The compiling of Pytorch 1.4.0 with python 2.7 for CUDA 10.2
Good day,
NVIDIA Jetson-AGX
 L4T 32.5.0 [ JetPack 4.5 ]
   Ubuntu 18.04.6 LTS
   Kernel Version: 4.9.201-tegra
 CUDA 10.2.89
   CUDA Architecture: 7.2
 OpenCV version: 4.1.1
   OpenCV Cuda: NO
 CUDNN: 8.0.0.180
 TensorRT: 7.1.3.0
 Vision Works: 1.6.0.501
 VPI: 1.0.15
 Vulcan: 1.2.70
I would like to use Pytorch on my Jetson AGX board. I am working with Python 2.7, so the latest version of pytorch, which I can use is 1.4 . However I couldn’t find the wheel for my Jetson AGX parameters (CUDA 10.2) and after that I would like to build it from the source. I have used the next example: PyTorch for Jetson to compile the wheel for my case.
I have used the next configuration for TORCH_CUDA_ARCH_LIST:
export TORCH_CUDA_ARCH_LIST="10.2"
On the step:
python setup.py bdist_wheel
I have met the next error:
Building wheel torch-1.4.0
-- Building version 1.4.0
cmake -GNinja -DBUILD_PYTHON=True -DBUILD_TEST=True -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/home/nvidia/pytorch1.4/pytorch/torch -DCMAKE_PREFIX_PATH=/home/nvidia/catkin_ws3/devel:/opt/ros/melodic -DNUMPY_INCLUDE_DIR=/usr/lib/python2.7/dist-packages/numpy/core/include -DPYTHON_EXECUTABLE=/usr/bin/python -DPYTHON_INCLUDE_DIR=/usr/include/python2.7 -DPYTHON_LIBRARY=/usr/lib/libpython2.7.so.1.0 -DTORCH_BUILD_VERSION=1.4.0 -DUSE_DISTRIBUTED=0 -DUSE_NCCL=0 -DUSE_NUMPY=True -DUSE_PYTORCH_QNNPACK=0 -DUSE_QNNPACK=0 /home/nvidia/pytorch1.4/pytorch
-- std::exception_ptr is supported.
-- NUMA is available
-- Building using own protobuf under third_party per request.
-- Use custom protobuf build.
-- Caffe2 protobuf include directory: $<BUILD_INTERFACE:/home/nvidia/pytorch1.4/pytorch/third_party/protobuf/src>$<INSTALL_INTERFACE:include>
-- Trying to find preferred BLAS backend of choice: MKL
-- MKL_THREADING = OMP
CMake Warning at cmake/Dependencies.cmake:141 (message):
  MKL could not be found.  Defaulting to Eigen
Call Stack (most recent call first):
  CMakeLists.txt:380 (include)
CMake Warning at cmake/Dependencies.cmake:160 (message):
  Preferred BLAS (MKL) cannot be found, now searching for a general BLAS
  library
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_intel_lp64: not found
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_intel: not found
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_gf_lp64: not found
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - gomp - pthread - m - dl]
--   Library mkl_gf: not found
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_gnu_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_intel_thread - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_intel - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_gf - mkl_sequential - mkl_core - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - gomp - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - iomp5 - pthread - m - dl]
-- Checking for [mkl_intel_lp64 - mkl_core - pthread - m - dl]
-- Checking for [mkl_intel - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf_lp64 - mkl_core - pthread - m - dl]
-- Checking for [mkl_gf - mkl_core - pthread - m - dl]
-- Checking for [mkl - guide - pthread - m]
--   Library mkl: not found
-- MKL library not found
-- Checking for [Accelerate]
--   Library Accelerate: BLAS_Accelerate_LIBRARY-NOTFOUND
-- Checking for [vecLib]
--   Library vecLib: BLAS_vecLib_LIBRARY-NOTFOUND
-- Checking for [openblas]
--   Library openblas: /usr/lib/aarch64-linux-gnu/libopenblas.so
-- Found a library with BLAS API (open).
-- Brace yourself, we are building NNPACK
-- NNPACK backend is neon
-- Found PythonInterp: /usr/bin/python (found version "2.7.17")
-- git Version: v1.4.0-505be96a
-- Version: 1.4.0
-- Performing Test HAVE_STD_REGEX -- success
-- Performing Test HAVE_GNU_POSIX_REGEX -- failed to compile
-- Performing Test HAVE_POSIX_REGEX -- success
-- Performing Test HAVE_STEADY_CLOCK -- success
-- Found Numa  (include: /usr/include, library: /usr/lib/aarch64-linux-gnu/libnuma.so)
-- Using third party subdirectory Eigen.
Python 2.7.17
-- Found PythonInterp: /usr/bin/python (found suitable version "2.7.17", minimum required is "2.7")
-- Could NOT find pybind11 (missing: pybind11_DIR)
-- Could NOT find pybind11 (missing: pybind11_INCLUDE_DIR)
-- Using third_party/pybind11.
-- pybind11 include dirs: /home/nvidia/pytorch1.4/pytorch/cmake/../third_party/pybind11/include
-- Adding OpenMP CXX_FLAGS: -fopenmp
-- No OpenMP library needs to be linked against
-- Caffe2: CUDA detected: 10.2
-- Caffe2: CUDA nvcc is: /usr/local/cuda-10.2/bin/nvcc
-- Caffe2: CUDA toolkit directory: /usr/local/cuda-10.2
-- Caffe2: Header version is: 10.2
-- Found cuDNN: v7.6.5  (include: /usr/local/cuda-10.2/include, library: /usr/local/cuda-10.2/lib64/libcudnn.so)
CMake Warning at cmake/public/utils.cmake:196 (message):
  In the future we will require one to explicitly pass TORCH_CUDA_ARCH_LIST
  to cmake instead of implicitly setting it as an env variable.  This will
  become a FATAL_ERROR in future version of pytorch.
  cmake/public/cuda.cmake:395 (torch_cuda_get_nvcc_gencode_flag)
  cmake/Dependencies.cmake:903 (include)
CMake Error at cmake/Modules_CUDA_fix/upstream/FindCUDA/select_compute_arch.cmake:215 (message):
  Unknown CUDA Architecture Name 10.2 in CUDA_SELECT_NVCC_ARCH_FLAGS
  cmake/public/utils.cmake:212 (cuda_select_nvcc_arch_flags)
CMake Error at cmake/Modules_CUDA_fix/upstream/FindCUDA/select_compute_arch.cmake:219 (message):
  arch_bin wasn't set for some reason
-- Added CUDA NVCC flags for:
-- Could NOT find CUB (missing: CUB_INCLUDE_DIR)
Generated: /home/nvidia/pytorch1.4/pytorch/build/third_party/onnx/onnx/onnx_onnx_torch-ml.proto
Generated: /home/nvidia/pytorch1.4/pytorch/build/third_party/onnx/onnx/onnx-operators_onnx_torch-ml.proto
-- ******** Summary ********
--   CMake version         : 3.10.2
--   CMake command         : /usr/bin/cmake
--   System                : Linux
--   C++ compiler          : /usr/bin/c++
--   C++ compiler version  : 7.5.0
--   CXX flags             :  -fvisibility-inlines-hidden -fopenmp -Wnon-virtual-dtor
--   Build type            : Release
--   Compile definitions   : ONNX_ML=1
--   CMAKE_PREFIX_PATH     : /home/nvidia/catkin_ws3/devel:/opt/ros/melodic;/usr/local/cuda-10.2
--   CMAKE_INSTALL_PREFIX  : /home/nvidia/pytorch1.4/pytorch/torch
--   CMAKE_MODULE_PATH     : /home/nvidia/pytorch1.4/pytorch/cmake/Modules;/home/nvidia/pytorch1.4/pytorch/cmake/public/../Modules_CUDA_fix
--   ONNX version          : 1.6.0
--   ONNX NAMESPACE        : onnx_torch
--   ONNX_BUILD_TESTS      : OFF
--   ONNX_BUILD_BENCHMARKS : OFF
--   ONNX_USE_LITE_PROTO   : OFF
--   ONNXIFI_DUMMY_BACKEND : OFF
--   ONNXIFI_ENABLE_EXT    : OFF
--   Protobuf compiler     :
--   Protobuf includes     :
--   Protobuf libraries    :
--   BUILD_ONNX_PYTHON     : OFF
--   System                : Linux
--   ONNX version          : 1.4.1
-- Found CUDA with FP16 support, compiling with torch.cuda.HalfTensor
-- Removing -DNDEBUG from compile flags
-- MAGMA not found. Compiling without MAGMA support
-- Could not find hardware support for NEON on this machine.
-- No OMAP3 processor on this machine.
-- No OMAP4 processor on this machine.
-- asimd/Neon found with compiler flag : -D__NEON__
-- Found a library with LAPACK API (open).
disabling ROCM because NOT USE_ROCM is set
-- MIOpen not found. Compiling without MIOpen support
disabling MKLDNN because USE_MKLDNN is not set
-- GCC 7.5.0: Adding gcc and gcc_s libs to link line
-- NUMA paths:
-- /usr/include
-- /usr/lib/aarch64-linux-gnu/libnuma.so
-- Found OpenMP_C: -fopenmp
-- Found OpenMP_CXX: -fopenmp
-- Found OpenMP: TRUE
-- Configuring build for SLEEF-v3.4.0
   Target system: Linux-4.9.201-tegra
   Target processor: aarch64
   Host system: Linux-4.9.201-tegra
   Host processor: aarch64
   Detected C compiler: GNU @ /usr/bin/cc
-- Using option `-Wall -Wno-unused -Wno-attributes -Wno-unused-result -Wno-psabi -ffp-contract=off -fno-math-errno -fno-trapping-math` to compile libsleef
-- Building shared libs : OFF
-- MPFR : LIB_MPFR-NOTFOUND
-- GMP : LIBGMP-NOTFOUND
-- RT : /usr/lib/aarch64-linux-gnu/librt.so
-- FFTW3 : LIBFFTW3-NOTFOUND
-- OPENSSL : 1.1.1
-- SDE : SDE_COMMAND-NOTFOUND
-- RUNNING_ON_TRAVIS : 0
-- COMPILER_SUPPORTS_OPENMP : 1
AT_INSTALL_INCLUDE_DIR include/ATen/core
core header install: /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/core/TensorBody.h
core header install: /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/core/TensorMethods.h
-- NCCL operators skipped due to no CUDA support
-- Excluding ideep operators as we are not using ideep
-- Excluding image processing operators due to no opencv
-- Excluding video processing operators due to no opencv
-- MPI operators skipped due to no MPI support
-- Include Observer library
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/AffineGridGenerator.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/BatchNorm.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/Conv.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/GridSampler.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/LossCTC.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cudnn/RNN.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/miopen/BatchNorm_miopen.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/miopen/Conv_miopen.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/miopen/RNN_miopen.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/sparse/cuda/SparseCUDATensor.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/CUDABlas.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/CUDAContext.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/CUDAGenerator.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/CuSparseHandlePool.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/CublasHandlePool.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/PinnedMemoryAllocator.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/detail/CUDAHooks.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/CUDAUnaryOps.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/LegacyDefinitions.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/TensorShapeCUDA.cpp
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/CUDAType.cpp
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/CUDAType.h
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/LegacyTHFunctionsCUDA.cpp
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/LegacyTHFunctionsCUDA.h
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/SparseCUDAType.cpp
--   /home/nvidia/pytorch1.4/pytorch/build/aten/src/ATen/SparseCUDAType.h
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCCachingHostAllocator.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCGeneral.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCStorageCopy.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensor.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCReduceApplyUtils.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCBlas.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCSleep.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCStorage.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCStorageCopy.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensor.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorCopy.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMath.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMathBlas.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMathMagma.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMathPairwise.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMathReduce.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMathScan.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorIndex.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorRandom.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorScatterGather.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorTopK.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorSort.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCSortUtils.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/THCTensorMode.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortByte.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseByte.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceByte.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedByte.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortChar.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseChar.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceChar.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedChar.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortShort.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseShort.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceShort.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedShort.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortInt.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseInt.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceInt.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedInt.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortLong.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseLong.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceLong.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedLong.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortHalf.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseHalf.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceHalf.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedHalf.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortFloat.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseFloat.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceFloat.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedFloat.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorSortDouble.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseDouble.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceDouble.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedDouble.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathPointwiseBool.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceBool.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedBool.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMathReduceBFloat16.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THC/generated/THCTensorMaskedBFloat16.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/BCECriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/ClassNLLCriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/ELU.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/GatedLinearUnit.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/HardTanh.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/LeakyReLU.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/LogSigmoid.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/MultiLabelMarginCriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/MultiMarginCriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/RReLU.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SoftMarginCriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SoftPlus.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SoftShrink.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SpatialClassNLLCriterion.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SpatialConvolutionMM.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/SpatialDepthwiseConvolution.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/THCUNN/Tanh.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cuda/detail/IndexUtils.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Activation.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AdaptiveAveragePooling.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AdaptiveAveragePooling3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AdaptiveMaxPooling2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AdaptiveMaxPooling3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AveragePool2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/AveragePool3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/BatchLinearAlgebra.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/BinaryArithmeticKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/BinaryCompareKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/BinaryMiscOpsKernels.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/CUDAScalar.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Col2Im.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Copy.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/CrossKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/DilatedMaxPool2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/DilatedMaxPool3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/DistanceKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Distributions.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Dropout.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Embedding.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/EmbeddingBackwardKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/EmbeddingBag.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/FillKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/FractionalMaxPool2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/FractionalMaxPool3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/GridSampler.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Im2Col.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/IndexKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Indexing.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Lerp.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/LinearAlgebra.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Loss.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/LossCTC.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/MaxUnpooling.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/MultinomialKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/NaiveConvolutionTranspose2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/NaiveConvolutionTranspose3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/NaiveDilatedConvolution.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Normalization.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/PointwiseOpsKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/PowKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/RNN.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/RangeFactories.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Reduce.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/ReduceOpsKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/ReflectionPad.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Repeat.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/ReplicationPadding.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Resize.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/SoftMax.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/SortingKthValue.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/SparseMM.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/SpectralOps.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/SummaryOps.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/TensorCompare.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/TensorFactories.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/TensorTransformations.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/TriangularOps.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UnaryOpsKernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/Unique.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleBicubic2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleBilinear2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleLinear1d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleNearest1d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleNearest2d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleNearest3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/UpSampleTrilinear3d.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/WeightNorm.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/cuda/layer_norm_kernel.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/sparse/cuda/SparseCUDABlas.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/sparse/cuda/SparseCUDATensor.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/sparse/cuda/SparseCUDATensorMath.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/quantized/cuda/fake_quantize_core.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/quantized/cuda/fake_quantize_per_channel_affine.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/native/quantized/cuda/fake_quantize_per_tensor_affine.cu
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cudnn/Descriptors.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cudnn/Handle.cpp
--   /home/nvidia/pytorch1.4/pytorch/aten/src/ATen/cudnn/Types.cpp
--   /home/nvidia/pytorch1.4/pytorch/caffe2/core/common_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/core/blob_serialization_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/core/common_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/core/event_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/core/context_gpu.cu
--   utils/math/broadcast.cu
--   utils/math/elementwise.cu
--   utils/math/reduce.cu
--   utils/math/transpose.cu
--   utils/math_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/contrib/aten/aten_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/db/create_db_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/distributed/file_store_handler_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_op_cache_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_transpose_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/dropout_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elu_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/local_response_normalization_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/order_switch_ops_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/pool_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sigmoid_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/softmax_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/tanh_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/transpose_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/channelwise_conv3d_op_cudnn.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/depthwise_3x3_conv_op_cudnn.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/spatial_batch_norm_op_cudnn.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/communicator_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/concat_split_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_op_shared_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/conv_transpose_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/counter_ops_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/do_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_add_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_sub_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/exp_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/expand_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/expand_squeeze_dims_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/free_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/fully_connected_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/if_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/im2col_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/load_save_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/locally_connected_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/log_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/matmul_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/negate_gradient_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/negative_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/order_switch_ops_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/prepend_dim_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reshape_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/scale_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/shape_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sqr_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sqrt_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/stop_gradient_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/tensor_protos_db_input_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/while_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/zero_gradient_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/abs_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/accumulate_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/accuracy_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/acos_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/affine_channel_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/alias_with_name.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/arg_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/asin_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/assert_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/atan_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/batch_gather_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/batch_matmul_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/batch_moments_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/batch_permutation_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/batch_sparse_to_dense_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/boolean_mask_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/boolean_unmask_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/bucketize_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cast_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cbrt_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/ceil_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/channel_backprop_stats_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/channel_shuffle_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/channel_stats_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/clip_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/copy_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cos_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cosh_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cosine_embedding_criterion_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cross_entropy_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/cube_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/data_couple_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/deform_conv_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/distance_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/dropout_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_div_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_linear_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_mul_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elementwise_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/elu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/enforce_finite_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/ensure_cpu_output_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/erf_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/filler_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/find_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/floor_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/gather_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/gelu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/generate_proposals_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/generate_proposals_op_util_nms_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/given_tensor_byte_string_to_uint8_fill_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/given_tensor_fill_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/glu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/group_norm_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/gru_unit_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/half_float_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/hard_sigmoid_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/instance_norm_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/integral_image_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/layer_norm_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/leaky_relu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/lengths_pad_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/lengths_tile_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/local_response_normalization_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/logit_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/loss_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/lp_pool_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/lstm_unit_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/margin_ranking_criterion_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/max_pool_with_index.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/mean_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/mem_query_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/minmax_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/moments_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/multi_class_accuracy_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/normalize_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/one_hot_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/pack_segments.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/pad_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/perplexity_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/piecewise_linear_transform_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/pool_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/pow_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/prelu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reciprocal_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reduce_front_back_max_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reduce_front_back_sum_mean_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reduce_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reduction_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/relu_n_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/relu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/replace_nan_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/resize_3d_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/resize_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/reverse_packed_segs_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rmac_regions_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/roi_align_gradient_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/roi_align_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/roi_align_rotated_gradient_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/roi_align_rotated_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/roi_pool_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rsqrt_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/scale_blobs_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/segment_reduction_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/selu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sequence_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sigmoid_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sin_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sinh_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/slice_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/softmax_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/softplus_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/softsign_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/space_batch_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sparse_normalize_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/sparse_to_dense_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/spatial_batch_norm_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/stump_func_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/summarize_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/swish_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/tan_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/tanh_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/thresholded_relu_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/tile_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/top_k.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/transpose_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/unique_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/upsample_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/utility_ops.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/weighted_sample_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rnn/recurrent_op_cudnn.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rnn/recurrent_network_blob_fetcher_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rnn/recurrent_network_executor_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/operators/rnn/recurrent_network_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/queue/queue_ops_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/iter_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/learning_rate_op_gpu.cc
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/adadelta_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/adagrad_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/adam_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/fp16_momentum_sgd_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/fp32_momentum_sgd_op.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/lars_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/momentum_sgd_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/rmsprop_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/sgd/yellowfin_op_gpu.cu
--   /home/nvidia/pytorch1.4/pytorch/caffe2/../torch/csrc/jit/fuser/cuda/fused_kernel.cpp
--   /home/nvidia/pytorch1.4/pytorch/caffe2/../torch/csrc/autograd/profiler_cuda.cpp
--   /home/nvidia/pytorch1.4/pytorch/caffe2/../torch/csrc/autograd/functions/comm.cpp
--   /home/nvidia/pytorch1.4/pytorch/caffe2/../torch/csrc/cuda/comm.cpp
-- /usr/bin/c++ /home/nvidia/pytorch1.4/pytorch/caffe2/../torch/abi-check.cpp -o /home/nvidia/pytorch1.4/pytorch/build/abi-check
-- Determined _GLIBCXX_USE_CXX11_ABI=1
-- pytorch is compiling with OpenMP.
OpenMP CXX_FLAGS: -fopenmp.
OpenMP libraries: /usr/lib/gcc/aarch64-linux-gnu/7/libgomp.so;/usr/lib/aarch64-linux-gnu/libpthread.so.
-- Caffe2 is compiling with OpenMP.
-- Using ATen parallel backend: OMP
-- Using lib/python2.7/dist-packages as python relative installation path
CMake Warning at CMakeLists.txt:583 (message):
  Generated cmake files are only fully tested if one builds with system glog,
  gflags, and protobuf.  Other settings may generate files that are not well
  tested.
-- General:
--   System                : Linux
--   C++ compiler id       : GNU
--   BLAS                  : MKL
--   CXX flags             :  -fvisibility-inlines-hidden -fopenmp -O2 -fPIC -Wno-narrowing -Wall -Wextra -Wno-missing-field-initializers -Wno-type-limits -Wno-array-bounds -Wno-unknown-pragmas -Wno-sign-compare -Wno-unused-parameter -Wno-unused-variable -Wno-unused-function -Wno-unused-result -Wno-strict-overflow -Wno-strict-aliasing -Wno-error=deprecated-declarations -Wno-stringop-overflow -Wno-error=pedantic -Wno-error=redundant-decls -Wno-error=old-style-cast -fdiagnostics-color=always -faligned-new -Wno-unused-but-set-variable -Wno-maybe-uninitialized -fno-math-errno -fno-trapping-math -Wno-stringop-overflow
--   Compile definitions   : ONNX_ML=1;ONNX_NAMESPACE=onnx_torch;HAVE_MMAP=1;_FILE_OFFSET_BITS=64;HAVE_SHM_OPEN=1;HAVE_SHM_UNLINK=1;HAVE_MALLOC_USABLE_SIZE=1
--   TORCH_VERSION         : 1.4.0
--   CAFFE2_VERSION        : 1.4.0
--   BUILD_CAFFE2_MOBILE   : ON
--   USE_STATIC_DISPATCH   : OFF
--   BUILD_BINARY          : OFF
--   BUILD_CUSTOM_PROTOBUF : ON
--     Link local protobuf : ON
--   BUILD_DOCS            : OFF
--   BUILD_PYTHON          : True
--     Python version      : 2.7.17
--     Python executable   : /usr/bin/python
--     Pythonlibs version  : 2.7.17
--     Python library      : /usr/lib/libpython2.7.so.1.0
--     Python includes     : /usr/include/python2.7
--     Python site-packages: lib/python2.7/dist-packages
--   BUILD_CAFFE2_OPS      : ON
--   BUILD_SHARED_LIBS     : ON
--   BUILD_TEST            : True
--   BUILD_JNI             : OFF
--   INTERN_BUILD_MOBILE   :
--   USE_ASAN              : OFF
--   USE_CUDA              : ON
--     CUDA static link    : OFF
--     USE_CUDNN           : ON
--     CUDA version        : 10.2
--     cuDNN version       : 7.6.5
--     CUDA root directory : /usr/local/cuda-10.2
--     CUDA library        : /usr/local/cuda-10.2/lib64/stubs/libcuda.so
--     cudart library      : /usr/local/cuda-10.2/lib64/libcudart.so
--     cublas library      : /usr/lib/aarch64-linux-gnu/libcublas.so
--     cufft library       : /usr/local/cuda-10.2/lib64/libcufft.so
--     curand library      : /usr/local/cuda-10.2/lib64/libcurand.so
--     cuDNN library       : /usr/local/cuda-10.2/lib64/libcudnn.so
--     nvrtc               : /usr/local/cuda-10.2/lib64/libnvrtc.so
--     CUDA include path   : /usr/local/cuda-10.2/include
--     NVCC executable     : /usr/local/cuda-10.2/bin/nvcc
--     CUDA host compiler  : /usr/bin/cc
--     USE_TENSORRT        : OFF
--   USE_ROCM              : OFF
--   USE_EIGEN_FOR_BLAS    : ON
--   USE_FBGEMM            : OFF
--   USE_FFMPEG            : OFF
--   USE_GFLAGS            : OFF
--   USE_GLOG              : OFF
--   USE_LEVELDB           : OFF
--   USE_LITE_PROTO        : OFF
--   USE_LMDB              : OFF
--   USE_METAL             : OFF
--   USE_MKL               : OFF
--   USE_MKLDNN            : OFF
--   USE_NCCL              : 0
--   USE_NNPACK            : ON
--   USE_NUMPY             : ON
--   USE_OBSERVERS         : ON
--   USE_OPENCL            : OFF
--   USE_OPENCV            : OFF
--   USE_OPENMP            : ON
--   USE_TBB               : OFF
--   USE_PROF              : OFF
--   USE_QNNPACK           : 0
--   USE_REDIS             : OFF
--   USE_ROCKSDB           : OFF
--   USE_ZMQ               : OFF
--   USE_DISTRIBUTED       : 0
--   BUILD_NAMEDTENSOR   : OFF
--   Public Dependencies  : Threads::Threads
--   Private Dependencies : nnpack;cpuinfo;/usr/lib/aarch64-linux-gnu/libnuma.so;fp16;aten_op_header_gen;foxi_loader;rt;gcc_s;gcc;dl
-- Configuring incomplete, errors occurred!
See also "/home/nvidia/pytorch1.4/pytorch/build/CMakeFiles/CMakeOutput.log".
See also "/home/nvidia/pytorch1.4/pytorch/build/CMakeFiles/CMakeError.log".
  File "setup.py", line 755, in <module>
    build_deps()
  File "setup.py", line 316, in build_deps
    cmake=cmake)
  File "/home/nvidia/pytorch1.4/pytorch/tools/build_pytorch_libs.py", line 59, in build_caffe2
    rerun_cmake)
  File "/home/nvidia/pytorch1.4/pytorch/tools/setup_helpers/cmake.py", line 319, in generate
    self.run(args, env=my_env)
  File "/home/nvidia/pytorch1.4/pytorch/tools/setup_helpers/cmake.py", line 141, in run
    check_call(command, cwd=self.build_dir, env=env)
  File "/usr/lib/python2.7/subprocess.py", line 190, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['cmake', '-GNinja', '-DBUILD_PYTHON=True', '-DBUILD_TEST=True', '-DCMAKE_BUILD_TYPE=Release', '-DCMAKE_INSTALL_PREFIX=/home/nvidia/pytorch1.4/pytorch/torch', '-DCMAKE_PREFIX_PATH=/home/nvidia/catkin_ws3/devel:/opt/ros/melodic', '-DNUMPY_INCLUDE_DIR=/usr/lib/python2.7/dist-packages/numpy/core/include', '-DPYTHON_EXECUTABLE=/usr/bin/python', '-DPYTHON_INCLUDE_DIR=/usr/include/python2.7', '-DPYTHON_LIBRARY=/usr/lib/libpython2.7.so.1.0', '-DTORCH_BUILD_VERSION=1.4.0', '-DUSE_DISTRIBUTED=0', '-DUSE_NCCL=0', '-DUSE_NUMPY=True', '-DUSE_PYTORCH_QNNPACK=0', '-DUSE_QNNPACK=0', '/home/nvidia/pytorch1.4/pytorch']' returned non-zero exit status 1
The CMakeError.log is:
Performing C++ SOURCE FILE Test CAFFE2_COMPILER_SUPPORTS_AVX2_EXTENSIONS failed with the following output:
Change Dir: /home/nvidia/pytorch1.4/pytorch/build/CMakeFiles/CMakeTmp
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_851a0"
[1/2] Building CXX object CMakeFiles/cmTC_851a0.dir/src.cxx.o
FAILED: CMakeFiles/cmTC_851a0.dir/src.cxx.o
/usr/bin/c++    -DCAFFE2_COMPILER_SUPPORTS_AVX2_EXTENSIONS -mavx2 -o CMakeFiles/cmTC_851a0.dir/src.cxx.o -c src.cxx
c++: error: unrecognized command line option ‘-mavx2’
ninja: build stopped: subcommand failed.
Source file was:
#include <immintrin.h>
      int main() {
        __m256i a, b;
        a = _mm256_set1_epi8 (1);
        b = a;
        _mm256_add_epi8 (a,a);
        __m256i x;
        _mm256_extract_epi64(x, 0); // we rely on this in our AVX2 code
        return 0;
Performing C++ SOURCE FILE Test CAFFE2_COMPILER_SUPPORTS_AVX512_EXTENSIONS failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_b2871"
[1/2] Building CXX object CMakeFiles/cmTC_b2871.dir/src.cxx.o
FAILED: CMakeFiles/cmTC_b2871.dir/src.cxx.o
/usr/bin/c++    -DCAFFE2_COMPILER_SUPPORTS_AVX512_EXTENSIONS -mavx512f -mavx512dq -mavx512vl -o CMakeFiles/cmTC_b2871.dir/src.cxx.o -c src.cxx
c++: error: unrecognized command line option ‘-mavx512f’
c++: error: unrecognized command line option ‘-mavx512dq’
c++: error: unrecognized command line option ‘-mavx512vl’
Source file was:
#if defined(_MSC_VER)
     #include <intrin.h>
     #else
     #endif
     // check avx512f
     __m512 addConstant(__m512 arg) {
       return _mm512_add_ps(arg, _mm512_set1_ps(1.f));
     // check avx512dq
     __m512 andConstant(__m512 arg) {
       return _mm512_and_ps(arg, _mm512_set1_ps(1.f));
     int main() {
       __m512i a = _mm512_set1_epi32(1);
       __m256i ymm = _mm512_extracti64x4_epi64(a, 0);
       ymm = _mm256_abs_epi64(ymm); // check avx512vl
       __mmask16 m = _mm512_cmp_epi32_mask(a, a, _MM_CMPINT_EQ);
       __m512i r = _mm512_andnot_si512(a, a);
Determining if the pthread_create exist failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_b8d21"
[1/2] Building C object CMakeFiles/cmTC_b8d21.dir/CheckSymbolExists.c.o
[2/2] Linking C executable cmTC_b8d21
FAILED: cmTC_b8d21
: && /usr/bin/cc   -rdynamic CMakeFiles/cmTC_b8d21.dir/CheckSymbolExists.c.o  -o cmTC_b8d21   && :
CMakeFiles/cmTC_b8d21.dir/CheckSymbolExists.c.o: In function `main':
CheckSymbolExists.c:(.text+0x14): undefined reference to `pthread_create'
CheckSymbolExists.c:(.text+0x18): undefined reference to `pthread_create'
collect2: error: ld returned 1 exit status
File /home/nvidia/pytorch1.4/pytorch/build/CMakeFiles/CMakeTmp/CheckSymbolExists.c:
#include <pthread.h>
int main(int argc, char** argv)
  (void)argv;
#ifndef pthread_create
  return ((int*)(&pthread_create))[argc];
#else
  (void)argc;
  return 0;
#endif
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_a89ae"
[1/2] Building C object CMakeFiles/cmTC_a89ae.dir/CheckFunctionExists.c.o
[2/2] Linking C executable cmTC_a89ae
FAILED: cmTC_a89ae
: && /usr/bin/cc -DCHECK_FUNCTION_EXISTS=pthread_create  -rdynamic CMakeFiles/cmTC_a89ae.dir/CheckFunctionExists.c.o  -o cmTC_a89ae  -lpthreads && :
/usr/bin/ld: cannot find -lpthreads
Performing C SOURCE FILE Test BLAS_F2C_DOUBLE_WORKS failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_2b010"
[1/2] Building C object CMakeFiles/cmTC_2b010.dir/src.c.o
[2/2] Linking C executable cmTC_2b010
Return value: 1
Source file was:
#include <stdlib.h>
#include <stdio.h>
float x[4] = { 1, 2, 3, 4 };
float y[4] = { .1, .01, .001, .0001 };
int four = 4;
int one = 1;
extern double sdot_();
int main() {
  int i;
  double r = sdot_(&four, x, &one, y, &one);
  exit((float)r != (float).1234);
Performing C++ SOURCE FILE Test HAVE_CXX_FLAG_WSHORTEN_64_TO_32 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_1859b"
[1/2] Building CXX object CMakeFiles/cmTC_1859b.dir/src.cxx.o
FAILED: CMakeFiles/cmTC_1859b.dir/src.cxx.o
/usr/bin/c++    -fvisibility-inlines-hidden  -std=c++11  -Wall  -Wextra  -Wshadow  -pedantic  -pedantic-errors -DHAVE_CXX_FLAG_WSHORTEN_64_TO_32  -Wshorten-64-to-32   -Wshorten-64-to-32 -o CMakeFiles/cmTC_1859b.dir/src.cxx.o -c src.cxx
c++: error: unrecognized command line option '-Wshorten-64-to-32'
Source file was:
int main() { return 0; }
Performing C++ SOURCE FILE Test HAVE_CXX_FLAG_WD654 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_f1abe"
[1/2] Building CXX object CMakeFiles/cmTC_f1abe.dir/src.cxx.o
FAILED: CMakeFiles/cmTC_f1abe.dir/src.cxx.o
/usr/bin/c++    -fvisibility-inlines-hidden  -std=c++11  -Wall  -Wextra  -Wshadow  -pedantic  -pedantic-errors  -Wfloat-equal  -fstrict-aliasing  -Wno-deprecated-declarations  -Wstrict-aliasing -DHAVE_CXX_FLAG_WD654  -wd654   -wd654 -o CMakeFiles/cmTC_f1abe.dir/src.cxx.o -c src.cxx
c++: error: unrecognized command line option '-wd654'
Source file was:
Performing C++ SOURCE FILE Test HAVE_CXX_FLAG_WTHREAD_SAFETY failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_d7def"
[1/2] Building CXX object CMakeFiles/cmTC_d7def.dir/src.cxx.o
FAILED: CMakeFiles/cmTC_d7def.dir/src.cxx.o
/usr/bin/c++    -fvisibility-inlines-hidden  -std=c++11  -Wall  -Wextra  -Wshadow  -pedantic  -pedantic-errors  -Wfloat-equal  -fstrict-aliasing  -Wno-deprecated-declarations  -Wstrict-aliasing -DHAVE_CXX_FLAG_WTHREAD_SAFETY  -Wthread-safety   -Wthread-safety -o CMakeFiles/cmTC_d7def.dir/src.cxx.o -c src.cxx
c++: error: unrecognized command line option '-Wthread-safety'; did you mean '-fthread-jumps'?
Source file was:
Determining if the include file cpuid.h exists failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_998af"
[1/2] Building C object CMakeFiles/cmTC_998af.dir/CheckIncludeFile.c.o
FAILED: CMakeFiles/cmTC_998af.dir/CheckIncludeFile.c.o
/usr/bin/cc   -fopenmp  -fPIE -o CMakeFiles/cmTC_998af.dir/CheckIncludeFile.c.o   -c CheckIncludeFile.c
CheckIncludeFile.c:1:10: fatal error: cpuid.h: No such file or directory
 #include <cpuid.h>
compilation terminated.
Performing C SOURCE FILE Test NO_GCC_EBX_FPIC_BUG failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_065aa"
[1/2] Building C object CMakeFiles/cmTC_065aa.dir/src.c.o
FAILED: CMakeFiles/cmTC_065aa.dir/src.c.o
/usr/bin/cc   -fopenmp -DNO_GCC_EBX_FPIC_BUG -fPIE -o CMakeFiles/cmTC_065aa.dir/src.c.o   -c src.c
src.c: In function ‘cpuid’:
src.c:6:9: error: impossible constraint in ‘asm’
         asm volatile ( "cpuid" : "+a"(a), "=b"(b), "+c"(c), "=d"(d) );
Source file was:
#include <stdint.h>
      static inline void cpuid(uint32_t *eax, uint32_t *ebx,
                               uint32_t *ecx, uint32_t *edx)
        uint32_t a = *eax, b, c = *ecx, d;
        *eax = a; *ebx = b; *ecx = c; *edx = d;
      int main() {
        uint32_t a,b,c,d;
        cpuid(&a, &b, &c, &d);
        return 0;
Performing C SOURCE FILE Test C_HAS_AVX_1 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_1db07"
[1/2] Building C object CMakeFiles/cmTC_1db07.dir/src.c.o
FAILED: CMakeFiles/cmTC_1db07.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX_1 -fPIE -o CMakeFiles/cmTC_1db07.dir/src.c.o   -c src.c
src.c:2:12: fatal error: immintrin.h: No such file or directory
Source file was:
  int main()
    __m256 a;
    a = _mm256_set1_ps(0);
    return 0;
Performing C SOURCE FILE Test C_HAS_AVX_2 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_5f07c"
[1/2] Building C object CMakeFiles/cmTC_5f07c.dir/src.c.o
FAILED: CMakeFiles/cmTC_5f07c.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX_2 -mavx -fPIE -o CMakeFiles/cmTC_5f07c.dir/src.c.o   -c src.c
cc: error: unrecognized command line option ‘-mavx’
Source file was:
  int main()
    __m256 a;
    return 0;
Performing C SOURCE FILE Test C_HAS_AVX_3 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_98529"
[1/2] Building C object CMakeFiles/cmTC_98529.dir/src.c.o
FAILED: CMakeFiles/cmTC_98529.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX_3 /arch:AVX -fPIE -o CMakeFiles/cmTC_98529.dir/src.c.o   -c src.c
cc: error: /arch:AVX: No such file or directory
Source file was:
  int main()
    __m256 a;
    return 0;
Performing C SOURCE FILE Test C_HAS_AVX2_1 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_a7cd1"
[1/2] Building C object CMakeFiles/cmTC_a7cd1.dir/src.c.o
FAILED: CMakeFiles/cmTC_a7cd1.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX2_1 -fPIE -o CMakeFiles/cmTC_a7cd1.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256i a = {0};
    a = _mm256_abs_epi16(a);
    __m256i x;
    return 0;
Performing C SOURCE FILE Test C_HAS_AVX2_2 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_24bd3"
[1/2] Building C object CMakeFiles/cmTC_24bd3.dir/src.c.o
FAILED: CMakeFiles/cmTC_24bd3.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX2_2 -mavx2 -mfma -fPIE -o CMakeFiles/cmTC_24bd3.dir/src.c.o   -c src.c
cc: error: unrecognized command line option ‘-mavx2’
cc: error: unrecognized command line option ‘-mfma’
Source file was:
  int main()
    __m256i a = {0};
    __m256i x;
    return 0;
Performing C SOURCE FILE Test C_HAS_AVX2_3 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_0b263"
[1/2] Building C object CMakeFiles/cmTC_0b263.dir/src.c.o
FAILED: CMakeFiles/cmTC_0b263.dir/src.c.o
/usr/bin/cc   -fopenmp -DC_HAS_AVX2_3 /arch:AVX2 -fPIE -o CMakeFiles/cmTC_0b263.dir/src.c.o   -c src.c
cc: error: /arch:AVX2: No such file or directory
Source file was:
  int main()
    __m256i a = {0};
    __m256i x;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX_1 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_962a8"
[1/2] Building C object CMakeFiles/cmTC_962a8.dir/src.c.o
FAILED: CMakeFiles/cmTC_962a8.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX_1 -fPIE -o CMakeFiles/cmTC_962a8.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256 a;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX_2 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_ea8be"
[1/2] Building C object CMakeFiles/cmTC_ea8be.dir/src.c.o
FAILED: CMakeFiles/cmTC_ea8be.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX_2 -mavx -fPIE -o CMakeFiles/cmTC_ea8be.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256 a;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX_3 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_ca1bc"
[1/2] Building C object CMakeFiles/cmTC_ca1bc.dir/src.c.o
FAILED: CMakeFiles/cmTC_ca1bc.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX_3 /arch:AVX -fPIE -o CMakeFiles/cmTC_ca1bc.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256 a;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX2_1 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_89f34"
[1/2] Building C object CMakeFiles/cmTC_89f34.dir/src.c.o
FAILED: CMakeFiles/cmTC_89f34.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX2_1 -fPIE -o CMakeFiles/cmTC_89f34.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256i a = {0};
    __m256i x;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX2_2 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_4b627"
[1/2] Building C object CMakeFiles/cmTC_4b627.dir/src.c.o
FAILED: CMakeFiles/cmTC_4b627.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX2_2 -mavx2 -mfma -fPIE -o CMakeFiles/cmTC_4b627.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256i a = {0};
    __m256i x;
    return 0;
Performing C SOURCE FILE Test CXX_HAS_AVX2_3 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_ea953"
[1/2] Building C object CMakeFiles/cmTC_ea953.dir/src.c.o
FAILED: CMakeFiles/cmTC_ea953.dir/src.c.o
/usr/bin/cc   -fopenmp -DCXX_HAS_AVX2_3 /arch:AVX2 -fPIE -o CMakeFiles/cmTC_ea953.dir/src.c.o   -c src.c
Source file was:
  int main()
    __m256i a = {0};
    __m256i x;
    return 0;
Performing C SOURCE FILE Test COMPILER_SUPPORTS_FLOAT128 failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_a3ad4"
[1/2] Building C object CMakeFiles/cmTC_a3ad4.dir/src.c.o
FAILED: CMakeFiles/cmTC_a3ad4.dir/src.c.o
/usr/bin/cc   -fopenmp -Wno-ignored-qualifiers -Wno-absolute-value -DCOMPILER_SUPPORTS_FLOAT128 -fPIE -o CMakeFiles/cmTC_a3ad4.dir/src.c.o   -c src.c
src.c: In function ‘main’:
src.c:2:16: error: unknown type name ‘__float128’; did you mean ‘_Float128’?
   int main() { __float128 r = 1;
                _Float128
src.c: At top level:
cc1: warning: unrecognized command line option ‘-Wno-absolute-value’
Source file was:
Performing C SOURCE FILE Test COMPILER_SUPPORTS_SVE failed with the following output:
Run Build Command:"/home/nvidia/.local/bin/ninja" "cmTC_88c4f"
[1/2] Building C object CMakeFiles/cmTC_88c4f.dir/src.c.o
FAILED: CMakeFiles/cmTC_88c4f.dir/src.c.o
/usr/bin/cc   -fopenmp -Wno-ignored-qualifiers -Wno-absolute-value -DCOMPILER_SUPPORTS_SVE -march=armv8-a+sve -fPIE -o CMakeFiles/cmTC_88c4f.dir/src.c.o   -c src.c
cc1: error: invalid feature modifier in ‘-march=armv8-a+sve’
Source file was:
  #include <arm_sve.h>
  int main() {
    svint32_t r = svdup_n_s32(1); }
Could you please help me with this question, what is the source of this problem or maybe it is possible to find somewhere the weel for Pytorch 1.4, cp27 for CUDA 10.2 or just CPU?
I have tried to change gcc from 7.5 to 6.5, however it didn’t solve the problem.
On the step
pip install ninja --user
I have met a problem, that ninja was 1.11.0 . When I tried to build Pytorch, there was a problem:
CMake Error at CMakeLists.txt:23 (project):
  Running
   '/home/nvidia/.local/bin/ninja' '--version'
  failed with:
    File "/home/nvidia/.local/bin/ninja", line 5, in <module>
      from ninja import ninja
    File "/home/nvidia/.local/lib/python2.7/site-packages/ninja/__init__.py", line 7, in <module>
      from ._version import version as __version__
    File "/home/nvidia/.local/lib/python2.7/site-packages/ninja/_version.py", line 10
      version: str
  SyntaxError: invalid syntax
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
    build_deps()
    cmake=cmake)
    rerun_cmake)
However, I solved it by using ninja 1.9.0 . I am not sure that it can be a source of the original problem.
Good to know you solved it.
There is a PyTorch v1.4.0 for Python 2.7 on the ink you shared.
So you can also use it directly.
https://forums.developer.nvidia.com/t/pytorch-for-jetson/72048
PyTorch v1.4.0
  • JetPack 4.4 Developer Preview (L4T R32.4.2)
    • Python 2.7 - [torch-1.4.0-cp27-cp27mu-linux_aarch64.whl ]
    • Python 3.6 - [torch-1.4.0-cp36-cp36m-linux_aarch64.whl ]
I just want to let you know, that I didn’t solve the problem with Pytorch building for 10.2 CUDA by Jetson AGX. I just installed another version of the Ninja library (a different version from the building from the source guide).
However, PyTorch v 1.4.0 for Python 2.7, for JetPack 4.4 has worked for me, thank you!
I think the problem was that I found the wheel file (torch 1.4 cp 27) on another forum, and it didn’t work for me. After that, I was sure I needed to build it from the source, so I didn’t try the wheels from the link I shared.
I still can’t build it from the source, but I can just download the wheel file.
