Hi!
Is there any way in CUDA to count with larger integer than 64bit?
If its possible can you give me instructions how can I do this?
Hi!
(unsigned) long long int provides 64-bits. There is no built-in non-vector integer type that is wider than 64 bits. However, you could easily build your own 128-bit integer type. For example:
typedef struct {
unsigned long long int lo;
unsigned long long int hi;
} my_uint128;
my_uint128 add_uint128 (my_uint128 a, my_uint128 b)
my_uint128 res;
res.lo = a.lo + b.lo;
res.hi = a.hi + b.hi + (res.lo < a.lo);
return res;
If a higher performance solution is desired, consider mapping a 128-bit integer to a uint4 and using inline PTX for more efficient handling of the carries between the four 32-bit chunks.
Thats exactly what I want. Thank you very much!
More questions: :-)
1.How can I display in decimal number system?
cudaMalloc( (void**)&deviceArray, (N * sizeof(my_uint128)) )
Your malloc() call looks OK. Here is some code that does conversions. This is rather simplistic and will not win any speed records, and it does not provide industrial-strength robustness (for example, conversion from my_uint128 is limited to numbers < 10**38 instead of the full range). But it should be sufficient as a starting point for your own work.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#define TRIALS 1000000
typedef struct {
} my_uint128;
my_uint128 add_my_uint128 (my_uint128 a, my_uint128 b)
my_uint128 res;
return res;
my_uint128 sub_my_uint128 (my_uint128 a, my_uint128 b)
my_uint128 res;
res.lo = a.lo - b.lo;
res.hi = a.hi - b.hi - (res.lo > a.lo);
return res;
my_uint128 shl_my_uint128 (my_uint128 a, int s)
if (s) {
a.hi = (a.hi << s) | (a.lo >> (64 - s));
a.lo = a.lo << s;
return a;
my_uint128 mul10_my_uint128 (my_uint128 a)
my_uint128 s, t;
s = shl_my_uint128 (a, 3);
t = shl_my_uint128 (a, 1);
return add_my_uint128 (s, t);
static const my_uint128 pwrten [] =
{0x0000000000000001, 0x0000000000000000}, /* 10**0 */
{0x000000000000000a, 0x0000000000000000}, /* 10**1 */
{0x0000000000000064, 0x0000000000000000}, /* 10**2 */
{0x00000000000003e8, 0x0000000000000000}, /* 10**3 */
{0x0000000000002710, 0x0000000000000000}, /* 10**4 */
{0x00000000000186a0, 0x0000000000000000}, /* 10**5 */
{0x00000000000f4240, 0x0000000000000000}, /* 10**6 */
{0x0000000000989680, 0x0000000000000000}, /* 10**7 */
{0x0000000005f5e100, 0x0000000000000000}, /* 10**8 */
{0x000000003b9aca00, 0x0000000000000000}, /* 10**9 */
{0x00000002540be400, 0x0000000000000000}, /* 10**10 */
{0x000000174876e800, 0x0000000000000000}, /* 10**11 */
{0x000000e8d4a51000, 0x0000000000000000}, /* 10**12 */
{0x000009184e72a000, 0x0000000000000000}, /* 10**13 */
{0x00005af3107a4000, 0x0000000000000000}, /* 10**14 */
{0x00038d7ea4c68000, 0x0000000000000000}, /* 10**15 */
{0x002386f26fc10000, 0x0000000000000000}, /* 10**16 */
{0x016345785d8a0000, 0x0000000000000000}, /* 10**17 */
{0x0de0b6b3a7640000, 0x0000000000000000}, /* 10**18 */
{0x8ac7230489e80000, 0x0000000000000000}, /* 10**19 */
{0x6bc75e2d63100000, 0x0000000000000005}, /* 10**20 */
{0x35c9adc5dea00000, 0x0000000000000036}, /* 10**21 */
{0x19e0c9bab2400000, 0x000000000000021e}, /* 10**22 */
{0x02c7e14af6800000, 0x000000000000152d}, /* 10**23 */
{0x1bcecceda1000000, 0x000000000000d3c2}, /* 10**24 */
{0x161401484a000000, 0x0000000000084595}, /* 10**25 */
{0xdcc80cd2e4000000, 0x000000000052b7d2}, /* 10**26 */
{0x9fd0803ce8000000, 0x00000000033b2e3c}, /* 10**27 */
{0x3e25026110000000, 0x00000000204fce5e}, /* 10**28 */
{0x6d7217caa0000000, 0x00000001431e0fae}, /* 10**29 */
{0x4674edea40000000, 0x0000000c9f2c9cd0}, /* 10**30 */
{0xc0914b2680000000, 0x0000007e37be2022}, /* 10**31 */
{0x85acef8100000000, 0x000004ee2d6d415b}, /* 10**32 */
{0x38c15b0a00000000, 0x0000314dc6448d93}, /* 10**33 */
{0x378d8e6400000000, 0x0001ed09bead87c0}, /* 10**34 */
{0x2b878fe800000000, 0x0013426172c74d82}, /* 10**35 */
{0xb34b9f1000000000, 0x00c097ce7bc90715}, /* 10**36 */
{0x00f436a000000000, 0x0785ee10d5da46d9}, /* 10**37 */
#define MAX_PWR ((int)(sizeof(pwrten)/sizeof(pwrten[0]))-1)
#define DIGITS (MAX_PWR+1)
void cvt_my_uint128_to_str (my_uint128 a, char *cp)
my_uint128 t;
int pwr, bit, non_zero, digit, remainder_neg;
non_zero = 0;
for (pwr = MAX_PWR; pwr >= 0; pwr--) {
digit = 0;
for (bit = 3; bit >= 0; bit--) {
t = shl_my_uint128 (pwrten[pwr], bit);
a = sub_my_uint128 (a, t);
remainder_neg = ((long long int)a.hi) < 0;
digit = (digit << 1) | !remainder_neg;
if (remainder_neg) {
a = add_my_uint128 (a, t);
non_zero |= digit;
if (non_zero || pwr == 0) {
*cp++ = '0' + digit;
*cp = 0;
my_uint128 cvt_str_to_my_uint128 (char *cp)
my_uint128 a = {0, 0};
my_uint128 t = {0, 0};
while (*cp) {
a = mul10_my_uint128 (a);
t.lo = *cp++ - '0';
return a;
void rand_num_str (char *cp, int digits)
int i;
for (i = 0; i < digits; i++) {
*cp++ = '0' + ((i) ? (rand() % 10) : (rand() % 9 + 1));
*cp = 0;
int main (void)
my_uint128 a;
int i;
char in_str[DIGITS+1];
char out_str[DIGITS+1];
int errors = 0;
printf ("^^^^ DIGITS=%d\n", DIGITS);
for (i = 0; i < TRIALS; i++) {
rand_num_str (in_str, DIGITS);
a = cvt_str_to_my_uint128 (in_str);
cvt_my_uint128_to_str (a, out_str);
if (strcmp (in_str, out_str) != 0) {
printf ("!!!! error: in_str = %s out_str=%s\n", in_str, out_str);
errors++;
printf ("@@@@ %d errors in %d trials\n", errors, TRIALS);
printf ("&&&& my_uint128 conversion test %s\n", errors ? "FAILED":"PASSED");
return EXIT_SUCCESS;
Works fine! :D
You helped me a lot.
Have you considered to use logarithms?
