L4t 32.7.1 jetson-disk-image-creator.sh no support to jetson nano 2G revision A02?
Hi I’ve been creating a custom image for my jetson nano 2G using this repository here. I had to make a fork etc to use bionic.
I’ve been using until version L4T 32.3.1 jetson-disk-image-creator.sh from Linux_for_Tegra/tools/ to create a SD card image from rootfs without problems. Where I used -b jetson-nano -r 200 for my jetson-nano 2G A02 revision.
It is impossible I see to use this configuration on more recent versions where it’s assumed that all 2G jetson-nano are B01 revisions. For example for the same tool for l4t 32.7.1 I cannot set the revision option where its fixed as -r 300 in the script.
I am doing something wrong or missing some point? Is there any other way to still use this tool?
Thanks for any help.
Did you try this?
-b jetson-nano-2gb-devkit
without -r <rev>
Hi eusoubrasileiro,
Please run below command to create SD image on Nano-2GB:
$ sudo ./tools/jetson-disk-image-creator.sh -o Nano2GB.img -b jetson-nano-2gb-devkit -r 300
Didn’t know -r 300 worked for jetson-nano 2G A02. Though was only for B01 etc. Thanks a lot!
