• Hardware Platform (Jetson / GPU): Jetson AGX Xavier
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4.1
• TensorRT Version: 7.1.3
• Issue Type( questions, new requirements, bugs): question
I have a custom pipeline that look like this:
[camera source source-bin 0] \ --> queue --> app_sink
--> streammuxer -> PGIE -> Tracker -> Tee --> queue --> tiler --> osd --> [...] --> udp_sink
[camera source source-bin 1] / --> queue --> msgconv --> msgbroker
Use the code here Enable Latency measurement for deepstream sample apps to add latency measurement to my pipeline:
typedef struct {
GMutex *lock;
int num_sources;
} LatencyCtx;
static GstPadProbeReturn
latency_measurement_buf_prob(GstPad *pad, GstPadProbeInfo *info, gpointer u_data)
LatencyCtx *ctx = (LatencyCtx *)u_data;
static int batch_num = 0;
guint i = 0, num_sources_in_batch = 0;
if (nvds_enable_latency_measurement)
GstBuffer *buf = (GstBuffer *)info->data;
NvDsFrameLatencyInfo *latency_info = NULL;
g_mutex_lock(ctx->lock);
latency_info = (NvDsFrameLatencyInfo *) calloc(1, ctx->num_sources * sizeof(NvDsFrameLatencyInfo));
g_print("\n************BATCH-NUM = %d**************\n", batch_num);
num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
for (i = 0; i < num_sources_in_batch; i++)
g_print("Source id = %d Frame_num = %d Frame latency = %lf (ms) \n",
latency_info[i].source_id,
latency_info[i].frame_num,
latency_info[i].latency);
g_mutex_unlock(ctx->lock);
batch_num++;
return GST_PAD_PROBE_OK;
[main function]
test_pad = gst_element_get_static_pad(<element>, "sink");
if (!test_pad)
g_print("Unable to get sink pad\n");
else
LatencyCtx *latency_ctx = (LatencyCtx *)g_malloc0(sizeof(LatencyCtx));
latency_ctx->lock = (GMutex *)g_malloc0(sizeof(GMutex));
latency_ctx->num_sources = NUM_SOURCES;
gst_pad_add_probe(test_pad, GST_PAD_PROBE_TYPE_BUFFER, latency_measurement_buf_prob, latency_ctx, NULL);
gst_object_unref(test_pad);
[main function]
- If
<element>is app_sink:
************BATCH-NUM = 5**************
Comp name = stream_muxer in_system_timestamp = 1607707499472.683105 out_system_timestamp = 1607707499525.270996 component latency= 52.587891
Comp name = stream_muxer in_system_timestamp = 1607707499472.512939 out_system_timestamp = 1607707499525.270996 component latency= 52.758057
Comp name = primary-nvinference-engine in_system_timestamp = 1607707499525.291992 out_system_timestamp = 1607707499553.311035 component latency= 28.019043
Comp name = tracker in_system_timestamp = 1607707499553.326904 out_system_timestamp = 1607707499602.200928 component latency= 48.874023
Comp name = nvtiler in_system_timestamp = 1607707499602.334961 out_system_timestamp = 0.000000 component latency= -1607707499602.334961
We have weird value like -1607707499602.334961
- If
<element>is udp_sink:
************BATCH-NUM = 0**************
Batch meta not found for buffer 0x7ec41f2280
- If
<element>is msgbroker:
Comp name = stream_muxer in_system_timestamp = 1607707850898.555908 out_system_timestamp = 1607707850910.142090 component latency= 11.586182
Comp name = stream_muxer in_system_timestamp = 1607707850900.982910 out_system_timestamp = 1607707850910.142090 component latency= 9.159180
Comp name = primary-nvinference-engine in_system_timestamp = 1607707850910.233887 out_system_timestamp = 1607707850990.382080 component latency= 80.148193
Comp name = tracker in_system_timestamp = 1607707850990.418945 out_system_timestamp = 1607707851408.416992 component latency= 417.998047
Comp name = nvtiler in_system_timestamp = 1607707851408.538086 out_system_timestamp = 0.000000 component latency= -1607707851408.538086
************BATCH-NUM = 1**************
Comp name = stream_muxer in_system_timestamp = 1607707850927.357910 out_system_timestamp = 1607707850937.496094 component latency= 10.138184
Comp name = stream_muxer in_system_timestamp = 1607707850935.074951 out_system_timestamp = 1607707850937.497070 component latency= 2.422119
Comp name = primary-nvinference-engine in_system_timestamp = 1607707850937.539062 out_system_timestamp = 1607707851061.644043 component latency= 124.104980
Comp name = tracker in_system_timestamp = 1607707851061.662109 out_system_timestamp = 1607707851415.853027 component latency= 354.190918
Again weird value like -1607707851408.538086, sometime the nvtiler is included, sometime nvtiler is exccuded.
In all cases, no report on the total latency time of the frame for each source is reported. I also observe wildly different component latency depending on whose element’s pad I attached the probe to. I’m not sure what I did wrong?
