Hey there, I am trying to pass an array of LightData (LightData*) to my Launch Parameters. My host code initializes an std::vector<LightData> lightData with the corresponding information for each light, and then I pass it to my launch parameters by assigning launchParams.lights = lightData.data(). However, my device code keeps crashing because of an illegal memory access within this LightData array. Before I make the call to OptiXLaunch, I make sure to update the space allocated for the launch parameters on my device by freeing the device_ptr, then reallocating space of size sizeof(launchParams). Could this be because my pipeline’s module is set up by passing the pipelineLaunchParamsVariableName, and at that point it just sees a LightData* in my launch parameter struct, not knowing how many elements the array will contain? What is the correct way to do this?
The launchParams.lights must be a pointer to GPU device memory. You cannot just assign the host side array pointer to that. That is not visible by the GPU.
Instead you need two more steps: Allocate the device memory with a CUDA runtime or driver API call to get a CUdeviceptr to a sufficiently large memory block.
Then you need to copy your lightData array data from host to device with a CUDA memcpy call.
