skim1
December 6, 2021, 11:47am
#1
Can this happens with deepstream-app?
Is there any inbuilt utility to get latency measurement in deepstream python apps?
************BATCH-NUM = 279**************
Comp name = nvosd0 in_system_timestamp = 1638786455453.705078 out_system_timestamp = 1638786455458.547119 component latency= 4.842041
Comp name = osd_conv in_system_timestamp = 1638786455452.995117 out_system_timestamp = 1638786455453.216064 component latency= 0.220947
Comp name = tiled_display_tiler in_system_timestamp = 1638786455350.739990 out_system_timestamp = 1638786455351.545898 component latency= 0.805908
Comp name = tracking_tracker in_system_timestamp = 1638786455224.802002 out_system_timestamp = 1638786455226.194092 component latency= 1.392090
Comp name = primary_gie in_system_timestamp = 1638786455221.758057 out_system_timestamp = 1638786455224.792969 component latency= 3.034912
Comp name = nvstreammux-src_bin_muxer source_id = 0 pad_index = 0 frame_num = 279 in_system_timestamp = 1638786455193.233887 out_system_timestamp = 1638786455221.726074 component_latency = 28.492188
Comp name = nvv4l2decoder0 in_system_timestamp = 1638786455020.454102 out_system_timestamp = 1638786455193.197998 component latency= 172.743896
Source id = 0 Frame_num = 279 Frame latency = 1638786455551.444092 (ms)
You may need to generate python binding for nvds_measure_buffer_latency() first according to the instruction deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
And then you can use this API to enable latency function as DeepStream SDK FAQ - #12 by bcao
skim1
December 7, 2021, 9:54am
#5
And what about : [Link]
(NvDsMetaType — Deepstream Python ##DeepStream_VERSION## documentation )
How we can access NVDS_LATENCY_MEASUREMENT_META : metadata type to be set for latency measurement ?
The enviroment setting and a probe function with getting user meta of NVDS_LATENCY_MEASUREMENT_META type are still needed.
skim1
December 7, 2021, 10:11am
#7
Sorry I couldn’t get this…
in this case we don’t need to write the python bindings for nvds_measure_buffer_latency() api?
we can get the latency info in the probe by accessing NVDS_LATENCY_MEASUREMENT_META?
Because it’s part of NvDsMeta, so in the PGIE probe can we get this info in l_frame?
Yes. You can access NVDS_LATENCY_MEASUREMENT_META type user meta to get latency info if you don’t want to use nvds_measure_buffer_latency() API. The proper place of the probe function has been shown in DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
skim1
December 7, 2021, 10:26am
#9
You can access NVDS_LATENCY_MEASUREMENT_META type user meta to get latency info if you don’t want to use nvds_measure_buffer_latency() API .
num_sources_in_batch = nvds_measure_buffer_latency(buf, latency_info);
again this can’t be replicated to python right?
No, there is no binding for it now.
skim1
December 7, 2021, 10:49am
#11
Is there some sample reference to start with writing bindings from deepstream C api to python api?
skim1
December 7, 2021, 11:01am
#12
[https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/12?u=imsk ](DeepStream SDK FAQ - #12 by bcao )
@Fiona.Chen
In this one a separate probe latency_measurement_buf_prob() is created.
What I am asking is can’t we get NVDS_LATENCY_MEASUREMENT_META from usermeta from gst_buffer in any of the probe function like other batchmeta, framemeta etc?
Without using nvds_measure_buffer_latency() api??
because NVDS_LATENCY_MEASUREMENT_META is already there in NvDsMetaType.
I think I have shared the sample. deepstream_python_apps/bindings at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
skim1:
Yes. You can get NVDS_LATENCY_MEASUREMENT_META user meta from NvDsMetaType. But it should be in the probe function. This special meta will collect the latency information for most deepstream component, the information is time related, so it is meaningful after the data pass through the whole pipeline. If you collect the latency in different place and different time, some component may be missed. Please following the sample.
skim1
December 8, 2021, 4:23am
#14
I saw below mentioned code in /deepstream-5.1/sources/apps/sample_apps/deepstream-nvdsanalytics-test/deepstream_app_main.c
Here I haven’t seen nvds_measure_buffer_latency() API called anywhere.
NvDsFrameLatencyInfo *latency_info = NULL;
NvDsDisplayMeta *display_meta =
nvds_acquire_display_meta_from_pool (batch_meta);
if(nvds_enable_latency_measurement) {
g_mutex_lock (&appCtx->latency_lock);
latency_info = &appCtx->latency_info[index];
display_meta->num_labels++;
display_meta->text_params[1].display_text = g_strdup_printf ("Latency: %lf",
latency_info->latency);
g_mutex_unlock (&appCtx->latency_lock);
@Fiona.Chen
@mchi
can you share the structure for the same (to access NVDS_LATENCY_MEASUREMENT_META from user meta)?
We have shown you the recommanded interface is nvds_measure_buffer_latency() and the c/c++ sample DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
Please read the Makefile.ds carefully. This app should be build with the following source codes:
SRCS:= $(wildcard ../../apps-common/src/*.c)
SRCS+= $(wildcard ../deepstream-app/deepstream_app.c ../deepstream-app/deepstream_app_config_parser.c)
Have you searched all the codes?
How much do you know about c/c++ programming? I think it is not a deepstream issue. We have provided enough document and samples. Please study the code and sample carefully.
system
closed
January 4, 2022, 1:59am
#19
