MOV R0, R8;                                 /* 0x5c98078000870000 */
        /*0510*/                   MOV R11, R13;                               /* 0x5c98078000d7000b */
        /*0518*/                   MOV R10, R5;                                /* 0x5c9807800057000a */
        /* 0x011f8400fc4007e1 */
        /*0528*/                   MOV R8, R7;                                 /* 0x5c98078000770008 */
        /*0530*/                   IADD32I R4, R4, 0x2c3e28;                   /* 0x1c0002c3e2870404 */
        /*0538*/                   IADD R2.CC, R2, R12;                        /* 0x5c10800000c70202 */
        /* 0x001f9c00fc8007e1 */
        /*0548*/                   MOV R12, R9;                                /* 0x5c9807800097000c */
        /*0550*/                   MOV R9, R6;                                 /* 0x5c98078000670009 */
        /*0558*/                   IADD.X R3, RZ, R3;                          /* 0x5c1008000037ff03 */
        /* 0x001ffc01ffa000fd */
        /*0568*/                   STG.E [R2], R15;                            /* 0xeedc20000007020f */
        /*0570*/               @P0 BRA 0x58;                                   /* 0xe2400fffae00000f */
        /*0578*/                   EXIT;                                       /* 0xe30000000007000f */
        /* 0x001f8000fc0007ff */
        /*0588*/                   BRA 0x580;                                  /* 0xe2400fffff07000f */
        /*0590*/                   NOP;                                        /* 0x50b0000000070f00 */
        /*0598*/                   NOP;                                        /* 0x50b0000000070f00 */
        /* 0x001f8000fc0007e0 */
        /*05a8*/                   NOP;                                        /* 0x50b0000000070f00 */
        /*05b0*/                   NOP;                                        /* 0x50b0000000070f00 */
        /*05b8*/                   NOP;                                        /* 0x50b0000000070f00 */
                Function : _Z4initv
                                                          /* 0x001fd800fe2007f6 */
        /*0010*/                   MOV32I R4, 0x200000;   /* 0x010002000007f004 */
        /*0018*/                   MOV R5, RZ;            /* 0x5c9807800ff70005 */
                                                          /* 0x001fc800fe2007fd */
        /*0028*/                   JCAL 0x0;              /* 0xe220000000000040 */
        /*0030*/                   MOV32I R2, 0x0;        /* 0x010000000007f002 */
        /*0038*/                   MOV32I R3, 0x0;        /* 0x010000000007f003 */
                                                          /* 0x001fac00fde000f1 */
        /*0048*/                   STG.E.64 [R2], R4;     /* 0xeedd200000070204 */
        /*0050*/                   NOP;                   /* 0x50b0000000070f00 */
        /*0058*/                   NOP;                   /* 0x50b0000000070f00 */
                                                          /* 0x001f8000ffe007ff */
        /*0068*/                   EXIT;                  /* 0xe30000000007000f */
        /*0070*/                   BRA 0x70;              /* 0xe2400fffff87000f */
        /*0078*/                   NOP;                   /* 0x50b0000000070f00 */
Fatbin ptx code:
arch = sm_60
code version = [6,1]
producer = cuda
host = linux
compressed
$ nvprof -m l2_tex_read_hit_rate,l2_read_transactions,l2_write_transactions,tex_cache_transactions,global_hit_rate ./t59
==24000== NVPROF is profiling process 24000, command: ./t59
==24000== Some kernel(s) will be replayed on device 0 in order to collect all events/metrics.
Replaying kernel "init(void)" (done)
Replaying kernel "getVals(void)" (done)
Replaying kernel "setVals(void)" (done)
==24000== Profiling application: ./t59
==24000== Profiling result:ector_queries
==24000== Metric result:
Invocations                               Metric Name                        Metric Description         Min         Max         Avg
Device "Tesla P100-PCIE-16GB (0)"
    Kernel: getVals(void)
          1                      l2_tex_read_hit_rate               L2 Hit Rate (Texture Reads)       0.00%       0.00%       0.00%
          1                      l2_read_transactions                      L2 Read Transactions           8           8           8
          1                     l2_write_transactions                     L2 Write Transactions          13          13          13
          1                    tex_cache_transactions                Unified Cache Transactions           0           0           0
          1                           global_hit_rate         Global Hit Rate in unified l1/tex       0.00%       0.00%       0.00%
    Kernel: init(void)
          1                      l2_tex_read_hit_rate               L2 Hit Rate (Texture Reads)      57.63%      57.63%      57.63%
          1                      l2_read_transactions                      L2 Read Transactions         297         297         297
          1                     l2_write_transactions                     L2 Write Transactions          72          72          72
          1                    tex_cache_transactions                Unified Cache Transactions          63          63          63
    Kernel: setVals(void)
          1                      l2_read_transactions                      L2 Read Transactions        1417        1417        1417
          1                     l2_write_transactions                     L2 Write Transactions      584825      584825      584825
          1                    tex_cache_transactions                Unified Cache Transactions     1048576     1048576     1048576
          1                           global_hit_rate         Global Hit Rate in unified l1/tex     100.00%     100.00%     100.00%
CUDA 9.1, CentOS 7.4, Tesla P100PCIE
A small change to getVals like so:
        int j = 1;
                j += *(nonce+i);
        if (j==0) printf("%d \n", j);
avoids the unwanted compiler optimization
profiling that case produces:
==24549== NVPROF is profiling process 24549, command: ./t59
==24549== Some kernel(s) will be replayed on device 0 in order to collect all events/metrics.
==24549== Profiling application: ./t59
==24549== Profiling result:it_sectors
==24549== Metric result:
          1                      l2_read_transactions                      L2 Read Transactions       65953       65953       65953
          1                    tex_cache_transactions                Unified Cache Transactions      524290      524290      524290
          1                           global_hit_rate         Global Hit Rate in unified l1/tex      87.50%      87.50%      87.50%
    Kernel: init(void)
          1                      l2_read_transactions                      L2 Read Transactions         305         305         305
          1                      l2_read_transactions                      L2 Read Transactions        1337        1337        1337
the numbers now look fairly sensible to me, although I haven’t studied it closely.
Dude, you got similar results as me… The 57% read hit rate is for init(), and I got 0% L2 hit rate for getVals() as well, but 0% l1/tex hit rate(yours is 87.50%)…
I think that getVals() is totally optimized out, too. It seems that your data go into L1/tex very often but pass L2 when executing getVals(). This is plausible because l1/tex is read-only.
My result is
➜  src git:(master) ✗ nvcc -arch=sm_50 cache.cu -o cache -g
➜  src git:(master) ✗ nvprof -m l2_tex_read_hit_rate,l2_read_transactions,l2_write_transactions,tex_cache_transactions,global_hit_rate ./cache
==15414== NVPROF is profiling process 15414, command: ./cache
==15414== Some kernel(s) will be replayed on device 0 in order to collect all events/metrics.
Replaying kernel "init(int)" (done)
Replaying kernel "getVals(int)" (done)
Replaying kernel "setVals(int)" (done)
==15414== Profiling application: ./cache
==15414== Profiling result:
==15414== Metric result:
Device "GeForce GTX 960M (0)"
    Kernel: init(int)
          1                      l2_tex_read_hit_rate               L2 Hit Rate (Texture Reads)      60.66%      60.66%      60.66%
          1                      l2_read_transactions                      L2 Read Transactions         274         274         274
          1                     l2_write_transactions                     L2 Write Transactions          64          64          64
    Kernel: setVals(int)
          1                      l2_tex_read_hit_rate               L2 Hit Rate (Texture Reads)     100.00%     100.00%     100.00%
          1                      l2_read_transactions                      L2 Read Transactions      524551      524551      524551
          1                     l2_write_transactions                     L2 Write Transactions      524311      524311      524311
    Kernel: getVals(int)
          1                      l2_read_transactions                      L2 Read Transactions          24          24          24
          1                     l2_write_transactions                     L2 Write Transactions           6           6           6
What do you think about the difference of L2 cache access behaviour between us?
Do you mean those messy variables like state/rand/size… fill the registers with more threads? This sounds as expected. Therefore, L1/tex will be utilized only when local variables fill registers, is this right? And variables in heap will never be cached by L1/tex?
However, according to Maxwell tuning guide, L1/tex will only cache read-only data, but I suppose those local variables are changed frequently. Why L1/tex transactions happen that frequently?
And the guide says that local loads are cached in L2 only, but your theory and my testing result does not behave like that. Do I get wrong with the documentation? It is as expected if L1/tex caches local loads but does not cache global loads. Thank you!
