Hi, I have installed pytorch on my Xavier NX from https://developer.download.nvidia.cn/compute/redist/jp/v51/pytorch/torch-1.14.0a0+44dac51c.nv23.01-cp38-cp38-linux_aarch64.whl. However, when I import torch, I receive the following exception
File "<stdin>", line 1, in <module>
File "/data/cascade-st/venv/lib/python3.8/site-packages/torch/__init__.py", line 192, in <module>
_load_global_deps()
File "/data/cascade-st/venv/lib/python3.8/site-packages/torch/__init__.py", line 154, in _load_global_deps
ctypes.CDLL(lib_path, mode=ctypes.RTLD_GLOBAL)
File "/home/dev/.pyenv/versions/3.8.15/lib/python3.8/ctypes/__init__.py", line 373, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libcublas.so.11: cannot open shared object file: No such file or directory
When I try to find the version of Jetpack with apt-cache show I find the following.
Package: nvidia-jetpack
Version: 4.6.3-b17
Architecture: arm64
Maintainer: NVIDIA Corporation
Installed-Size: 194
Depends: nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0), nvidia-cuda (= 4.6.3-b17), nvidia-tensorrt (= 4.6.3-b17), nvidia-nsight-sys (= 4.6.3-b17), nvidia-cudnn8 (= 4.6.3-b17), nvidia-opencv (= 4.6.3-b17), nvidia-container (= 4.6.3-b17), nvidia-vpi (= 4.6.3-b17)
Homepage: http://developer.nvidia.com/jetson
Priority: standard
Section: metapackages
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.3-b17_arm64.deb
SHA256: bc486787ebc35228cd51b647f581e52f53e6238c0444a7654d3dcd43c6c8f6aa
SHA1: 5db526f319cae2dca64d7722cdb72bc9eaccb6c1
MD5sum: 5e44667d6e5b9d6d7ea8f0830fb83d66
Description: NVIDIA Jetpack Meta Package
Description-md5: ad1462289bdbc54909ae109d1d32c0a8
Version: 4.6.2-b5
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.2-b5), nvidia-opencv (= 4.6.2-b5), nvidia-cudnn8 (= 4.6.2-b5), nvidia-tensorrt (= 4.6.2-b5), nvidia-visionworks (= 4.6.2-b5), nvidia-container (= 4.6.2-b5), nvidia-vpi (= 4.6.2-b5), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.2-b5_arm64.deb
SHA256: 3b173ce179df79348fc68254a1fa4b7c9fc1d65ff2a065de7bf70459223ac39f
SHA1: eb5f9357dffa31c6945b39d6d28f7ef31b10fda2
MD5sum: 93001822fdf68db3a47cc832a17cbce8
Version: 4.6.1-b110
Architecture: arm64
Installed-Size: 194
Depends: nvidia-cuda (= 4.6.1-b110), nvidia-opencv (= 4.6.1-b110), nvidia-cudnn8 (= 4.6.1-b110), nvidia-tensorrt (= 4.6.1-b110), nvidia-visionworks (= 4.6.1-b110), nvidia-container (= 4.6.1-b110), nvidia-vpi (= 4.6.1-b110), nvidia-l4t-jetson-multimedia-api (>> 32.7-0), nvidia-l4t-jetson-multimedia-api (<< 32.8-0)
Priority: standard
Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_4.6.1-b110_arm64.deb
SHA256: 312e75d89d0837472668714c43590fd204a33b9c7727c542e1b5df367ec239c4
SHA1: 769cbf1c7acb9e39a4539879884a570bde12292c
MD5sum: a074f5225dfe8d7ea24560b15eef08d9
Can you please help mi with the reason I am seeing multiple Jetpack versions and how can I solve the issue with Pytorch.
