• Hardware Platform (Jetson / GPU) : Jetson Xavier NX
• DeepStream Version: 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1-1+cuda10.2
I have an .etlt model that was trained based on Yolo3 with TAO (v3.21.11) toolkit on a Nvidia EC2 instance with CUDA 11.2. The output files are the .etlt model and the calibration file. I used the code in deepstream-tao_apps to do inference on jetson with my new model, but it shows the errors as below.
My configuration file is:
[property]
gpu-id=0
net-scale-factor=1.0
offsets=103.939;116.779;123.68
model-color-format=1
labelfile-path=my_yolo_labels.txt
model-engine-file=…/…/deepstream_tao_apps/models/tao_model/saved.engine
int8-calib-file=…/…/deepstream_tao_apps/models/tao_model/cal.bin
tlt-encoded-model=…/…/deepstream_tao_apps/models/tao_model/yolov3_resnet18_epoch_002.etlt
tlt-model-key=nvidia_tlt
infer-dims=3;544;960
maintain-aspect-ratio=1
uff-input-order=0
uff-input-blob-name=Input
batch-size=1
network-mode=1
num-detected-classes=4
interval=0
gie-unique-id=1
is-classifier=0
#network-type=0
#no cluster
cluster-mode=3
output-blob-names=BatchedNMS
parse-bbox-func-name=NvDsInferParseCustomBatchedNMSTLT
custom-lib-path=…/…/post_processor/libnvds_infercustomparser_tao.so
[class-attrs-all]
pre-cluster-threshold=0.3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=0
detected-max-h=0
Any suggestion would be helpful. Thanks.
