**• Hardware Platform (Jetson / GPU)Jetson
**• DeepStream Version6.3
**• JetPack Version (valid for Jetson only)5.1.2
• TensorRT Version
**• Issue Type( questions, new requirements, bugs)question
I would like to know how to measure the latency of each plugin when the deepstream application is running slow.
https://forums.developer.nvidia.com/t/latency-measure-for-every-frame/278047/6
I did the following with reference to
- pip install cffi
- apply the following patch to deepstream_test_3.py
diff --git a/apps/deepstream-test3/deepstream_test_3.py b/apps/deepstream-test3/deepstream_test_3.py
index d81ec92..21d2f3b 100755
--- a/apps/deepstream-test3/deepstream_test_3.py
+++ b/apps/deepstream-test3/deepstream_test_3.py
@@ -36,6 +36,28 @@ from common.FPS import PERF_DATA
import pyds
+from cffi import FFI
+ffi = FFI()
+clib = None
+ffi.cdef("""
+typedef struct
+ uint32_t source_id;
+ uint32_t frame_num;
+ double comp_in_timestamp;
+ double latency;
+} NvDsFrameLatencyInfo;
+uint32_t nvds_measure_buffer_latency(void *buf, NvDsFrameLatencyInfo *latency_info);
+bool nvds_get_enable_latency_measurement();
+# Compile the C sources to produce the following .dll (or .so under *nix)
+clib = ffi.dlopen("/opt/nvidia/deepstream/deepstream/lib/libnvdsgst_meta.so")
no_display = False
silent = False
file_loop = False
@@ -56,6 +78,27 @@ OSD_PROCESS_MODE= 0
OSD_DISPLAY_TEXT= 1
pgie_classes_str= ["Vehicle", "TwoWheeler", "Person","RoadSign"]
+batch_num = 0
+def osd_src_pad_buffer_probe(pad, info, u_data):
+ number_source = u_data
+ gst_buffer = info.get_buffer()
+ if not gst_buffer:
+ print("Unable to get GstBuffer ")
+ return
+ global batch_num
+ if clib.nvds_get_enable_latency_measurement:
+ print(f"************BATCH-NUM = {batch_num}**************")
+ c_gst_buf = ffi.cast("void *", hash(gst_buffer))
+ cNvDsFrameLatencyInfo = ffi.new(f"NvDsFrameLatencyInfo[{number_source}]")
+ sources = clib.nvds_measure_buffer_latency(c_gst_buf, cNvDsFrameLatencyInfo)
+ for i in range(sources):
+ print(f"Source id = {cNvDsFrameLatencyInfo[i].source_id} "
+ f"Frame_num = {cNvDsFrameLatencyInfo[i].frame_num} "
+ f"Frame latency = {cNvDsFrameLatencyInfo[i].latency} (ms) ")
+ batch_num += 1
+ return Gst.PadProbeReturn.OK
# pgie_src_pad_buffer_probe will extract metadata received on tiler sink pad
# and update params for drawing rectangle, object information etc.
def pgie_src_pad_buffer_probe(pad,info,u_data):
@@ -199,7 +242,7 @@ def create_source_bin(index,uri):
return None
return nbin
-def main(args, requested_pgie=None, config=None, disable_probe=False):
+def main(args, requested_pgie=None, config=None, disable_probe=True):
global perf_data
perf_data = PERF_DATA(len(args))
@@ -380,6 +423,12 @@ def main(args, requested_pgie=None, config=None, disable_probe=False):
# perf callback function to print fps every 5 sec
GLib.timeout_add(5000, perf_data.perf_print_callback)
+ osd_src_pad=nvosd.get_static_pad("src")
+ if not osd_src_pad:
+ sys.stderr.write(" Unable to get src pad \n")
+ else:
+ osd_src_pad.add_probe(Gst.PadProbeType.BUFFER, osd_src_pad_buffer_probe, number_sources)
# List the sources
print("Now playing...")
for i, source in enumerate(args):
- Execute the following command in the shell
export NVDS_ENABLE_COMPONENT_LATENCY_MEASUREMENT=1
export NVDS_ENABLE_LATENCY_MEASUREMENT=1
python3 deepstream_test_3.py --no-display -i rtsp://"yourtspuri0" uri1
When I run it, I get the following error
| Traceback (most recent call last):
| File "/usr/local/lib/python3.8/dist-packages/cffi/api.py", line 266, in new
| cdecl = self._typeof(cdecl)
| File "/usr/local/lib/python3.8/dist-packages/cffi/api.py", line 186, in _typeof
| result = self._typeof_locked(cdecl)
| File "/usr/local/lib/python3.8/dist-packages/cffi/api.py", line 171, in _typeof_locked
| type = self._parser.parse_type(cdecl)
| File "/usr/local/lib/python3.8/dist-packages/cffi/cparser.py", line 552, in parse_type
| return self.parse_type_and_quals(cdecl)[0]
| File "/usr/local/lib/python3.8/dist-packages/cffi/cparser.py", line 555, in parse_type_and_quals
| ast, macros = self._parse('void __dummy(\n%s\n);' % cdecl)[:2]
| File "/usr/local/lib/python3.8/dist-packages/cffi/cparser.py", line 338, in _parse
| self.convert_pycparser_error(e, csource)
| File "/usr/local/lib/python3.8/dist-packages/cffi/cparser.py", line 367, in convert_pycparser_error
| raise CDefError(msg)
| cffi.CDefError: cannot parse "NvDsFrameLatencyInfo[<__gi__.GstNv3dSink object at 0xffff8363d480 (GstNv3dSink at 0x2406b750)>]"
| <cdef source string>:2:22: before: <
| ************BATCH-NUM = 0**************
| File "/usr/local/lib/python3.8/dist-packages/cffi/api.py", line 183, in _typeof
| result = self._parsed_types[cdecl]
| KeyError: 'NvDsFrameLatencyInfo[<__gi__.GstNv3dSink object at 0xffff8363d480 (GstNv3dSink at 0x2406b750)>]'
| During handling of the above exception, another exception occurred:
| File "/usr/local/lib/python3.8/dist-packages/cffi/cparser.py", line 336, in _parse
| ast = _get_parser().parse(fullcsource)
| File "/usr/local/lib/python3.8/dist-packages/pycparser/c_parser.py", line 147, in parse
| return self.cparser.parse(
| File "/usr/local/lib/python3.8/dist-packages/pycparser/ply/yacc.py", line 331, in parse
| return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
| File "/usr/local/lib/python3.8/dist-packages/pycparser/ply/yacc.py", line 1199, in parseopt_notrack
| tok = call_errorfunc(self.errorfunc, errtoken, self)
| File "/usr/local/lib/python3.8/dist-packages/pycparser/ply/yacc.py", line 193, in call_errorfunc
| r = errorfunc(token)
| File "/usr/local/lib/python3.8/dist-packages/pycparser/c_parser.py", line 1931, in p_error
| self._parse_error(
| File "/usr/local/lib/python3.8/dist-packages/pycparser/plyparser.py", line 67, in _parse_error
| raise ParseError("%s: %s" % (coord, msg))
| pycparser.plyparser.ParseError: <cdef source string>:2:22: before: <
What am I missing?
