How to access Deepstream latency informations in python
• Hardware Platform (Jetson / GPU) Jetson Orin AGX
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) question
I want to get the latency of a (or multiple) component(s) of my pipeline. My code is in python, using the python bindings.
I understand that in C++, we would use the function nvds_measure_buffer_latency(), but since there is no binding in python for it, I am trying to get NVDS_LATENCY_MEASUREMENT_META user meta from NvDsMetaType, as explained by Fiona.Chen here : How to get the latency from deepstream python apps - #13 by Fiona.Chen
Taking example on this NvDsUserMeta — Deepstream Deepstream Version: 6.3 documentation (nvidia.com), I presume it would look something like this :
def latency_measurement_probe(self,pad, info, u_data):
	buffer = info.get_buffer()
	if not buffer:
	    self.logger.info('Unable to get GstBuffer')
	    return
	batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buffer))
	l_user = batch_meta.batch_user_meta_list
	while l_user is not None:
	    try:
		user_meta=pyds.NvDsUserMeta.cast(l_user.data)
	    except StopIteration:
		break
	    if(user_meta and user_meta.base_meta.meta_type == pyds.NvDsMetaType.NVDS_LATENCY_MEASUREMENT_META):
		try:
		    latency_meta = pyds.NvDsFrameLatencyInfo.cast(user_meta.user_meta_data)
		    #or latency_meta = pyds.NvDsMetaCompLatency.cast(user_meta.user_meta_data)
		    break
		latency_ms = latency_meta.latency
		print("Latency :",latency_ms,"ms")
	return Gst.PadProbeReturn.OK
But neither NvDsFrameLatencyInfo nor NvDsMetaCompLatency exist in the binding. So the question is how can I access latency informations that are in the user metadata in python ?
You need to bind the structures by referring the BINDINGSGUIDE.md.
Thank you for the answer. I followed the guide to create binding for the NvDsFrameLatencyInfo struct, but when i look at the latency I get an absurd value (1.145327…93e+243). Am I missing something with my probe code ?
Yes. You can refer to our C demo code : latency_info[i].latency. The latency_meta should be a list.
I see, but currently my variable latency_meta is non iterable, maybe i’m casting it wrong ?
here is my binding code (I also added binding for the nvds_measure_buffer_latency function but didn’t get more success with it, I just don’t get how to call the function in python)
    void bindnvds_latency_meta(py::module &m) {
        py::class_<NvDsFrameLatencyInfo>(m, "NvDsFrameLatencyInfo",
                                pydsdoc::nvds_latency_metadoc::NvDsFrameLatencyInfoDoc::descr)
        .def(py::init<>()) // Constructor wrapper, empty for struct
        .def_readwrite("source_id", &NvDsFrameLatencyInfo::source_id)
        .def_readwrite("frame_num", &NvDsFrameLatencyInfo::frame_num)
        .def_readwrite("comp_in_timestamp", &NvDsFrameLatencyInfo::comp_in_timestamp)
        .def_readwrite("latency", &NvDsFrameLatencyInfo::latency)
        .def("cast",
            [](void *data) { // Function definition
                return (NvDsFrameLatencyInfo *) data; // Cast void* to NvDsLatencyInfo*
            py::return_value_policy::reference, // Ownership of return object must remain with C++
            pydsdoc::nvds_latency_metadoc::NvDsFrameLatencyInfoDoc::cast); // Docstring
        m.def("nvds_measure_buffer_latency",
        &nvds_measure_buffer_latency,
        "buf"_a,
        "latency_info"_a,
        pydsdoc::methodsDoc::nvds_measure_buffer_latency);
    } // Define the bindings function declared in the header file
OK. We will try adding this feature next version and notify you once it is completed.
Thank you very much, i’m sure it will help a lot of peoples
Hi there, I came across this thread when I was looking for a method to get latency info for the pipeline in python, I wanted to ask is there any update on the availability of the feature anytime soon? @yuweiw
We will release this feature in our next version.
Hi, I came across this thread as well.
Is there news regarding exposing the latency information in python? @yuweiw
Yes. Please refer to our latest deepstream-test3 sample.
