I tried to use this method, but TX2 cuda version is 9.0. I don’t know how to modify it.
I used this tutorial you provided :
Python2.7
Download wheel file from here:
sudo apt-get install python-pip
pip install torch-1.0.0a0+8601b33-cp27-cp27mu-linux_aarch64.whl
pip install numpy
Torch can be found in pip list. When I import torch in python, the error showed:
ImportError: libcudart.so.10.0:cannot open shared object file: No such file or directory.
Thanks for your reply. I tried this cript to build pyTorch, but it still showed error as follows. LOL…
nvidia@tegra-ubuntu:~/pytorch$ python setup.py build_deps
running build_deps
/home/nvidia/pytorch/torch/_thnn/utils.py:1: RuntimeWarning: Parent module ‘torch._thnn’ not found while handling absolute import
import os
/home/nvidia/pytorch/torch/_thnn/utils.py:2: RuntimeWarning: Parent module ‘torch._thnn’ not found while handling absolute import
import itertools
/home/nvidia/pytorch/torch/_thnn/utils.py:3: RuntimeWarning: Parent module ‘torch._thnn’ not found while handling absolute import
import importlib
CMake Warning (dev) at /usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:179 (if):
if given arguments:
"TRUE"
An argument named “TRUE” appears in a conditional statement. Policy
CMP0012 is not set: if() recognizes numbers and boolean constants. Run
“cmake --help-policy CMP0012” for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
Call Stack (most recent call first):
/usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:224 (_OPENMP_GET_SPEC_DATE)
CMakeLists.txt:65 (FIND_PACKAGE)
This warning is for project developers. Use -Wno-dev to suppress it.
if given arguments:
"TRUE"
/usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:266 (_OPENMP_GET_SPEC_DATE)
– Compiling with OpenMP support
– Could not find hardware support for NEON on this machine.
– No OMAP3 processor on this machine.
– No OMAP4 processor on this machine.
– asimd/Neon found with compiler flag : -D__NEON__
– TH_SO_VERSION: 1
– Atomics: using GCC intrinsics
– Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m]
– Library mkl_gf_lp64: not found
– Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m]
– Checking for [mkl_gf - mkl_gnu_thread - mkl_core - iomp5 - pthread - m]
– Library mkl_gf: not found
– Checking for [mkl_gf - mkl_intel_thread - mkl_core - iomp5 - pthread - m]
– Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m]
– Library mkl_intel_lp64: not found
– Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m]
– Checking for [mkl_intel - mkl_gnu_thread - mkl_core - iomp5 - pthread - m]
– Library mkl_intel: not found
– Checking for [mkl_intel - mkl_intel_thread - mkl_core - iomp5 - pthread - m]
– Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - pthread - m]
– Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - pthread - m]
– Checking for [mkl_gf - mkl_gnu_thread - mkl_core - pthread - m]
– Checking for [mkl_gf - mkl_intel_thread - mkl_core - pthread - m]
– Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - pthread - m]
– Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - pthread - m]
– Checking for [mkl_intel - mkl_gnu_thread - mkl_core - pthread - m]
– Checking for [mkl_intel - mkl_intel_thread - mkl_core - pthread - m]
– Checking for [mkl_gf_lp64 - mkl_sequential - mkl_core - m]
– Checking for [mkl_gf - mkl_sequential - mkl_core - m]
– Checking for [mkl_intel_lp64 - mkl_sequential - mkl_core - m]
– Checking for [mkl_intel - mkl_sequential - mkl_core - m]
– Checking for [mkl - guide - pthread - m]
– Library mkl: not found
– MKL library not found
– Checking for [openblas]
– Library openblas: BLAS_openblas_LIBRARY-NOTFOUND
– Checking for [openblas - pthread]
– Checking for [goto2 - gfortran]
– Library goto2: BLAS_goto2_LIBRARY-NOTFOUND
– Checking for [goto2 - gfortran - pthread]
– Checking for [acml - gfortran]
– Library acml: BLAS_acml_LIBRARY-NOTFOUND
– Checking for [Accelerate]
– Library Accelerate: BLAS_Accelerate_LIBRARY-NOTFOUND
– Checking for [vecLib]
– Library vecLib: BLAS_vecLib_LIBRARY-NOTFOUND
– Checking for [ptf77blas - atlas - gfortran]
– Library ptf77blas: BLAS_ptf77blas_LIBRARY-NOTFOUND
– Checking for [blas]
– Library blas: BLAS_blas_LIBRARY-NOTFOUND
– Cannot find a library with BLAS API. Not using BLAS.
– LAPACK requires BLAS
– Cannot find a library with LAPACK API. Not using LAPACK.
– Configuring done
– Generating done
– Build files have been written to: /home/nvidia/pytorch/torch/lib/build/TH
[100%] Built target TH
Install the project…
– Install configuration: “Release”
– Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTH.so.1
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/TH.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THAllocator.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THMath.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THBlas.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THDiskFile.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THFile.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THFilePrivate.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGeneral.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateAllTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateHalfType.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateFloatTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateIntTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THLapack.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THLogAdd.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THMemoryFile.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THRandom.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THStorage.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensor.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorApply.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorDimApply.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorMacros.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THVector.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THAtomic.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THHalf.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/vector/AVX.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/vector/AVX2.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THBlas.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THBlas.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THLapack.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THLapack.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorage.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorage.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorageCopy.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorageCopy.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensor.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensor.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorConv.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorConv.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorCopy.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorCopy.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorLapack.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorLapack.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorMath.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorMath.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorRandom.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorRandom.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THVectorDispatch.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THVector.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/share/cmake/TH/THConfig.cmake
– TH_LIBRARIES: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTH.so.1
– THS_SO_VERSION: 1
– Configuring done
– Generating done
– Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THS
Scanning dependencies of target THS
[ 50%] Building C object CMakeFiles/THS.dir/THSTensor.c.o
[100%] Linking C shared library libTHS.so
[100%] Built target THS
– Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTHS.so.1
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THS.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateAllTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateFloatTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateIntTypes.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSTensor.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensor.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensor.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensorMath.c
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensorMath.h
if given arguments:
"TRUE"
CMakeLists.txt:52 (FIND_PACKAGE)
if given arguments:
"TRUE"
CMake Warning (dev) at CMakeLists.txt:61 (LINK_DIRECTORIES):
This command specifies the relative path
as a link directory.
Policy CMP0015 is not set: link_directories() treats paths relative to the
source dir. Run “cmake --help-policy CMP0015” for policy details. Use the
cmake_policy command to set the policy and suppress this warning.
– THNN_SO_VERSION: 1
– Configuring done
– Generating done
– Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THNN
[100%] Built target THNN
– Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTHNN.so.1
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THNN/THNN.h
– Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THNN/generic/THNN.h
– Removing -DNDEBUG from compile flags
– MAGMA not found. Compiling without MAGMA support
– Autodetected CUDA architecture(s): 6.2
– got cuda version 9.0
– Found CUDA with FP16 support, compiling with torch.CudaHalfTensor
– CUDA_NVCC_FLAGS: -DTH_INDEX_BASE=0 -I/home/nvidia/pytorch/torch/lib/tmp_install/include -I/home/nvidia/pytorch/torch/lib/tmp_install/include/TH -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THC -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THS -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THCS -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THPP;-gencode;arch=compute_62,code=sm_62;-DCUDA_HAS_FP16=1
– THC_SO_VERSION: 1
– Configuring done
– Generating done
– Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THC
[ 1%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o
[ 3%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCBlas.cu.o
[ 3%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCReduceApplyUtils.cu.o
[ 5%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCSleep.cu.o
[ 6%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCStorage.cu.o
[ 7%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCStorageCopy.cu.o
[ 8%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensor.cu.o
[ 10%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o
[ 11%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(40): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(41): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(42): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(80): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(88): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(92): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(122): error: class “__half” has no member “x”
7 errors detected in the compilation of “/tmp/tmpxft_00005433_00000000-6_THCHalf.cpp1.ii”.
CMake Error at THC_generated_THCHalf.cu.o.cmake:267 (message):
Error generating file
/home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCHalf.cu.o
CMakeFiles/THC.dir/build.make:3839: recipe for target ‘CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o’ failed
make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o] Error 1
make[2]: *** Waiting for unfinished jobs…
/home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(171): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(175): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(114): error: class “__half” has no member “x”
/home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(115): error: class “__half” has no member “x”
6 errors detected in the compilation of “/tmp/tmpxft_000054a3_00000000-6_THCTensorCopy.cpp1.ii”.
CMake Error at THC_generated_THCTensorCopy.cu.o.cmake:267 (message):
/home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorCopy.cu.o
CMakeFiles/THC.dir/build.make:1866: recipe for target ‘CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o’ failed
make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o] Error 1
6 errors detected in the compilation of “/tmp/tmpxft_000054c3_00000000-6_THCTensorMath.cpp1.ii”.
CMake Error at THC_generated_THCTensorMath.cu.o.cmake:267 (message):
/home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorMath.cu.o
CMakeFiles/THC.dir/build.make:2683: recipe for target ‘CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o’ failed
make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o] Error 1
CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/THC.dir/all’ failed
make[1]: *** [CMakeFiles/THC.dir/all] Error 2
Makefile:127: recipe for target ‘all’ failed
make: *** [all] Error 2
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - pthread - m]
bash: --: command not found
nvidia@tegra-ubuntu:~/pytorch$ – Library mkl_intel_lp64: not found
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - pthread - m]
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [mkl_intel - mkl_gnu_thread - mkl_core - pthread - m]
nvidia@tegra-ubuntu:~/pytorch$ – Library mkl_intel: not found
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [mkl_intel - mkl_intel_thread - mkl_core - pthread - m]
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [mkl - guide - pthread - m]
nvidia@tegra-ubuntu:~/pytorch$ – Library mkl: not found
nvidia@tegra-ubuntu:~/pytorch$ – MKL library not found
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [openblas]
nvidia@tegra-ubuntu:~/pytorch$ – Library openblas: BLAS_openblas_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [openblas - pthread]
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [goto2 - gfortran]
nvidia@tegra-ubuntu:~/pytorch$ – Library goto2: BLAS_goto2_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [goto2 - gfortran - pthread]
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [acml - gfortran]
nvidia@tegra-ubuntu:~/pytorch$ – Library acml: BLAS_acml_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [Accelerate]
nvidia@tegra-ubuntu:~/pytorch$ – Library Accelerate: BLAS_Accelerate_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [vecLib]
nvidia@tegra-ubuntu:~/pytorch$ – Library vecLib: BLAS_vecLib_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [ptf77blas - atlas - gfortran]
nvidia@tegra-ubuntu:~/pytorch$ – Library ptf77blas: BLAS_ptf77blas_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Checking for [blas]
nvidia@tegra-ubuntu:~/pytorch$ – Library blas: BLAS_blas_LIBRARY-NOTFOUND
nvidia@tegra-ubuntu:~/pytorch$ – Cannot find a library with BLAS API. Not using BLAS.
nvidia@tegra-ubuntu:~/pytorch$ – LAPACK requires BLAS
nvidia@tegra-ubuntu:~/pytorch$ – Cannot find a library with LAPACK API. Not using LAPACK.
nvidia@tegra-ubuntu:~/pytorch$ – Configuring done
nvidia@tegra-ubuntu:~/pytorch$ – Generating done
nvidia@tegra-ubuntu:~/pytorch$ – Build files have been written to: /home/nvidia/pytorch/torch/lib/build/TH
nvidia@tegra-ubuntu:~/pytorch$ [100%] Built target TH
bash: [100%]: command not found
nvidia@tegra-ubuntu:~/pytorch$ Install the project…
bash: Install: command not found
nvidia@tegra-ubuntu:~/pytorch$ – Install configuration: “Release”
nvidia@tegra-ubuntu:~/pytorch$ – Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTH.so.1
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/TH.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THAllocator.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THMath.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THBlas.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THDiskFile.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THFile.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THFilePrivate.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGeneral.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateAllTypes.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateHalfType.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateFloatTypes.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THGenerateIntTypes.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THLapack.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THLogAdd.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THMemoryFile.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THRandom.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THStorage.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensor.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorApply.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorDimApply.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THTensorMacros.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THVector.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THAtomic.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/THHalf.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/vector/AVX.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/vector/AVX2.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THBlas.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THBlas.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THLapack.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THLapack.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorage.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorage.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorageCopy.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THStorageCopy.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensor.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensor.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorConv.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorConv.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorCopy.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorCopy.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorLapack.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorLapack.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorMath.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorMath.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorRandom.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THTensorRandom.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THVectorDispatch.c
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/TH/generic/THVector.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/share/cmake/TH/THConfig.cmake
nvidia@tegra-ubuntu:~/pytorch$ – TH_LIBRARIES: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTH.so.1
nvidia@tegra-ubuntu:~/pytorch$ – THS_SO_VERSION: 1
nvidia@tegra-ubuntu:~/pytorch$ – Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THS
nvidia@tegra-ubuntu:~/pytorch$ Scanning dependencies of target THS
bash: Scanning: command not found
nvidia@tegra-ubuntu:~/pytorch$ [ 50%] Building C object CMakeFiles/THS.dir/THSTensor.c.o
6bash: [: missing ]' nvidia@tegra-ubuntu:~/pytorch$ [100%] Linking C shared library libTHS.so bash: [100%]: command not found nvidia@tegra-ubuntu:~/pytorch$ [100%] Built target THS bash: [100%]: command not found nvidia@tegra-ubuntu:~/pytorch$ Install the project... nbash: Install: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Install configuration: "Release" bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTHS.so.1 bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTHS.so bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THS.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateAllTypes.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateFloatTypes.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSGenerateIntTypes.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/THSTensor.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensor.c bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensor.h bash: --: command not found Device) object CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o [ 11%] Building NVCC (Dnvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensorMath.c bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THS/generic/THSTensorMath.h bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- TH_LIBRARIES: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTH.so.1 bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ CMake Warning (dev) at /usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:179 (if): bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ if given arguments:
i> “TRUE”
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ "cmake --help-policy CMP0012" for policy details. Use the cmake_policy bash: cmake --help-policy CMP0012: command not found nvidia@tegra-ubuntu:~/pytorch$ command to set the policy and suppress this warning. bash: to: command not found nvidia@tegra-ubuntu:~/pytorch$ Call Stack (most recent call first): bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ /usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:224 (_OPENMP_GET_SPEC_DATE)
bash: syntax error near unexpected token _OPENMP_GET_SPEC_DATE' nvidia@tegra-ubuntu:~/pytorch$ CMakeLists.txt:52 (FIND_PACKAGE) bash: syntax error near unexpected token FIND_PACKAGE’
nvidia@tegra-ubuntu:~/pytorch$ This warning is for project developers. Use -Wno-dev to suppress it.
bash: This: command not found
bash: syntax error near unexpected token `(’
"TRUE"
nvidia@tegra-ubuntu:~/pytorch$ /usr/local/share/cmake-3.7/Modules/FindOpenMP.cmake:266 (_OPENMP_GET_SPEC_DATE)
nvidia@tegra-ubuntu:~/pytorch$ – Compiling with OpenMP support
nvidia@tegra-ubuntu:~/pytorch$ CMake Warning (dev) at CMakeLists.txt:61 (LINK_DIRECTORIES):
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ This command specifies the relative path bash: This: command not found nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ as a link directory. Assembler messages: Error: can't open a for reading: No such file or directory a: Error: can't open link for reading: No such file or directory link: Error: can't open directory. for reading: No such file or directory nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ Policy CMP0015 is not set: link_directories() treats paths relative to the bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ source dir. Run “cmake --help-policy CMP0015” for policy details. Use the
bash: dir.: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ cmake_policy command to set the policy and suppress this warning.
bash: cmake_policy: command not found
nvidia@tegra-ubuntu:~/pytorch$ – THNN_SO_VERSION: 1
nvidia@tegra-ubuntu:~/pytorch$ – Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THNN
nvidia@tegra-ubuntu:~/pytorch$ [100%] Built target THNN
nvidia@tegra-ubuntu:~/pytorch$ – Installing: /home/nvidia/pytorch/torch/lib/tmp_install/lib/libTHNN.so.1
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THNN/THNN.h
nvidia@tegra-ubuntu:~/pytorch$ – Up-to-date: /home/nvidia/pytorch/torch/lib/tmp_install/include/THNN/generic/THNN.h
nvidia@tegra-ubuntu:~/pytorch$ – Removing -DNDEBUG from compile flags
nvidia@tegra-ubuntu:~/pytorch$ – MAGMA not found. Compiling without MAGMA support
nvidia@tegra-ubuntu:~/pytorch$ – Autodetected CUDA architecture(s): 6.2
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ -- got cuda version 9.0 idbash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Found CUDA with FP16 support, compiling with torch.CudaHalfTensor bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- CUDA_NVCC_FLAGS: -DTH_INDEX_BASE=0 -I/home/nvidia/pytorch/torch/lib/tmp_install/include -I/home/nvidia/pytorch/torch/lib/tmp_install/include/TH -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THC -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THS -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THCS -I/home/nvidia/pytorch/torch/lib/tmp_install/include/THPP;-gencode;arch=compute_62,code=sm_62;-DCUDA_HAS_FP16=1 bash: --: command not found bash: -gencode: command not found bash: -DCUDA_HAS_FP16=1: command not found nvidia@tegra-ubuntu:~/pytorch$ -- THC_SO_VERSION: 1 bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Configuring done bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Generating done bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ -- Build files have been written to: /home/nvidia/pytorch/torch/lib/build/THC bash: --: command not found nvidia@tegra-ubuntu:~/pytorch$ [ 1%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ [ 3%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCBlas.cu.o
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ [ 3%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCReduceApplyUtils.cu.o bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ [ 5%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCSleep.cu.o
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ [ 6%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCStorage.cu.o bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ [ 7%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCStorageCopy.cu.o
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ [ 8%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensor.cu.o bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ [ 10%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ [ 11%] Building NVCC (Device) object CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(40): error: class “__half” has no member “x”
bash: syntax error near unexpected token 40' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(41): error: class "__half" has no member "x" bash: syntax error near unexpected token 41’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(42): error: class “__half” has no member “x”
bash: syntax error near unexpected token 42' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(80): error: class "__half" has no member "x" bash: syntax error near unexpected token 80’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(88): error: class “__half” has no member “x”
bash: syntax error near unexpected token 88' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(92): error: class "__half" has no member "x" bash: syntax error near unexpected token 92’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCHalf.cu(122): error: class “__half” has no member “x”
bash: syntax error near unexpected token 122' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ 7 errors detected in the compilation of "/tmp/tmpxft_00005433_00000000-6_THCHalf.cpp1.ii". bash: 7: command not found nvidia@tegra-ubuntu:~/pytorch$ CMake Error at THC_generated_THCHalf.cu.o.cmake:267 (message): bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ Error generating file
bash: Error: command not found
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCHalf.cu.o
bash: /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCHalf.cu.o: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ CMakeFiles/THC.dir/build.make:3839: recipe for target ‘CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o’ failed
bash: CMakeFiles/THC.dir/build.make:3839:: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCHalf.cu.o] Error 1
bash: make[2]:: command not found
nvidia@tegra-ubuntu:~/pytorch$ make[2]: *** Waiting for unfinished jobs…
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(171): error: class “__half” has no member “x”
bash: syntax error near unexpected token 171' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(171): error: class "__half" has no member "x" bash: syntax error near unexpected token 171’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(175): error: class “__half” has no member “x”
bash: syntax error near unexpected token 175' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(175): error: class "__half" has no member "x" bash: syntax error near unexpected token 175’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(114): error: class “__half” has no member “x”
bash: syntax error near unexpected token 114' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(115): error: class "__half" has no member "x" bash: syntax error near unexpected token 115’
nvidia@tegra-ubuntu:~/pytorch$ 6 errors detected in the compilation of “/tmp/tmpxft_000054a3_00000000-6_THCTensorCopy.cpp1.ii”.
bash: 6: command not found
nvidia@tegra-ubuntu:~/pytorch$ CMake Error at THC_generated_THCTensorCopy.cu.o.cmake:267 (message):
bash: syntax error near unexpected token (' nvidia@tegra-ubuntu:~/pytorch$ Error generating file bash: Error: command not found nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorCopy.cu.o bash: /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorCopy.cu.o: No such file or directory nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ CMakeFiles/THC.dir/build.make:1866: recipe for target 'CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o' failed bash: CMakeFiles/THC.dir/build.make:1866:: No such file or directory nvidia@tegra-ubuntu:~/pytorch$ make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCTensorCopy.cu.o] Error 1 bash: make[2]:: command not found nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(171): error: class "__half" has no member "x" bash: syntax error near unexpected token 171’
bash: syntax error near unexpected token 171' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCTensorTypeUtils.cuh(175): error: class "__half" has no member "x" bash: syntax error near unexpected token 175’
bash: syntax error near unexpected token 175' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(114): error: class "__half" has no member "x" bash: syntax error near unexpected token 114’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/THC/THCNumerics.cuh(115): error: class “__half” has no member “x”
bash: syntax error near unexpected token 115' nvidia@tegra-ubuntu:~/pytorch$ nvidia@tegra-ubuntu:~/pytorch$ 6 errors detected in the compilation of "/tmp/tmpxft_000054c3_00000000-6_THCTensorMath.cpp1.ii". bash: 6: command not found nvidia@tegra-ubuntu:~/pytorch$ CMake Error at THC_generated_THCTensorMath.cu.o.cmake:267 (message): bash: syntax error near unexpected token (’
nvidia@tegra-ubuntu:~/pytorch$ /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorMath.cu.o
bash: /home/nvidia/pytorch/torch/lib/build/THC/CMakeFiles/THC.dir//./THC_generated_THCTensorMath.cu.o: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ CMakeFiles/THC.dir/build.make:2683: recipe for target ‘CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o’ failed
bash: CMakeFiles/THC.dir/build.make:2683:: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ make[2]: *** [CMakeFiles/THC.dir/THC_generated_THCTensorMath.cu.o] Error 1
nvidia@tegra-ubuntu:~/pytorch$ CMakeFiles/Makefile2:67: recipe for target ‘CMakeFiles/THC.dir/all’ failed
bash: CMakeFiles/Makefile2:67:: No such file or directory
nvidia@tegra-ubuntu:~/pytorch$ make[1]: *** [CMakeFiles/THC.dir/all] Error 2
bash: make[1]:: command not found
nvidia@tegra-ubuntu:~/pytorch$ Makefile:127: recipe for target ‘all’ failed
bash: Makefile:127:: command not found
nvidia@tegra-ubuntu:~/pytorch$ make: *** [all] Error 2
bash: make:: command not found
I have been installing many Frameworks on Jetson TX2, with many JetPack versions.
I’ve found out that the most stable version of JetPack for most frameworks is JetPack-3.1.
I think that is so because of Cuda 8.0, which most frameworks accept really well.
I strongly suggest that you flash your TX2 with it.
After you successfully flash it, here is the tutorial that I wrote for myself in order to install torch and torchvision on Jetson TX2. Enjoy.
Just a quick note: This installation process happens with no problems, however, pytorch doesn`t work properly, specially the module object which gets many erros on declarations.
I`m currently trying alternative installations, if I succeed I will share.
Finally, I was able to work my way around the problem.
The command list has been updated.
The final tutorial is to be used after a clean JetPack flash.
I strongly suggest either JetPack3.2.1 or JetPack3.3
tinydao were you able to find a solution for this? I have the same issue, can’t build torch for JetPack3.3 with python 3.5 from any of the linked sources (same error: class “__half” has no member “x”). Could not find a wheel either. Any help is highly appreciated as I don’t want to flash my Jetson just for the sake of python3.6
nvidia@tegra-ubuntu:~/pytorch$ sudo python3 setup.py install
nvlink error : entry function '_Z33ncclAllReduceTreeLLKernel_sum_u648ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceRingLLKernel_sum_u648ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceTreeLLKernel_sum_i648ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceRingLLKernel_sum_i648ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceTreeLLKernel_sum_u328ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceRingLLKernel_sum_u328ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceTreeLLKernel_sum_i328ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z33ncclAllReduceRingLLKernel_sum_i328ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z32ncclAllReduceTreeLLKernel_sum_u88ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z32ncclAllReduceRingLLKernel_sum_u88ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z32ncclAllReduceTreeLLKernel_sum_i88ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
nvlink error : entry function '_Z32ncclAllReduceRingLLKernel_sum_i88ncclColl' with max regcount of 80 calls function '_Z29ncclReduceScatterRing_max_f64P14CollectiveArgs' with regcount of 96
Makefile:68: recipe for target '/home/nvidia/pytorch/build/nccl/obj/collectives/device/devlink.o' failed
make[2]: *** [/home/nvidia/pytorch/build/nccl/obj/collectives/device/devlink.o] Error 255
make[2]: Leaving directory '/home/nvidia/pytorch/third_party/nccl/nccl/src/collectives/device'
Makefile:44: recipe for target '/home/nvidia/pytorch/build/nccl/obj/collectives/device/colldevice.a' failed
make[1]: *** [/home/nvidia/pytorch/build/nccl/obj/collectives/device/colldevice.a] Error 2
make[1]: Leaving directory '/home/nvidia/pytorch/third_party/nccl/nccl/src'
Makefile:25: recipe for target 'src.build' failed
make: *** [src.build] Error 2
[51/2792] Building CXX object third_pa...__/src/google/protobuf/descriptor.cc.o
ninja: build stopped: subcommand failed.
File "setup.py", line 720, in <module>
build_deps()
File "setup.py", line 286, in build_deps
build_dir='build')
File "/home/nvidia/pytorch/tools/build_pytorch_libs.py", line 278, in build_caffe2
check_call(ninja_cmd, cwd=build_dir, env=my_env)
File "/usr/lib/python3.5/subprocess.py", line 581, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['ninja', 'install']' returned non-zero exit status 1
What is wrong the following problems ???
SystemError: Cannot compile ‘Python.h’. Perhaps you need to install python-dev|python-devel.
I try: sudo apt install python-dev
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package python-dev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
python python:i386 python:amd64
E: Package ‘python-dev’ has no installation candidate
