Hello everyone,
I have a question regarding how to determine the number of sectors for the L2 cache.
My assumption was that L2 sectors should correspond to the L1 misses, which I tried to represent using these metrics:
lts__t_sectors_srcunit_tex_op_read.sumlts__t_sectors_srcunit_tex_op_write.sum
However, when I compare these numbers, things don’t add up. Here’s what I’m seeing:
lts__t_sectors_srcunit_tex_op_read.sum (sector) 2,073,756
lts__t_sectors_srcunit_tex_op_write.sum (sector) 16,808,976
lts__t_sector_hit_rate.pct (%) 99.37
lts__t_sectors.sum (sector) 27,430,992
The total number of L2 sectors (lts__t_sectors.sum) is much larger than the sum of L1 read and write misses. I also found another metric:
lts__t_sectors_lookup_hit.sum (sector) 27,258,385
This value is also much larger than the sum of L1 read and write misses.
Can anyone explain why these metrics are so different? Why is the total number of sectors and sector hits at L2 much higher than what I would expect from just the L1 misses (reads and writes)? Is there something I’m misunderstanding about how these metrics are calculated or what they represent?
Thank you in advance for any insights!
