L4T 35.4.1 on Seedstudio Orin NX
I’m trying to run the latest L4T v. 35.4.1 on the Seedstudio Orin NX (J4012).
It freezes after bootup with the following message (from serial console):
[   17.507421] CPU:0, Error: dce-fabric@0xde00000, irq=28
[   17.512718] **************************************
[   17.517646] CPU:0, Error:dce-fabric, Errmon:2
[   17.522141]    Error Code            : SLAVE_ERR
[   17.525998]    Overflow              : Multiple SLAVE_ERR
[   17.530484]
[   17.532014]    Error Code            : SLAVE_ERR
[   17.535873]    MASTER_ID             : DCE
[   17.539101]    Address               : 0x2212000
[   17.542691]    Cache                 : 0x1 -- Bufferable
[   17.546988]    Protection            : 0x3 -- Privileged, Non-Secure, Data Access
[   17.553803]    Access_Type           : Read
[   17.557290]    Access_ID             : 0x0
[   17.557291]    Fabric                : dce-fabric
[   17.564101]    Slave_Id              : 0x3b
[   17.567321]    Burst_length          : 0x0
[   17.570815]    Burst_type            : 0x1
[   17.574133]    Beat_size             : 0x2
[   17.577358]    VQC                   : 0x0
[   17.580142]    GRPSEC                : 0x3f
[   17.583195]    FALCONSEC             : 0x0
No monitors or other peripherals are attached.
It doesn’t need any custom BCPs, the flashing command is
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 \
  -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
  --showlogs --network usb0 p3509-a02+p3767-0000 internal
L4T 35.3.1 worked fine without any problems. What can I do to solve this problem?
Sorry, we just noticed this bug when HDMI is enabled.
Added an info in the release note for bypass it.
